re: Fit a 215 75 R15 wheel underneath ... mod part
Gday All,
Ok, finally found it. Here's what I think Sam has imported from the USA
to enable the placement underneath of the above size inflated tyre.
Goto: http://tinyurl.com/5s6dk5
Depending upon where you want to take your syncro, you may first want
to consider whether or not you can live without the protection the
steel clamshell does provide.
This is a good find.
Does one think it would be possible to modify the existing clamshell to fit the 215/75/15 ?
Not having examined it closely, however, would the Van Cafe model below deal with the steering column issues as well?
Mark.
On Mon, Oct 27, 2008 at 5:23 PM, Ken <unclekenz@yahoo.com> wrote:
Gday All,
Mark Kofahl
Solutions Outsourced Pty Ltd
Main: 1300 33 1000
Direct: 02 9375 2747
Mobile: 0419 275 259
Skype: markkofahl
www.solutionsoutsourced.com.au
www.siteflex.com.au
16 View Street, Camden, NSW, 2570
PO Box 658, Camden, NSW, 2570
This e-mail, including all attachments, may be confidential or privileged. Confidentiality or privilege is not waived or lost because this email has been sent to you in error. If you are not the intended recipient, any use, disclosure or copying of this email is prohibited. If you have received it in error please notify the sender immediately by reply email and destroy all copies of this email and any attachments. All liability for direct and indirect loss arising from this email and any attachments is hereby disclaimed to the extent permitted by law. Any views or opinions presented are solely those of the author and do not necessarily represent those of Solutions Outsourced Pty Ltd.
Gday Mark,
Based on what I've gleaned, my view is that it's not possible to modify
an existing clamshell to fit an inflated 215 75 15 wheel and still
retain the all important and already limited clearance approach angle
underneath. So in short ........ no.
This would need to be subject to confirmation, but as part of Van Cafe's
R&D, it makes sense to me that part of their brief to successfully
solve the problem of the 215 75 15 accommodation underneath would have
to include resolution of the steering shaft clearance. So I would say
.... yes. Sending them an email query though would confirm one way or
the other eh.
--- In Syncro_T3_Australia@yahoogroups.com, "Mark Kofahl"
<markkofahl@...> wrote:
> Ken,
to fit
> the 215/75/15 ?
below deal
> Regards
> Mark.
> On Mon, Oct 27, 2008 at 5:23 PM, Ken unclekenz@... wrote:
> > Gday All,
USA
want
> > Cheers.
> Mark Kofahl
> Main: 1300 33 1000
> Skype: markkofahl
> www.siteflex.com.au
privileged.
has
use,
received it
destroy all
presented
of
> fit
> the 215/75/15 ?
It has been done.
> deal
It may not fit a RHD.
Phil - can you advise or  indeed recommend someone in Sydney who would properly modify the clamshell to comfortably fit the BFG 275/75/15 (inflated) ? This would be helpful for our forthcoming Christmas trip.
Mark.
> fit
> the 215/75/15 ?
It has been done.
> deal
Mark Kofahl
Main: 1300 33 1000
Skype: markkofahl
www.siteflex.com.au
There are instructions on the internet somewhere. Probably a US site. Start with Derek Drew's site.
> Thanks
> Mark.
> clamshell
> > to
> > > fit
> > > the 215/75/15 ?
> > It has been done.
> below
> > > deal
> Mark Kofahl
> Main: 1300 33 1000
> Skype: markkofahl
> www.siteflex.com.au
> privileged.
> has
> use,
> it
> all
> presented
Early Australian syncros had the spare in the back.
> Mark,
> The word clamshell refers to a wheel carrier that indeed looks like a
> clamshell. It is pressed out of a sheet of steel, has no reinforcement
> and hinges the same as the Syncro wheel carrier. The Syncro wheel
> carrier was, as far as I know, fitted to all Australian delivered
> Syncros. This is constructed from heavy steel square tube.
> Give me a couple of days and I will get back to you on what is needed to
> modify it for the 215/75/15 tyre. I am running that size but I am
> carrying a 14" as a spare until I can modify the carrier. I have a
> decoupler, so I can run one 14" wheel if needed.
> Sent: Tuesday, October 28, 2008 7:43 AM
> Subject: Re: Re: Re: [Syncro_T3_Australia] re: Fit a 215 75 R15 wheel
> would
> trip.
> > Thanks
> > Mark.
> > clamshell
> > > to
> > > > fit
> > > > the 215/75/15 ?
> > > It has been done.
> model
> > below
> > > > deal
> > Mark Kofahl
> > Main: 1300 33 1000
> > Skype: markkofahl
> > www.siteflex.com.au
> > privileged.
> email
> > has
> any
> > use,
> received
> > it
> destroy
> > all
> and
> > presented
> those of
Gday Mark,
Here's another solution for $4.
Goto: http://tinyurl.com/5oyl7j
--- In Syncro_T3_Australia@yahoogroups.com, "Mark Kofahl" <markkofahl@...> wrote:
> Thanks
> Mark.
