I am an avid reader of the posts but this is only the second time I have
posted.
My beloved synchro has no lights. Low beam in particular.
When I flick the light switch, I get parkers and can make the high beam
come on by holding the arm in on the steering column. When I release the
arm, the high beam goes off and I am left with parkers only.
I have checked the fuses and they are not blown.
Any assistance and/or guidance towarda previous relevant posts would be
greatly appreciated.
second time I have posted.
beam in particular.
can make the high beam come on by holding the arm in on the steering
column. When I release the arm, the high beam goes off and I am left with
parkers only.
blown.
would be greatly appreciated.
It sounds like it's your headlight switch. They tend to go bad on T3's because they are not protected with relays. The current for the lights go directly through the switch. Replace it and you should be good to go. Add relays to your headlights for better current flow and longer life for your switch.
> Hello
> posted.
> Thank you and wishing everyone a fantastic 2011!
> Regards
> Peter
Does your heater fan work?
Does your rear wiper work?
If these still work it is probably your headlight switch.
> Peter <pleolkes@bigbutton.com.au> wrote:
> Hello
> posted.
> Regards
> Peter
beam in particular.
parkers only.
blown.
> The T3's delivered to the US and North America do not have headlight
> relays.
> Seems you are saying OZ T3's came with a headlight relay. If that's the
> case then I stand corrected.
> BenT
> Sent from my relayless headlights
> On Jan 5, 2011, at 1:45 PM, "Mr Scott Pitcher"
> <spbconsulting@bigpond.com> wrote:
> > Peter,
> > Have you tried the headlight relay. They fit into the fuse box area
> and are a square box with about 5 pins from memory. They are fairly
> cheap.
> > Also check your earths - syncros rattle around a lot on corrugated
> roads and earths can come loose.
> > Best of luck.
> > Cheers,
> > Skot
> > ----- Original Message -----
> > From: Peter
> > To: Syncro_T3_Australia@yahoogroups.com
> > Sent: Thursday, January 06, 2011 8:37 AM
> > Subject: [Syncro_T3_Australia] No low beam
> > Hello
> have
> > posted.
> beam
> be
> > Regards
> > Peter
I just assumed it would be the same as the 71 model I have -
had the same problem with that and a headlight relay fixed it. Didn't help that
the 71 had so much windscreen rust that water was flowing over the relay during
rain. The relay was full of rusty water when I removed it.
If there is no relay then a switch would definitely be the
animal.
beam in particular.
and can make the high beam come on by holding the arm in on the
steering column. When I release the arm, the high beam goes off and I
not blown.
posts would be greatly appreciated.
Thank you to BenT, Phill and Skot for your prompt responses to my low
beam issue.
Yes it was the light switch. I purchased one from Imparts Automotive,
315 South Rd.
Mile End, S.A. ph. 1300467278, who had one in stock. ($75.20 GST incl.).
I hope one day I can return the favour!
Behalf Of plander@optusnet.com.au Sent: Thursday, 6 January 2011
8:29 AM To:
Syncro_T3_Australia@yahoogroups.com Subject: [-Disarmed-] Re:
Headlight switch or Ignition switch.
> Hello
> posted.
> Regards
> Peter
Thank you to
BenT, Phill and Skot for your prompt responses to my low beam
issue.
Yes it was
the light switch. I purchased one from Imparts Automotive, 315 South
Rd. Mile End, S.A. ph. 1300467278, who had one in stock. ($75.20
GST incl.).
I hope one
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of
plander@optusnet.com.au Sent: Thursday, 6 January 2011 8:29
AM To:
Headlight
Does your heater fan work? Does your rear
wiper work? If these still work it is probably your headlight
switch.
wrote: > > > Hello > > I am an avid reader of
the posts but this is only the second time I have > posted. >
> My beloved synchro has no lights. Low beam in particular. >
beam > come on by holding the arm in on the steering column. When I
release the > arm, the high beam goes off and I am left with parkers
only. > > I have checked the fuses and they are not
blown. > > Any assistance and/or guidance towarda previous
relevant posts would be > greatly appreciated. > > Thank
you and wishing everyone a fantastic 2011! > > Regards >
> Peter
looks like I have similar symptoms
Parking lights work (ignition on or off)
High beam works, but with flash (light switch off) and latches on high beam when headlight switch is off.
Low beam headlights do not work (either side)
Checked so far:
Both fused good and tested
I have installed additional relays so high power does not run through the switch, have relaced relay, no change.
Checked the wiring where I into/out of the relay
Checked the light switch for continuity, all checks out correct
Checked cables and power into plug that connects to light switch
When turning the light switch on, the relay also clicks.
Have not checked the bulbs yet (but would be odd both went at the same time)
Looks like there is a relay in the fuse box, I will check this also. Does the one relay control both high beam and low beam, or are they separate?
Any ideas where else to look?
Thanks Scott, ignition off there is power to the terminals that supply the parkers and dash lights.
Ignition on I have power to the terminal that supplies the head lights.
With the light switch, I jumped a wire from the supply terminal to the terminal going to the lights with no luck.
Will do some more checking over the week end.
Otherwise my trip away might be day time driving only
Thanks Scott. As they say the problem is always the last place you look… Or for me try the simplest things first!!
Checked the ignition switch also, no luck, pulled the plug from the ignition switch and put on a new one, no change. the power only runs through fuses in the fuse box, not through a relay there
Thinking back on previous testing, the relay (I installed) was turning on/off fine with the light switch, so power was getting to the relay fine.
Just to add a bit more to the story, I have bypassed the main power that runs through the ignition switch, the switch only powers a relay.
So in all, I have three relays to keep high power out of the ignition switch and head light switch, one runs all the accessories, one for low beam, one for high beam (I even doubled up all the high power cables back to the battery).
Anyway, re-did all previous testing, pulled the fuse box out and checked everything there, nothing obvious.
Well, time to look at the head lights themselves, yep power was getting to the light plugs!!
So in short, yes BOTH head lights had blown at the same time (was driving the previous night with both lights working). Never would have thought that.
Anyway, two new bulbs installed and I’m back up and running.
Rather than fit the spare (standard) bulbs I have, bought a set of the “130+” bulbs. But might need to look at LED ones
One day left to finish preparing the bus for a trip away
Have been busy again, spent a week over on Moreton Island. Great to get away and a nice relaxing trip. Very little driving but a lot of fun.
Seem to be having a few gremlins creeping into the Syncro.
In addition to the bulbs, on Moreton, the radiator fan was not kicking in, was just a blown fuse luckily. Few days later, losr power to the dash accessories. Again a blown fuse. Also having trouble with the battery. Alternator/regulator etc seem fine so far, and cables/connections look sound. The battery is getting quite old though, so will replace it an see how I go.
The AC compressor is also not kicking in now (the clutch does not engage). Have not had much time to investigate, fuses look good, but the relays look original, so will test them and the cabling next.
Cheers Scott, yes I have pulled each fuse and had a look. Most are still original and connections are clean. Might be worth giving each a rub with rough dry scouring sponge.
Checked what I could on AC, still has the original relays, and both still working fine!! Confirmed power to both and both operate fine, and no resistance on the switching terminal when on, fuses are OK
Put power to the AC compressor clutch and works fine.
Had a look at the pressure switch you mentioned, one of the cables was just hanging there, but not connected. I’m guessing when the compressor was replaced (few years ago now) the cable was not supported correctly causing the cable to break. Managed to remove the cap on the switch and re-soldered the cable inside the cap. All running again!
Also bleed the brakes and clutch while I was checking over the van (brakes/bearings/CV’s etc).
