Re: de coupler
I'm confused. If you all have operational VC's and not solid shaft then why in hell do you want to fit a decoupler. Did'nt VW drop the production of decouplers when they chose to go down the VC route? Can a decoupler be fitted to a non diff lock syncro?
Michael
See what's on at the movies in your area. Find out now.
Because the VC system is not 100% perfect design. (It is very close) It locks up when you don't want it to. eg roundabouts.
NO!!!!!!!!!
Yes, it is a seperate issue.
Michael
For me, the decoupler is good for two things.
1) temporarily disconnecting the front drive when you are unable to find a suitable spare tyre
2) keeping the VC offline when i need 2wd.
Micheal,I want to fit a decoupler so I can keep my vc operational as long as possible,I drive around city and highway(11 months of year)without driveshaft,so a decoupler will eliminate me climbing underneath when mates call up for a day off-road.
Because of the vcs design it does transmit torque to front wheels sometimes when it is not needed(parking,roundabouts,highway),and this will affect the normal duty cycle of your vc.
--- In Syncro_T3_Australia@yahoogroups.com, Michael Rayner <mrayner51@...> wrote:
> Regards
> Michael
> __________________________________________________________________________________
> See what's on at the movies in your area. Find out now: http://au.movies.yahoo.com/session-times/
Good luck with draining your piggy banks to purchase decouplers. I think you'll find Syncro Services is the slightly cheaper source, even allowing for the high Aussie dollar vs the Greenback, and shipping rates from Europe may well be cheaper too.
Francesca.
> Regards
> Michael
Ben, and .....
3) keeping the solid shaft offline when i need 2wd.
Sent: Wednesday, 16 December 2009 8:10 AM
Subject: Re: [Syncro_T3_Australia] Re: de coupler
Michael
According to the currency traders who share my office the Aussie dollar is not likely to rise from here so now is the time to buy (It is now steadily falling against the US from its peak about 3 weeks ago). Any sign of a US recovery and it will start to fall more rapidly.
Gary
[2 0 / 2 1 Design]
28 Gwynne St
Richmond
Vic 3121
gary@twentytwentyone.net
www.twentytwentyone.net
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
Francesca.
Because of the vcs design it does transmit torque to front wheels sometimes when it is not needed(parking, roundabouts, highway), and this will affect the normal duty cycle of your vc.
--- In Syncro_T3_Australia @yahoogroups. com, Michael Rayner <mrayner51@.. .> wrote:
> Regards
> Michael
> See what's on at the movies in your area. Find out now: http://au.movies. yahoo.com/ session-times/
Message
Decoupler:
Syncro Services website and their current advertised price = 654,11 € plus freight.
Including vacuum hoses, switch, bulb, ready to be mounted with mounting drawing! Built according to original VW-specifications, not a cheap rebuild. Hundreds of them are successfully in use and You won´t find this quality better priced.
Deposit for housing! (please don´t remove anything from the cone housing, as we need it back completely). We´ll wire the money back immediately after receiving your cone housing or you send us the housing advance, then no deposit applies.
Ralph
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Gary Cookson
Sent: Wednesday, 16 December 2009 11:15 a.m.
Gary
[2 0 / 2 1 Design]
28 Gwynne St
Richmond
Vic 3121
gary@twentytwentyon e.net
www.twentytwentyone .net
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
Francesca.
> Regards
> Michael
After buying a decoupler from Henning at syncro services I was asked if the decoupler was built to original SDP spec. Wasn't too fussed personally but I emailed Henning in regards to their design and was told the decouplers are built to original spec with the exception that they contain thicker tooth wheels and as such are stronger than the original.
Date: Wed, 16 Dec 2009 11:48:53 +1300
Subject: RE: [Syncro_T3_Australia] Re: de coupler
Decoupler:
Ralph
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of Gary Cookson
Subject: Re: [Syncro_T3_Australi a] Re: de coupler
Gary
[2 0 / 2 1 Design]
28 Gwynne St
Richmond
Vic 3121
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
Francesca.
> Regards
> Michael
Check out the latest features today Get more out of Hotmail
Miichael,I too dont get the whole de coupler thing . My van is currently running a 2wd gbox while rhe rebiult syncro box awaits its owner to install it.I feel it drives like a lightweight japanese van & not like the rock solid feel Im used to.In the 16 years of syncro ownership I have never been left stranded due to lack of grip on snowy roads or slippery, muddy fire trails and mine doesnt have diff locks.For me it seems the perfect balance for on & off road.
> Regards
> Michael
Fools rush in….  I am going to stop answering this question one day…..
VAG/Steyr Puch designed an all wheel drive system that was then (and still is) unique and put it in a multi-purpose vehicle, the Kombi/Transporter.  Their intention was to achieve the best road holding and grip over a very wide variety of road and off-road conditions.  And they did this in a very large and heavy vehicle.
They wanted a vehicle that would achieve these high levels without needing any input from the driver and they succeeded.  They realized that, to achieve these levels, it did not need a reduction box, which was heavy, bulky and very expensive.  They settled for one very low gear (G gear) as being more than adequate to get the vehicle anywhere a reasonable person would need or want to go.  It was never intended to rush up moraines or climb cliffs – there were already plenty of vehicles that could do that and none of them were the size and comfort of the Kombi/Transporter.
The result is our Syncro, immensely strong, very stable, go anywhere one could reasonably want to go.
Twenty years down the track, we know that the VC can become aggressive – it kicks in very much earlier than an as-new VC.  This is not a bad thing and in fact many of us prefer this to the standard VC in terms of improved handling and braking.  But it comes with a downside.  Full lock turns on a grippy surface will produce binding in the drive train which can be both heard and felt.  The load on the drivetrain is immense and will lead to premature wear/failure of the drivetrain.
The solution is the decoupler.  Disengage for the full lock stuff, engage for everything else.  It has a side benefit of allowing the vehicle to be driven with mismatched tyre sizes, otherwise a guaranteed path to expensive driveline failures.  The principal benefit is to get you home with one totally mismatched wheel after a tyre/wheel failure far from home.  In extreme cases, not a few people have driven a long way to get home with no rear half shafts following catastrophic failure – it drives the front wheels only.
The decoupler is not affected by having/not having diff locks.
From: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] On Behalf Of bergodaz
Sent: 16 December 2009 17:46
Subject: [Syncro_T3_Australia] Re: de coupler
--- In Syncro_T3_Australia @yahoogroups. com, Michael Rayner <mrayner51@. ..> wrote:
> Regards
> Michael
href="http://au.movies.yahoo.com/session-times/">http://au.movies. yahoo.com/ session-times/
Les , don’t stop” one day”  -- stop today ! Keep the blog in your draft box and just kick it out next time. We do need your experience as much as decouplers in our vehicles.
Two things of interest firstly on my Type  166 4x4 could only be engaged in 1st gear
Type 82 was unique too, just so typical  VW, when you experienced 2 flat tyres, you stuck the spare on to the front end and continued for home. I once made it home in the middle of night
trough the African Veldt.  hartmut
Sent: Wednesday, 16 December 2009 6:43 PM
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of bergodaz
> Regards
> Michael
href="http://au.movies.yahoo.com/session-times/">http://au.movies.yahoo.com/session-times/
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4691 (20091215) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Michael,
I installed the German model and so did others on this Forum.
Personally I have, so far, encountered no problems, The de-coupler is
well engineered with roller bearing.
