My Radiator is starting to leak.
Mick Motors has one of these..
https://www.mickmotors.com.au/product-radiator-t3-1-92-1-84-50mm-wide-14564.aspx
Are they OK for the syncro
For background research, use the search function on this forum, type in “068 121 253E” and/or “radiator”. Don’t know about the “D” designated one from Mick Motors.
Just be careful to avoid any radiator that’s only 30mm core thickness.
The genuine original VAG OEM radiator I found is definitely superior in quality of construction/durability to the present offerings. Consider whether your present leaky one is re-usable after an inspection, proper flush,repair and pressure test by a qualified radiator repairer.
