prestige A/C update
No compressor mounts??? Don,t get caught with Prestige stuff, try and find original mounts at 1/2 the weight and twice the strenght. Got mine from benT,
$ 100 plus us shipping , some 6 years back.
Sent from my iPad
On 9 Nov 2016, at 8:20 PM, richo1166@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
I have a Prestige ac also however no compressor or mounts?  pipes run to the engine and everything else appears to be there but no compressor. So if someone has a good one lying around  i could be interested in removing it from you.. ��
I have a compressor but no mount.
You can probably get a good factory mount from theSamba.com.
They are loads better than the Prestige ones.
On 9/11/2016 8:20 PM, richo1166@gmail.com [Syncro_T3_Australia] wrote:
I have a Prestige ac also however no compressor or mounts? pipes run to the engine and everything else appears to be there but no compressor. So if someone has a good one lying around i could be interested in removing it from you.. 😊
So what is a Prestige system? Is that a brand/installer?
I like your idea on the mount Hart, I have a very heavy steel fabricated one on the Syncro, but a factory one on my 2WD. Factory looks so much nicer.
Might be something I keep my eye out for!
Richo, if you need a compressor, I'd be considering new over second hand. Anything original would be at or past the end of it's useful life. I replaced mine just over a year ago as the system kept leaking gas. It was from the seals in the compressor.
Sent from my iPad
On 9 Nov 2016, at 8:20 PM, richo1166@... [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
I've got a "Daewoo" compressor on my spare engine. If anybody wants it, can be done for a six pack. :)
Hi Beau,
More than happy to share info.
I currently have the motor out of mine as I am about to undertake the conversion to a Ford zetec motor. Which will take some time.
But you can call to discuss 0448690696.
PK
1989 Syncro
1991 Single cab
1985 Double cab
2016 Double cab 4motion
On 9 Nov 2016 2:23 PM, "beau.sagadin@yahoo.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Peter.
I'm in the same position. Trying to upgrade prestige A/C and make my syncro ready for QLD humidity. I'm in Sunshine Coast.
Would you be able to share more info on your setup?
Thanks in advance
Beau
