Oil cooler
Hello all, I hope you all had a great Christmas. We are off on a trip around Tassie in nine days and I have just discovered my oil cooler needs replacing. The need to replace it has got me thinking aftermarket oil to air cooler? So my question is has anyone got one, if so from where and how many sheckels. If not has anyone bought a genuine cooler from a dealer recently? Any info appreciated. Greg E
Hi Greg - I bought oil an oil cooler for my mate's car from Tooleys less than a year ago, it cost well under a hundred bucks. When I tried to buy one for myself about six months ago they were out of stock so I got one from VanCafe, which cost about AU$80 plus freight.
  If the cooler springs a coolant leak, in an emergency you can just remove it and patch it with solder, or join the two hoses together to get you out of trouble. [The cooler is not essential except when the vehicle is working hard in hot weather - the early wasserboxers with the 1.9 motor didn't have them at all]. To remove the cooler altogether you would need to replace the threaded union that the oil filter screws on to with a shorter one, which is common to many vehicles and should be easy to find at Repco or a wreckers. Then you could simply screw the oil filter back on and toss the oil cooler over your left shoulder.
If you get stuck for a new cooler, I haven't used mine yet - you can use it and replace it later. I'm at Goulburn, just off the Hume Highway [on the way to Tassie]. Let me know.
Hi Roger , you are correct, the 1.9 didnt use a cooler for that size engine.....but a 2.1 needs a cooler,when we did factory exchange engines we often fitted 2.1 in place of the 1.9's but noticed oil consumption increased...all the oettinger 2.5's had an external cooler fitted with a thermo fan to reduce oil consumption under load...this is a more costly exercise compared to fitting a std cooler.Fitting an oil temp guage will tell a story too.....all the very best roger for the season too...catch up soon...ps there is a trip organised in July with a few buses to the simpson will keep you informed if your interested
Steve,
That is very valuable information.  It certainly indicates that it would be unwise to by-pass the existing cooler, particularly in summer conditions.
As a matter of interest, what form of cooler was fitted to the Oettinger and where was it located<
From: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] On Behalf Of stehenmullervw
Sent: 28 December 2010 09:22
Subject: [Syncro_T3_Australia] Re: Oil cooler
_._,___
G'day Steve - good to have you aboard.
  I should have stressed that it isn't advisable to remove the oil cooler except in an emergency [when it springs a leak], and then only temporarily. Without it the engine should not be worked too hard.
  The trip to the Simpson sounds like it might be a goer - let me know.
  I always thought that Toyota had a pretty lame claim to being the first vehicle to cross the Simpson the hard way - from east to west - when they couldn't have done it without the support of a Syncro to carry the fuel. Technically it must have come "second" because it was a few yards behind them all the way ...
  Did you ever put together that video about old Kombi adventures? I'd like to see that!
  All the best for the New Year, Roger.
Hi, Roger/Steve ,  maybe you can shed some light on the "fuel carrier Syncro" was that the Tristar DOKA  ? I believe it did the desert twice, but unfortunately I have very little info on that. I believe the Syncro carried 50 jerry cans for the others to make the trip.
Hartmut
Date: Mon, 27 Dec 2010 17:48:09 -0500
Subject: Re: [Syncro_T3_Australia] Re: Oil cooler
Hi Les, I have a complete installation which, years back, I had bought from Bernd Jaeger. I will do some photos and try and send them to you. All  the fittings , hoses to the front of the vehicle, oilcooler, switches etc all is there.
Hartmut
Date: Tue, 28 Dec 2010 09:38:22 +1100
Subject: RE: [Syncro_T3_Australia] Re: Oil cooler
Steve,
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of stehenmullervw
_._,___
Hartmut,
Ah, a front cooler location.  The cooler capacity plus the hoses would have added a useful volume. The greater the volume, the better the heat sink.  Did the original cooler stay in place?
You mention switches; what were they for?  I presume that the fan was controlled by a thermostatic switch, so I can’t think what switches might do.
If you have any problem with the pics, email them direct to me and I will post them for you.
Sent: 28 December 2010 10:08
To: wendyand brian
Hartmut
Sorry, no switches, just had a look, relais and stuff are for the intercooler. All this was for the TDI installation which hasn"t happened, as so many other projects in my life.
And no need to post the pics unless someone wants to have a look what the cooler looks like, because if I sell, I would like to sell the lot incl. engine (non computer) etc.
Hartmut
Date: Tue, 28 Dec 2010 10:21:56 +1100
Hartmut,
To: wendyand brian
Hartmut
Les, oil cooler location is important....all the modified T1's that I builkd use a front location and a 1980's merc cooler....but oil pump volume is critical as the relationship to hose lenght will drop pressure to a point that the oil warnimg buzzer will go off.....Oettinger suggested cutting out the panel behind lh tailight and fitting the air to oil and I suspect Harty has a similar kit to fit....Re the refuel ute I will dig out a few photos but am sure past copies from overlander showed the T3 in action. A worthwhile add to any syncro will be a oil temp guage for the engine and more importantly the gearbox which does overheat
> Hartmut,
> controlled by a thermostatic switch, so I can't think what switches might
> do.
