Hi Skot,
my suspension shop guy sourced them, made by an Aussie mob (
name escapes me ). Specifically for T3 with an indent to accommodate the
bump
stop.
Can get you more details if you want.
--- In mailto:Syncro_T3_Australia%40yahoogroups.com,
Scott Pitcher <spbconsulting@...> wrote:
> Mark,
> Where did you get them?
> Doesn't the bump stop get in
the way?
> Thanks,
> Skot
> On 23/11/2011 5:02 PM, mark wrote:
> I run air bags inside the back coils. Great for long trips when I
have
> > a spare and 40l of fuel and a bike hanging off the back of
the
> > syncro. Keeps it level and keeps it handling well on those
skanky old
> > outback tracks..
> > Mark
> --- In
href="mailto:Syncro_T3_Australia%40yahoogroups.com">mailto:Syncro_T3_Australia%40yahoogroups.com
> <mailto:Syncro_T3_Australia%40yahoogroups.com>, Gullyraker@
wrote:
> > > I fitted a pair of Gabriel pump-up
shocks to the back of my old
> > splittie
> > > years ago.
I was carrying a trials bike on a swing out rack on the
> > back,
and
> > > nearly a ton inside. They raised the sagging rear end, but
busted a
> > > shock-absorber mount on a corrugated road in outback
Queensland.
> > > Moral; never expect a
shock-absorber mount to carry a load it wasn't
> > > designed
for.
> > > I used them more succesfully on a 1973
T2, which had stronger mounts,
> > > minus the bike.
> > > They worked really well on the Country Buggy, which went
further than
> > > heavy four-wheel-drives in the West Australian
desert. Gave it a
> > boost in
> > > ground
clearance.
> > > One important lesson was to
replace the single air valve and "T" piece
> > > with individual
valves, otherwise on a long sweeping bend the air
> > would be
> > forced from the outside shocker to the inside one via the shared
air
> > hose,
> > > increasing body lean. This could have
serious results - especially on a
> > > swing-axled kombi or country
buggy!
> > > The air pressure was a real pain to
equalise with individual valves,
> > but
> > > it didn't
hurt as much as landing on your head.
Something to keep in mind; raising the rear of the vehicle will change
> > the steering and handling characteristics for the worse.
> > > Another option when carrying heavy loads is to fit
air-bags inside the
> > > coils. These will not increase unladen
ride height, but it will
> > reduce sagging
> > > under
heavy loads.
> > > I've never used them but a mate
has a set on the rear of his Landrover
> > > Defender. They've been
there since 1994, have covered half a million
> > k's, and
> he swears by them. The only downside is that they inhibit
suspension
> > > compression in extreme four-wheel driving, which is
not something
> > you normally do
> > > with 1.3 tonnes
aboard.
> > > Hope these thoughts are of some
help.
> > > Roger
> > > [Beetle].
