Hi
Nick and Roger and Forum Moderator,
Worrisome
that Rogers post arrived in my email account ok today but
the post Roger replied to from Nick has gone AWOL! I was
forced to go into the forum to find and read Nicks prior
post.
In
recent times, my forum posts experience has been similar
... receipt of forum posts to my email account has been
intermittent ... some arrive, some don't. Might partly
explain why the forum appears quiet? I've never changed my
email preferences in Yahoo syncro forum away from "receive
all posts to my email address". Go figure. Fixable?
Oil
Filler Cap part
# 070115311
Nick,
to avoid losing your oil cap, always make it your practice
to remove the cap, swing fully open the spring-loaded
access flap and wedge the cap in the space between the
flap hinges. Works a treat, fits nicely and hard to
forget. It would be difficult to think you could then
STILL drive away with the flap fully open AND with the oil
cap still wedged in. Yes?
Perhaps
first try Volkwerke or some other recognised Melbourne T3
service outlet for replacement oil filler cap.
Or
try your local VW service/parts centre.
Alternator
... supplementary support bracket
Every
T3 should have either one of these add-on bracket kits
installed, to avoid the catastrophe of the bolts holding
the original bracket from being ripped out of the engine
casing when the alternator starts shaking/pulling the
bolts out!
I
have the original version from many years ago, similar to
the first listed one above. Offers great peace of mind.
Silicone Coolant Hose Kit
I don't have the
complete set of silicone hoses installed, due to the
complete set being unavailable at the time. But I wish I
had. The only downside in my view is the removal/loss of
the original spring clips from the coolant system, maybe
they are too small for the thicker walled silicone
hoses. I've had no issues ever since with the silicone
hoses I have, I'm expecting they will serve the
remaining life of the van.
Overhauling
the complete coolant system is a pure labour of love,
definitely worth doing and doing well. You learn all about
patience, persistence and in due course, really appreciate
that journey you took doing it and reap the rewards ever
after.
I
also disagree with the populist brainwashing that's gone
on for so long about replacing the long nylon coolant
pipes with stainless steel. Just take the time and FIX the
nylon pipes in situ. I did. Learnt a lot in the process.
No problem ever since, it's been years. Funnily enough,
Rudi agrees with me.
and good luck with the overhaul.
Hi Nick
Your local auto electrician can overhaul the
alternator. The bearings wear out much quicker
than a front-engine vehicle if you drive on
dusty roads, so I carry a spare one on outback
trips.
Check out the file Ken put together on
radiator hoses. It's a beauty.
I just purchased a whole heap of hoses.
After exhausting the local suppliers, had to
source most of them overseas. Prices vary
enormously, so shop around and also compare the
freight costs.
It's possible to fabricate alternatives for
some of the hoses with judicious use of plumbing
or irrigation pipe angles and reducers.
Consider the use of stainless steel
"Christmas trees" and reservoirs to replace the
original plastic ones - or carry spares..
Although new plastic parts are available, they
are usually inferior.
Most of my problems over the last twenty
years have been due to coolant issues, so it is
worth replacing the entire system if you want
reliability in the middle of nowhere.
Roger.
