radiator size
hi guys just a queary about rad dimentions iv measured mine at 50mm thick but all the ones i can see 4 sale are 30 mm thick.also when i looked on go westy site no sizes given but part numbers same as the 2wd t25 can anyone help as i need a new rad
Try Tooleys as they told me last year they were getting some early this year.
BenC
--- In Syncro_T3_Australia@yahoogroups.com, "russellcotton25" <rcotton@...> wrote:
Let us know how you go as I am interested in one of these or a larger version if that exists.
CC NSW
Sent: Friday, April 29, 2011 5:01 PM
Subject: [Syncro_T3_Australia] Re: radiator size
BenC
I think that the Australian square headlight syncros had the largest available radiator.
> Skot
> CC NSW
> From: Ben
> this year.
> BenC
Was under the van today, the core on mine is 50mm. Also has same part number as the gowesty one stamped on the lower rib. Mine is mid '92. You could pull it out and get a copy made with aluminium tanks. Greg E
Sent: Fri, 29 April, 2011 4:13:21 PM
Subject: [Syncro_T3_Australia] radiator size
There are two radiators for syncros.
Australian syncros should have 068 121 253E
The smaller one is 025 121 253A
> number as
> pull it out
> From: russellcotton25 <rcotton@kleenheat.com.au>
> thick but
> westy
> as i
> need a new rad