> post them for you.
> To: wendyand brian
> there.
> Hartmut
Do you know or remember Ken Virgin , and Glen, his son ??
Very fascinating write up in VWMA issue 27
Hartmut
Hartmut,
To: wendyand brian
Hartmut
Excuse me for piggybacking on the oil cooler debate, but we are
driving up the Fume Highway and I have a query. We have had an
intermittent buzzing noise in the dash for a while which we are now
fairly certain is the speedo cable. My question: why does it happen
only after we have been driving along for a while at speed? Also, is
it tricky/costly to fix? Otherwise she is running nicely, although
given that it's school holidays I am heavily touching wood....
Francesca.
On 12/28/10, Hartmut Kiehn <hartis@live.com.au> wrote:
> Hartmut
> From: leslieharris@optusnet.com.au
> Hartmut,
> do.
> post them for you.
> To: wendyand brian
> there.
> Hartmut
Steve,
Ca you help Francesca with this one?
The only buzzer (i.e. a buzzer as distinct from a buzzing sound) is the oil pressure warning.
The speedo drive cable is a snap fit to the back of the speedo and is either engaged or not, so that doesn’t sound likely.
Any ideas?
Sent: 28 December 2010 11:57
Francesca.
Hartmut,
No, I don’t know them.  I will have a look at the VWMA
Sent: 28 December 2010 11:23
To: wendyand brian
Hartmut
If you are certain it is not the oil warning buzzer and it is the speedo cable proceed as follows. Unclip the instrument cover by pulling up on the forward (front of car) edge and pivot on rear edge untill released. Reach behind the speedo and push down the white plastic tongue on the speedo cable and pull it out. Hold the end up and pour in a couple of mls of engine oil or similar. Refit in reverse. That said it sounds like the dynamic oil pressure buzzer. I know you had Lloyd look at this a while back, I think you mentioned new switches? Do you have a genuine/Mann oil filter fitted? What grade of oil? I hope you have a great holiday and don't spend too much time keeping those three lads of yours in check. Greg E
Received: Tuesday, 28 December, 2010, 11:56 AM
Francesca.
> Hartmut
> Hartmut,
> do.
> post them for you.
> To: wendyand brian
> there.
> Hartmut
Yahoo! Groups Links
<*> Your email settings:
    (Yahoo! ID required)
The dynamic oil pressure buzzer only works over about 2000rpm. Maybe you are getting low oil pressure as the oil gets hot, so it only buzzes after driving for a while.
When it buzzes again, stop the car and let it idle, there should be no buzz. Rev the engine to about 3000 revs and see what happens.
If you have any problems near Sydney, I live near the M5 toll both.
> Hi all,
> Francesca.
> > Les
> > Hartmut
> > Hartmut,
> have
> sink.
> > controlled by a thermostatic switch, so I can���t think what switches
> might
> > do.
> will
> > post them for you.
> > Les
> Kiehn
> > To: wendyand brian
> from
> all is
> > there.
> > Hartmut
G'day Hart - I looked back through my files to find the write-up from "Overlander" magazine on the first east-west crossing of the Simpson desert by vehicle, which as I recall was sponsored by Toyota and hailed as a big deal at the time.
  I couldn't find it the article I was looking for, so maybe my memory is at fault - do others recall this event?
  I did find an article from October 1989 featuring an east-west crossing by two HJ60 Landcruisers, a red Tristar dual-cab [rego PPC 097] which carried 30 jerry-cans of fuel, and a white syncro camper [NSW rego POZ 217]. The expedition was organised by "Australian Outback 4 Wheel Drive Company" to test the capability of the VW's, which passed with flying colours. The only problem was a couple of spat fan belts which prompted the company to order belt-guards.
  If any one is interested, and the article has not already been scanned elsewhere, I could do so.
Cheers, Roger.
  Was that your Tristar Hart?
PPC 097 was Hart's Tri Star
> desert by
> deal at
> the time.
> is
> crossing
> carried
> to test
> order
> belt-guards.
> Cheers, Roger.
Thanks Phill,
I wasn't 100% sure but then again only one Tristar came to Oz and only one red one anyway.
Date: Tue, 28 Dec 2010 18:17:49 +1100
Subject: Re: Re: [Syncro_T3_Australia] Re: Oil cooler
> desert by
> deal at
> the time.
> is
> crossing
> carried
> to test
> order
> belt-guards.
> Cheers, Roger.
Sorry Rodger I forgot to reply to your post. I will be trying tooleys and the local dealer tomorrow if I just can't buy one in Melbourne I might take you up on your very generous offer. I get on the boat on the seventh so still some time to sort it out. I could patch it with some silver solder, but I don't want to have to strip it again when I get back. Any way I found a pic of the oil cooler adapter I was talking about. You can get these with an internal thermostat and fit it sans original cooler. Thanks again Greg
--- On Mon, 27/12/10, Gullyraker@aol.com <Gullyraker@aol.com> wrote:
Subject: Re: [Syncro_T3_Australia] Oil cooler
Received: Monday, 27 December, 2010, 11:46 PM
