R&R Starter motor
Gday ALL,
Having starter motor trouble at the moment, could be bad connections
causing it and/or trouble in the motor itself. I don't think it's the
battery. I'm undecided whether to just take it to the mechanic/auto
electrician and say "fix it" or have a go at removing it myself, then
give it to the auto electrician to check. That way I can clean out
all the crud in the vicinity and check/clean/lubricate the electrical
connections and grounding while the starter is out.
Trouble is space seems so tight to get at it and I can't even see
both fixing bolts/nuts, let alone everything else that has to be
shifted or dismantled to get it out. I've read up what little there
is on the subject in Bentley's but at the moment it still looks a
pretty daunting task.
Has anyone done this and maybe has some helpful thoughts on this
please. To be realistic, should I even attempt this? If so, are there
special tools needed to get at the "hidden" fixings? Does the axle
shaft have to be removed at both ends and are there re-assembly
issues with this? Or would it be more prudent to simply take it to
the experts to fix? Any thoughts would be appreciated. TIA. Cheers.
Hi Ken
Double check the battery status & earthing connection under the
seat. Also the keyswitch has been known to cause problems.
Working on the starter is a pain witout first lowering the tranny.
Details for that can be found at the USA syncro site:
http://autos.groups.yahoo.com/group/Syncro/files/technica/Transmissio
n/
--- In Syncro_T3_Australia@yahoogroups.com, "Ken" <unclekenz@...>
wrote:
> Gday ALL,
connections
the
mechanic/auto
then
electrical
there
there
I think that the usual workshop procedure is to remove the diff lock mechanism then remove the starter, but dropping the gearbox would give good access.  Most starter motor problems come down to the solenoid not pulling in because of a poor current path.
Sent: Friday, June 16, 2006 12:28 AM
Subject: [Syncro_T3_Australia] R&R Starter motor
Gday ALL,
all the crud in the vicinity and check/clean/ lubricate the electrical
Gday Peter,
Everything else works as normal electrically. I've hooked up an extra
battery to the syncro battery but makes no difference. The Syncro
clutch-starts easily enough. So I think it's still a degraded connection
somewhere in the starter circuitry or the starter is having a heart
attack, which brings me back to where I started. What Les says about the
solenoid makes sense.
Lower the tranny eh. Bentleys doesn't mention that, but does suggest
removing the drive axle.
Oh well, looks like I better sleep on this. Maybe I can just always park
at the top of a hill .. lol. Thanks all. Cheers.
--- In Syncro_T3_Australia@yahoogroups.com, "Peter" <kestel.p@...>
wrote:
> Hi Ken
> n/
> Regards
> Peter
> --- In Syncro_T3_Australia@yahoogroups.com, "Ken" unclekenz@
> wrote:
> > Gday ALL,
> connections
> mechanic/auto
> then
> electrical
> there
> there
Gday all,
Can anyone tell me how to tackle removing the rear fastener (bolt?) of
the starter motor please. Is it an allen head bolt and you have to
juggle an allen key up behind the starter motor from under the van or
is it accessible from the engine bay after removing things like the air
filter assembly etc? Or is this all wrong? Special tools needed?
Any help appreciated. TIA. Cheers
> Gday all,
of
air
Hi Ken,
what ´kind of engine? A 2.1 or 1,9 waterboxer?
You have to unscrew the screws from the front gearbox-fastener and then
drop the gear some inches, that you can reach the starter!
Nevertheless you have to remove the air-filter and all other thins to
reach the upper screw where the starter is fixed...
No special tools needed!
Hope this might help you?
Gday Dirk,
Thanks for that. Yes it's a standard 2.1 WBX.
From what I've read in my VAG workshop manual and Bentleys, both fail to
describe a number of steps involved with the removal of the starter
motor. Are they expecting assumed knowledge for this? I'm perplexed as
to why they cover some but not all of the procedures to carry out this
task.
I'd be interested to know if someone out there has typed up a "Step by
Step Procedure for the Compleat Idiot" for the removal of the Syncro
starter motor. By way of example, John Muir's publication by that name
for Beetle and Kombi air-cooled's is a godsend ... a grand shame he
passed away.
