Power Steering parts
Starting to collect what I can. Can anyone help?
Hi Mark,
Do they need to be parts off a syncro with power steering? (remember all telstra syncros were ordered with power steering).
There are always a few 2wd Caravelle GL's getting wrecked/ parted out so someone may have a set.
I am not sure if Syncro PS is any different. Probably not.
I’d prefer to go factory hydraulic. Did look at electric, but I think not.
On Fri, 5 Jul 2019 at 9:19 pm, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Mark,
Mark Fisher- CEO
Australia
Swift Performance Equipment
Unit 2, 1472 Boundary Road, Wacol, 4076
Queensland, Australia
Postal: PO Box 2054, New Farm, 4005
Office: +61 7 3879 3005
USA
Swift Performance LLC
3388a Commercial Ave. Northbrook IL, 60062 USA
Office: +1 224 501 9001
Also I think I saw someone with a high torque starter for a Syncro.
Might be interested in that.
I’m rebuilding engine to DJ specs with mild CB Performanc cam and Megasquirt
Fuel injection.
On Fri, 5 Jul 2019 at 9:33 pm, Mark Fisher <mark@swiftperformance.com> wrote:
Hi Mark,
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Power steer for 2WD and 4WD is identical apart from the Intermediate Shaft:
On 05/07/2019 21:03, Mark Fisher mark@spe.com.au [Syncro_T3_Australia] wrote:
I am not sure if Syncro PS is any different. Probably not.??
I???d prefer to go factory hydraulic. Did look at electric, but I think not.
Hi Mark,
Mark Fisher- CEO
Australia
Unit 2, 1472 Boundary Road, Wacol,??4076??
USA
3388a Commercial Ave.??Northbrook IL, 60062??USA
Than you. Just have to find one now.
On Fri, 5 Jul 2019 at 9:45 pm, 'busman.syncro' busman.syncro@yahoo.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Mark,
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
I've done this upgrade to my syncro.
Are you referring to a syncro with no PS?
Engine type?
On Fri, 5 Jul. 2019, 9:19 pm Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Mark,
Hi Peter,
Its 1992 (yes 92 according to its plate) Syncro with MV motor (soon to be DJ).
Are on Sunny coast somewhere? Did I buy some sliding windows from you?
On Sat, 6 Jul 2019 at 07:28, Peter Bellamy wanderingstar911@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Engine type?
Hi Mark,
Mark Fisher- CEO
Australia
USA
I will keep an eye out for you.
Where are you located?
Just Kampers has a syncro specific hi-torque starter.
On 5/07/2019 10:19 pm, Mark Fisher mark@spe.com.au [Syncro_T3_Australia] wrote:
Hi Mark,
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Hi Scott,
Im in Brisbane. Many thanks.
Syncro is in Casino NSW at my Mums place (big shed)
Full paint job happening son (and Im not doing it)
The plan is not to build a camper with cupboards etc. I just want a lightweight SYncro, with difflocks
On Sat, 6 Jul 2019 at 09:23, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Mark,
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Sounds like a great plan.
On 6/07/2019 9:36 am, Mark Fisher mark@spe.com.au [Syncro_T3_Australia] wrote:
Hi Scott,
Hi Mark,
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Thanks Scott. Looking forward to catching up one day
On Sat, 6 Jul 2019 at 09:58, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Scott,
Hi Mark,
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Yep, on the sunshine coast.
Where are you?
Sliding windows? Not sure?
The upgrade is reasonably achievable, I use rubber hydraulic hose to feed the rack from the pump. And plain rubber oil circulation hose for the return line. I put an oil cooler and filter on the return line.
The fiddly part was altering the intermediate steering shaft from right angle box to rack.
The non PS shaft is too long, so I cut mine and joined it with a solid shaft, rolled pins, and then welded it.
You need the S.S universal which replaces the rubber flex coupling.
I reconditioned the rack before installing it.
Wheel alignment when complete.
Don't know about idle rpm for stock engine, mine is a Subaru 2.2 and it handles the PS at idle. Some engines pickup the rpm at idle when PS pressure goes up; when you turn the steering wheel at idle.
Probably left out a few bits in this description.
On Sat, 6 Jul. 2019, 7:34 am Mark Fisher mark@spe.com.au [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Peter,
Engine type?
Hi Mark,
Mark Fisher- CEO
Australia
USA
Thanks Peter,
I picked up the windows late onme afternoon. If your Syncro is in the shed, and painted blue, you will be the Peter I met
Yep right, I remember
Are you proceeding with the power steering modifications?
On Thu, 11 Jul. 2019, 6:24 pm mark@spe.com.au [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Thanks Peter,
Sure am
On Thu, 11 Jul 2019 at 6:45 pm, Peter Bellamy wanderingstar911@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Thanks Peter,
Mark Fisher- CEO
Australia
USA
Sing out if you need help
On Thu, 11 Jul. 2019, 6:56 pm Mark Fisher mark@spe.com.au [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Sure am
On Thu, 11 Jul.. 2019, 6:24 pm mark@spe.com.au [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Thanks Peter,
Mark Fisher- CEO
Australia
USA
Will do Peter. Much appreciated.
On Thu, 11 Jul 2019 at 9:14 pm, Peter Bellamy wanderingstar911@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Sure am
On Thu, 11 Jul... 2019, 6:24 pm mark@spe.com.au [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Thanks Peter,
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Hey Pete,
What instruments did you put in your Blue Syncro? I remeber spying them.
Sure am
Thanks Peter,
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
I used a pair of Speedhut gauges. My reason initially was to get a GPS speedo to overcome the 16" diameter wheels which were 14". The GPS is 100% accurate and comes with a whole bunch of features like a compass in the odometer display slot. The wiring is easy too. Only issue I have had is the other gauge which is a speedhut 4x gauge cluster. The oil pressure on this was a saga, another story. Check it out their website.
On Mon, 15 Jul. 2019, 4:29 pm Mark Fisher mark@spe.com.au [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Hey Pete,
Sure am
On Thu, 11 Jul.... 2019, 6:24 pm mark@spe.com.au [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Thanks Peter,
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
Mark Fisher- CEO
Australia
USA
