No Start!
I have a bit of a puzzle.  I have been running one of Hartmut’s distributors but had to send it back to him to get Peter out of trouble.
I installed my old distributor with a new Hall sender.  It will not fire, let alone start.  Spark is OK, tested on a plug while cranking, so I am at a loss to know why I now have no firing.
Any suggestions welcome!!
Maybe 180 degrees out?
Very easily done and when installed that way it doesn't sit in properly and doesn't turn.
On 5/07/2015 4:04 PM, 'Les Harris' leslieharris@optusnet.com.au [Syncro_T3_Australia] wrote:
Or the drive dog was fitted to the shaft 180 degrees out. I would go back to basics and get number 3 rocking and make sure the rocker arm is on the grove. Then make sure your leads are in the right spot. Greg E
Sent from Greg's iPhone
On 5 Jul 2015, at 6:36 pm, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
OK, everyone back to their own beds!!
I have just taken pole position in the Dopey GT for 2015.
To fit the Hall sender, I had to dismantle the distributor.  On reassembly, I had indeed assembled the dog drive 180 degrees out!
Dopey, dopey, dopey, dopey!!!!!!!!!!!
Sent: 06 July 2015 07:11
Subject: Re: [Syncro_T3_Australia] No Start!
Sent from Greg's
iPhone
at least you found the problem !
good work.
On 7/5/2015 3:15 PM, 'Les Harris' leslieharris@optusnet.com.au [Syncro_T3_Australia] wrote:
Sent from Greg's
iPhone
Scott,
The next problem to solve is intermittent cutting out.  It will either cut out completely (complete loss of a signal to the ECU) or cut out for a few seconds then resume running.  This can happen at any speed.  Since it was happening on the borrowed distributor and on the newly re-fitted original distributor with a new Hall sender, it is probably safe to say that it is not the Hall sender.
I will go through the Digifant manual to see which senders will shut down the ECU if they fail to send a signal.  The Hall sender is certainly one of them.
Sent: 07 July 2015 11:48
at least you found the problem !   good work.
AIR FLOW SENSOR can cause this. The carbon track gets worn. Old fix was to add capacitor across pins 2&3. If that doesn't work you have to move the wiper inside the sensor. This fault (and fix) well described on the USA syncro site.
Peter, you are a couple of days behind with the postings. As already posted, I caused the problem myself by assembling the drive dog on the distributor 180° out of phase. Old brains like mine experience fade from time to time!!
Sent: 08 July 2015 12:43
Subject: [Syncro_T3_Australia] Re: No Start!
thought you had 2 problems
Peter,
Yes indeed, and you were referring to the intermittent miss problem.  Sorry, my brain is now more online than it was when I answered your previous post.  Sorry.
Sent: 08 July 2015 16:07
Subject: RE: [Syncro_T3_Australia] Re: No Start!