Any clues as to the existence of such a typed up procedure please
anyone? TIA. Cheers.
--- In Syncro_T3_Australia@yahoogroups.com, "syncro_experts" <dirk@...>
wrote:
> --- In Syncro_T3_Australia@yahoogroups.com, "Ken" unclekenz@ wrote:
> > Gday all,
> of
or
> air
> Hi Ken,
then
Have you looked at page 27.13a and 27.13b of the Bentley?
It gives a step by step procedure.
> Gday Dirk,
> task.
> passed away.
> > > Gday all,
> > of
> or
> > air
> > > Ken
> > Hi Ken,
> > what �kind of engine? A 2.1 or 1,9 waterboxer?
> then
Gday Phil,
That's what I've been looking at all along and am still stumped, hence
the pleas for help.
The first part refers to removal of the top fixing bolt of the starter
motor. I can't even see the top bolt, let alone remove it. That's why I
asked for clues about where I need to go to access it to remove it.
Others members have said something about getting the top bolt out from
the engine bay. Not sure about this and Bentleys doesn't say, so I was
wanting more info and confirmation if it is the case.
Other members have said the transmission needs to be lowered to get the
starter motor out. Not mentioned in Bentleys. True?
At the moment I'm also unclear on swinging to one side the coolant
hoses. I'm thinking that's not possible, rather, the hoses need to be
removed to get working clearance. I'll take yet another look to try and
resolve this point. I'm not quite ready yet to concurrantly address the
issue of draining/refilling the coolant system.
So Phil, I take it you've removed the starter motor at some stage. Then
you may be in a position to clarify for me some of these queries ......
thanks Phil. Cheers
> > Ken unclekenz@... wrote:
> > Gday Dirk,
fail to
as
this
> > task.
by
name
> > passed away.
> > --- In Syncro_T3_Australia@yahoogroups.com, "syncro_experts" dirk@
wrote:
> > > > Gday all,
(bolt?)
> > > of
to
van
> > or
the
> > > air
> > > > Ken
> > > Hi Ken,
> > then
to
No I haven't removed a starter before on a syncro, but it should be the same as any Kombi/Beetle.
The top bolt is probably the same one that bolts the engine to the gearbox.
It will be a 17mm head,
> Gday Phil,
> the pleas for help.
> thanks Phil. Cheers
> > > Gday Dirk,
> fail to
> as
> this
> > > task.
> by
> name
> > > passed away.
> > > Ken
> wrote:
> > > > > Gday all,
> (bolt?)
> > > > of
> to
> van
> > > or
> > > > air
> > > > > Ken
> > > > Hi Ken,
> > > then
> to
SOme things are not meant to be easy. You might be able to work on
the starter without lowering the tranny & I could imagine that with
fancy multi-axial ring spanners (at $35 each) and long thin fingers
you might get there.
Personally I would allocate a few days & give myself the room to do
the job easily by lowering the tranny first. Sure it is a lot more
work however in the long run...
I have learnt first hand that the Syncro does not give up easily.
PK
gearbox.
> > Ken <unclekenz@...> wrote:
> > Gday Phil,
hence
> > the pleas for help.
starter
That's why I
it.
out from
I was
get the
coolant
to be
try and
address the
stage. Then
queries ......
> > thanks Phil. Cheers
> > > > Ken unclekenz@ wrote:
> > > > Gday Dirk,
both
> > fail to
starter
perplexed
> > as
carry out
> > this
> > > > task.
a "Step
> > by
the Syncro
that
> > name
shame he
> > > > passed away.
please
> > > > Ken
dirk@
unclekenz@
> > wrote:
> > > > > > Gday all,
fastener
> > (bolt?)
> > > > > of
you have
> > to
under the
> > van
> > > > or
things like
> > the
> > > > > air
needed?
> > > > > > Ken
> > > > > Hi Ken,
fastener and
> > > > then
other thins
> > to
Peter ... today the auto electrician confirmed the brushes are sticking,
he did the tap tap tap on the starter motor and then voila! ... it
started. So at least I know it's not a crook switch, or bad
connection/wiring. Bite the bullet time? Cheers
wrote:
> Regards
> PK
> gearbox.
