100,000 kms. My rig had been suffering from `listlessness' and
occasional surging &/or hesitating.
I sourced a new (aftermarket) 3 wire sensor from Vintage Vee Dub who
got it from `Tooley Imports'. I think the original is made by
Bosch? Any one know?
Very easy to install by cutting off and reusing the existing plug
connectors. 2 wires are for the heater (non polarity dependant) and
the other goes to the ECU.
The difference in performance was considerable and I wish I had done
it earlier. It now runs better than ever with less throttle.
The O2 sensor senses the amount of O2 in the exhaust & sends a
voltage to the ECU which then adjusts the air/fuel mixture to the
optimal level. Too much O2 indicates lean mixture which can cause
performance problems including misfire. Too little O2 indicates rich
mixture which wastes fuel.
Maybe should be changed every 100,000kms??
