Ken, removing the pulley just gives you a bit of room to
work with & gives you a good view of what you are doing- properly aligning
things & making sure you have properly sealed all hoses and gaskets.Sure
the woodruff key is a pain when reinstalling the pulley ,but this pain is
nothing compared to th pain you'll feel if you finish the job only to find
leaks in your work-I've made that mistake-but only once.Just one other bit of
advice, if you are using hose clamps , try to position them so you can easily
retighten them later. Good luck with your repair.Eddie.
--- In
Syncro_T3_Australia@yahoogroups.com,
Ken Garratt <unclekenz@...> wrote:
Eddie,
> Yes I've already mastered expanding and holding the
distance between the main drive pulley and tinware to easily fit a 30mm socket
and driver onto the drive pulley bolt. Made up an expanding bizzo to do that
... works pretty good. In the back of the drive pulley are 2 holes on opposing
sides, they accept the special VW tool that locks fast the drive pulley fast
so the pulley bolt can be removed/installed. I found that instead, depending
upon whether you are taking the bolt in or out, select the appropriate hole
and insert a long socket through the hole ... think its around 14-16mm size
(can't remember). Shift the pulley around until it jambs the socket against
the engine casing, just as the special tool does. Then you can loosen/tighten
the pulley bolt. I must say though I've chickened out so far on removing the
pulley. Also someone here recently said they had a deal of trouble refitting
the pulley, in particular due to the difficulty re-aligning the woodruff
key.
> Any other hints you have please doing
the water pump R&R? Tools? etc etc. Thanks a lot.
> To:
Syncro_T3_Australia@yahoogroups.com>
> Date: Wed, 1 Dec 2010 07:46:43 +0000
Subject: [Syncro_T3_Australia] Re: R&R water pump
> Hi Ken ,Ive done that R&R
about 5 times.4 with crank pulley in & 1 with it out. The job is EASY with
it out, so if you can, get it out.
> I can force the tinware back far
enough to get a socket onto the pulley bolt.Cheers, Eddie.
> --- In
Ken Garratt <unclekenz@> wrote:
All,
> > Looks like it's
finally happened to me too ..... and out of the blue, for no particular reason
other than I'm guessing ... its old age. It may well be the original pump, if
so, then it's done 202,000klms.
> > I recently noticed a coolant leak and traced it as coming from
the drain hole on the water pump housing, so I assume the internal seal on the
water pump shaft has finally spat the dummy ... nicely timed for pre Xmas
break/businesses closures/Batemans Bay Tour prepping.
> > I've been boning up on past posts and links,
hopefully to find enough courage to attempt this R&R insitu procedure. I
agree, doing this sort of project, the first time is always the
hardest.
> > However I am
still unclear on how far one has to go with dismantling surrounding components
so as to enable enough clearance to allow the water pump to be shifted
rearwards on the threaded studs so as to clear everything for removal. Anyone
know please, with some clarity?
> > For example, it seems to be accepted that the main drive pulley
doesn't require removal. Assuming that is the case, how does one then deal
with the metal coolant pipe bolted to the RHS of the water pump housing and
running horizontally across behind and toward the bottom of the main drive
pulley? Does this pipe, once unbolted from the water pump, have to be
physically removed altogether for clearance reasons or can it simply be angled
up or down to clear for the water pump housing removal? It'd be nice if it
didn't require removal but someone may say otherwise?
> > Some say remove the tinware ... yes or no or
just loosen it to offer some better access for tools to bolts, clamps, screws
etc if needed or is it really unnecessary ... just leave the tinware as
is.
> > Some say remove the
complete distributor for necessary better access for tools etc .... yes or no?
Or just remove the distributor cap and rotor or leave as is?
> > Any other critical procedure and/or
component issue I need to know about?
> > Any help, hints and tips for a successful water pump changeover
would be welcome. TIA.