> > > Gday Phil,
> hence
> > > the pleas for help.
> starter
> That's why I
> it.
> out from
> I was
> get the
> coolant
> to be
> try and
> address the
> stage. Then
> queries ......
> > > thanks Phil. Cheers
> > > Ken
> > > > > Gday Dirk,
> both
> > > fail to
> starter
> perplexed
> > > as
> carry out
> > > this
> > > > > task.
> a "Step
> > > by
> the Syncro
> that
> > > name
> shame he
> > > > > passed away.
> please
> > > > > Ken
> dirk@
> unclekenz@
> > > wrote:
> > > > > > > Gday all,
> fastener
> > > (bolt?)
> > > > > > of
> you have
> > > to
> under the
> > > van
> > > > > or
> things like
> > > the
> > > > > > air
> needed?
> > > > > > > Ken
> > > > > > Hi Ken,
> fastener and
> > > > > then
> other thins
> > > to
wrote:
> Regards
> PK
> gearbox.
> > > Gday Phil,
> hence
> > > the pleas for help.
> starter
> That's why I
> it.
> out from
> I was
> get the
> coolant
> to be
> try and
> address the
> stage. Then
> queries ......
> > > thanks Phil. Cheers
> > > Ken
> > > > > Gday Dirk,
> both
> > > fail to
> starter
> perplexed
> > > as
> carry out
> > > this
> > > > > task.
> a "Step
> > > by
> the Syncro
> that
> > > name
> shame he
> > > > > passed away.
> please
> > > > > Ken
> dirk@
> unclekenz@
> > > wrote:
> > > > > > > Gday all,
> fastener
> > > (bolt?)
> > > > > > of
> you have
> > > to
> under the
> > > van
> > > > > or
> things like
> > > the
> > > > > > air
> needed?
> > > > > > > Ken
> > > > > > Hi Ken,
> fastener and
> > > > > then
> other thins
> > > to
Well as Bill Clinton once said (erm, he lied) .... "READ MY LIPS!" I
can now tell you all it's official ......
..... to remove a syncro starter motor, there is NO need to lower the
transmission NOR remove the axle shaft.
Tomorrow I'm taking it to the auto electrician for a good seeing to.
Ken F.Q.S.S.M.R.
sticking,
> --- In Syncro_T3_Australia@yahoogroups.com, "Peter" kestel.p@
> wrote:
> > Regards
> > PK
> > gearbox.
> > > > Gday Phil,
> > hence
> > > > the pleas for help.
> > starter
> > That's why I
> > it.
> > out from
> > I was
> > get the
> > coolant
> > to be
> > try and
> > address the
> > stage. Then
> > queries ......
> > > > thanks Phil. Cheers
> > > > Ken
> > > > > > Gday Dirk,
> > both
> > > > fail to
> > starter
> > perplexed
> > > > as
> > carry out
> > > > this
> > > > > > task.
> > a "Step
> > > > by
> > the Syncro
> > that
> > > > name
> > shame he
> > > > > > passed away.
> > please
> > > > > > Ken
> > dirk@
> > unclekenz@
> > > > wrote:
> > > > > > > > Gday all,
> > fastener
> > > > (bolt?)
> > > > > > > of
> > you have
> > > > to
> > under the
> > > > van
> > > > > > or
> > things like
> > > > the
> > > > > > > air
> > needed?
> > > > > > > > Ken
> > > > > > > Hi Ken,
> > fastener and
> > > > > > then
> > other thins
> > > > to
Just to set the record straight here, the quote "read my lips" cannot
be attributed to Bill Clinton. In fact it was the first President
Bush's campaign promise not to raise taxes that is the origin of this
quote. You are right that he lied as he found himself forced to raise
taxes to help pay for the HUGE deficits run up by Ronald reagan.
Yes I wondered if I'd get picked up on this straight after I posted it.
Nice to put history to right.
Heh and I believe they STILL have HUGE deficits!
--- In Syncro_T3_Australia@yahoogroups.com, Alexander Sfakianos
