Hi All,
What's going on? No queries, call for help, or advice - for over a week.
So I will have a bitch on having spent quite a bit of money recently on the Syncro,
and ending up with oil & water leak. The pleasure of owning a Syncro.
Hi All,
Hi All,
Hi Theo, sad to hear on the leaks, hopefully they will fix it for you? Or at least be a simple fix.
If your stuck, I think Pete from Custom VW has experience with Subaru's also. (I have never used him, but know of him)
As far as the pleasure of owning a Syncro, mine is thankfully still going well, but have noticed a few changes recently in terms of being a little lethargic off idle, and different smell from the exhaust. So something is happening with the EFI system. Have been meaning to look into it for a while, but life gets in the way. Initial thoughts are the Temp sensor as all earth's were cleaned (and doubled up) when the engine was out last year, as were all the connectors in the whole system cleaned etc. I have not just replaced it as I want to take some measurements first to compare.
The changes are very subtle and hardly noticeable, has not affected economy, but I know something is changing!
On a side note, has anyone ever tried to fit a second radiator fan in front of the radiator? As we come into the hot weather and the AC is on more regular, the fan is on permanent with the AC. I was wondering if it's worth having a second fan, the extra only runs with the AC, the original is only there is the temperature rises too much. Just a curiosity.
Anyway, hope your Melb visit is going well.
Hi All,
On 14 Nov 2017, at 18:42, cathrich1@yahoo.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
---In Syncro_T3_Australia@yahoogroups.com, <teows@...> wrote :Hi All,
On Tue, 14 Nov 2017 at 6:42 PM, cathrich1@yahoo.com.au [Syncro_T3_Australia]<Syncro_T3_Australia@yahoogroups.com> wrote:Hi Theo, sad to hear on the leaks, hopefully they will fix it for you? Or at least be a simple fix.
On 14 Nov 2017, at 18:39, jacques greyling publo204@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi everyone
I’m new to this group. Proud owner of a T3 Syncro 1989After spending a small fortune on the gearbox recently it’s going so smooth I’m constantly looking for excuses to drive the scenic route of course.Sorry to hear some of you are experiencing troubles at the moment. That seems to be the joys of Syncro ownership.If anyone can help me with or point me in the correct direction for a LH front swivel seat base I’ll appreciate it very much.Recently I sourced a aluminium roof rack ladder from a old land cruiser which is going to be made fit on the RH side for access to my roof rack. Looking forward to that!Thanks everyoneCheersJacques Greyling0416107975@gmail
On 14 Nov 2017, at 18:42, cathrich1@yahoo.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Hi Theo, sad to hear on the leaks, hopefully they will fix it for you? Or at least be a simple fix.
Hi everyone
On 14 Nov 2017, at 19:58, Beau Sagadin beau.sagadin@yahoo.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hey mate.
Good on your syncro.I have a spare never used swivel base if interested, located Sunshine Coast QLD. Can ship but it’s pretty heavy.CheersBeauSent from my iPhone
On 14 Nov 2017, at 18:39, jacques greyling publo204@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Hi everyone
On 14 Nov 2017, at 20:49, Arne kleinersyncro@yahoo.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hey Jacques,Welcome to the group!Where about are you based?Cheers Arne
Am 14.11.2017 um 19:39 schrieb jacques greyling publo204@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>:Hi everyone
Hi Skot,
Thanks for the suggestion and picture. So, still more work to be done.
Thanks god that my problem is only superficial, oil filter & stainless steel pipe, but still annoying.
I don't want to crawl under the van any more.
Sent: Saturday, 11 November 2017 9:40 PM
Subject: Re: [Syncro_T3_Australia] [2 Attachments]
Theo,
Thats nasty.
I thought you got a real low km version?
I bought mine specifically because it had the head-gaskets done.
I had the new stainless exhaust wrapped before it got dirty to prevent it heating up the new gaskets and cooking them which apparently makes them leak.
Most syncro to suby swap 2.5's have an exhaust that sits a lot closer to the engine and hence causes heat damage more rapidly than in a Subaru car. A friend made heat shields and fitted them between the exhaust and the engine to help prevent this issue.
On 11/11/2017 9:19 PM, 'Theo Weiss' teows@melbpc.org.au [Syncro_T3_Australia] wrote:
Hi All,
Thanks for your concern ( see e-mail to Skot). When I have a minute, I will change the oil filter and check all the hose clamps again.
Sent: Tuesday, 14 November 2017 6:42 PM
Hi All,
On Tue, Nov 14, 2017 at 6:39 PM, jacques greyling publo204@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Hi everyone
On 14 Nov 2017, at 18:42, cathrich1@yahoo.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@ yahoogroups.com> wrote:Hi Theo, sad to hear on the leaks, hopefully they will fix it for you? Or at least be a simple fix.
---In Syncro_T3_Australia@ yahoogroups.com, <teows@...> wrote :Hi All,
How are the swivel bases different I have 3 of them so would have to check2 were fitted to the leftpeter 0754429307
Hi everyone
Thanks everyone
Hi All,
On 14 Nov 2017, at 22:18, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
I think the swivel bases are interchangeable.
Mine was definitely not sided and it is a factory VW/ Westfalia version.
Well worth the install and the added 25mm height increase to the seat too.
On 14/11/2017 10:08 PM, Peter Wilson peterw1000@gmail.com [Syncro_T3_Australia] wrote:
Hi everyone
Thanks everyone
Hi All,
Sounds like a discussion for when your up this way :)
Welcome aboard Jacques, if you have the gear box done, at least one of the biggest jobs is taken care of!
Do you have any more details on what yours is? (camper, van etc?)
They are a labour of love to keep on the road, that is for sure.
On 14 Nov 2017, at 18:42, cathrich1@... [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
On Wed, Nov 15, 2017 at 10:34 PM, m.mullet@yahoo.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Gday Pete,
you have one of those bases for sale ?
Might be a nice addition .. Van's going very well although heater fan died last year. That'll be a fun job.
On 14 Nov 2017, at 23:05, cathrich1@yahoo.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Welcome aboard Jacques, if you have the gear box done, at least one of the biggest jobs is taken care of!
---In Syncro_T3_Australia@yahoogroups.com, <publo204@...> wrote :Hi everyoneI’m new to this group. Proud owner of a T3 Syncro 1989After spending a small fortune on the gearbox recently it’s going so smooth I’m constantly looking for excuses to drive the scenic route of course.Sorry to hear some of you are experiencing troubles at the moment. That seems to be the joys of Syncro ownership.If anyone can help me with or point me in the correct direction for a LH front swivel seat base I’ll appreciate it very much.Recently I sourced a aluminium roof rack ladder from a old land cruiser which is going to be made fit on the RH side for access to my roof rack. Looking forward to that!Thanks everyoneCheersJacques Greyling0416107975@gmailOn 14 Nov 2017, at 18:42, cathrich1@... [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Hi Theo, sad to hear on the leaks, hopefully they will fix it for you? Or at least be a simple fix.
