Hello All,
I thought it was appropriate to change the subject to make these easier to access in the archives. Attached pics are courtesy of "Oxroad" Jeff in Los Angeles. He bought these mudflaps from a former listmember called James Cohen who used to finance his Syncro habit by selling a few trinkets from VW of South Africa. This is going back nearly a decade. Just to recap, the part number is: 22S 821 833
Jeff, wanted me to point out that the rear mudflaps have this unique (to the SA flaps) extension shield which fits inside the back of the rear wheel wells. See 4th pic.
It looks to me that these are different from the mudflaps currently available from Europe or RSA. My memory was faulty as to how they attached to the body from I mentioned in my previous email.
Hoping that these attachments aren't to large for the forum. If so I can reduce the size and resend.
Regards,
On Sat, Nov 29, 2008 at 3:04 PM, Les Harris <leslieharris@optushome.com.au> wrote:
Martin's reply.----- Original Message -----From: "Martin Henning" <martin@easy2design.de>To: "Les Harris" <leslieharris@optushome.com.au>Sent: Sunday, November 30, 2008 9:59 AMSubject: Re: Mud Flaps SA.pdf> Les,
> the thing is: The SA microbusses where mostly fitted with plastic
> bumpers all around, which made it impossible to mount the standard-
> style mud flaps! They were intended for 2WD anyway, as there were only
> very few syncros over there. Up to date i have no hints, that the
> original US/EU/AU-style mudflaps have ever been officially available
> in SA. At least my SA-ETKA doesn't list them at all.
> .martinmartin@easy2design.de>
> On 29.11.2008, at 23:35, Les Harris wrote:
>> Martin,
>> We appear to be on different trams. The flaps shown in the ETKA
>> extract fit inside the wheel arches. The plastic things fit along
>> the edge of the wheel arch. The heavy moulded flaps fit to the body
>> well behind the wheel arches front and rear.
>> The attached pics show what we got in Australia. They are very
>> thick and the blades that run up the outside of the body are around
>> 30 mm thick.
>> As nominated by Phill, the following extract from ETKA shows the
>> mudflaps we got in Australia:
>> 251 821 809 mud flap with bracket left front
>> 251 821 810 mud flap with bracket right front
>> 900 691 01 threaded pin 5X30
>> 251 821 811 A mud flap with bracket left rear
>> 251 821 812 A mud flap with bracket right rear
>> As a matter of interest, the mounting plate for the original front
>> flap is thicker than the whole plastic flap.
>> Image 0226 is the thin plastic thing. It attached to the rim of the
>> wheel arch. Very low resolution pics, sorry.
>> Putting together the information that has come in, it would appear
>> that the plastic things have become the replacement for the heavy
>> moulded rubber, which was original fitment. This probably happened
>> at the point where production of the T3 ended. All of which is a
>> bit sad to think that VAG would drop the original and replace it
>> with a thin plastic moulding.
>> Les
>> To: "Les Harris" <leslieharris@optushome.com.au>martin@easy2design.de
>> Sent: Sunday, November 30, 2008 8:13 AM
> Martin Henning, DM5OY
> http://log.tigerbus.de