> > to
> > > fit
> > > the 215/75/15 ?
> > It has been done.
> > > deal
> Mark Kofahl
> Main: 1300 33 1000
> Skype: markkofahl
> www.siteflex.com.au
> Gday Mark,
> Goto: http://tinyurl.com/5oyl7j <http://tinyurl.com/5oyl7j>
What?
I run a tyre carrier from van cafe. You still need to deflate a 215/75/15 to avoid steering column problems. In fact you can still run the original clamshell with a 215/75/15 deflated.
You need a spacer to drop it by about 15mm, and a plate to prevent the tyre rubbing the
steering column. And don't forget the compressor.
I prefer it because it's lighter. Less protection is the downside. Having no tyre up front and
one hanging off the back seems to throw out the syncro's balance at speed.
Has anyone else experienced removing the centrifugal air filter provides a noticeable power
increase ?
regards
Send instant messages to your online friends http://au.messenger.yahoo.com
Gday Mark,
In Syncro_T3_Australia@yahoogroups.com, mark hallett <m.mullet@...>
> increase ?
Not here Mark.
Would you please elaborate, not sure exactly what you mean, what's
involved etc. TIA.
Hi Ken,
referring to the snorkel system that extends from the air filter to the side vent ( on an 89 syncro ). The last fitting before the main air filter is a centrifugal air filter. Remove this and there is a noticeable improvement in air flow and throttle response.
I've replaced mine with a paper style filter . If I'm ever going underwater I guess I'll put it back on.. I've heard that removing the cat converter also improves power by 10%.
But who would do that ?!
Re clamshell I meant the Aussie style spare tyre holder.
Search 1000's of available singles in your area at the new Yahoo!7 Dating. Get Started.
Makes no difference whatsoever.
If anyone wishes to try it, I can lend them a pipe from a DJ engine.
Gday syncronauts,
A revelation, I think.
Re: .............
""""""--- In Syncro_T3_Australia@yahoogroups.com, "Ken" <unclekenz@...>
wrote:
> Gday Mark,
modify
> underneath. So in short ........ no.""""""
UPDATE:
Given all the interest and posts on this topic, I decided to get down
and dirty today (it was raining outside anyway) and eyeball the spare
wheel holder vicinity. As they say, if you want a job done properly, do
it yourself. So now it seems to me, most of the info I've previously
"gleaned" online is in fact a load of old cobblers.
What I'm about to say may not be as momentous as when Les revealed here
recently about the availability of an Oz manufactured and sourced ring
and pinion gear but heh ... I reckon it's up there somewhere!
Firstly, let me be clear on this. I'm referring to the Australian
square-ish clamshell/skidplate, not the lightweight USA circular
clamshell.
So what I'm saying here is that .... yes, merely with the aid of a 100mm
electric grinder and several hours hard yakka, some but not all 15"
deflated tyres on rims WILL fit in the clamshell. This is with no
modifications nor adjustments to it nor clearance issues with the
steering rod nor loss of approach angle. All good, as long as you've
selected the right profile 15" tyre that will fit or perhaps even a
lower profile tyre on a 16" rim.
Good news I think for syncro owners generally, not good news for
manufacturers and retailers of rear wheel carriers nor those who've
already paid top dollars buying one, especially from overseas. Then
again, if you do have a rear wheel carrier, means now there is the
option to carry a second matching spare wheel or tyre for outback
touring.
The two critical criteria for this to work is the overall diameter and
width of the deflated tyre. Diameter size determines whether or not the
tyre can fit between the two fore/aft structural beams which, if you
take a look, have already been factory trimmed to allow room for the
tyre diameter. This is where I used the grinder to trim off more
material and on a more even curve, this is what's needed for this
project to be successful. More on that later. Now the width of the tyre
determines whether or not it can actually fit in the storage space
height and crucially, achieve clearance off the steering rod.
So now to the 3 tyres tested. For those interested, if your tyre isn't
mentioned here, you'll need to check your own to see if you are "in with
a chance" of similar success. May I suggest you report back here your
findings for the benefit of us all.
Best fit (easiest) was BF Goodrich All-Terrain T/A LT215/75 R15. This
should please lots of Oz syncro owners.
Next best fit (larger diameter but still ok) was Dunlop Adventurer
GR78-15LT (8 ply). Probably rare these days.
Failed to fit (my present tyres) was Goodyear Wrangler AT/R 215/75 R15.
Tyre is too wide to clear steering rod.
For those wanting to check their tyre dimensions first, lay the tyre
flat on a level surface, a rough rule of thumb guide for success would
be a deflated tyre diameter no more than 704mm and not more than 208mm
overall width to clear the steering rod. Expect that different brand
tyres have different profiles in the 215 75 15 size, so at the end of
the day, the real acid test after checking the tyre is to then eyeball
the project and depending what you decide, tackle the grinding, refit
the tyre a few times as you go to see how things are progressing until
you are satisfied with the fit.
A tip is, after each time you do some more grinding and you then want to
check progress, reinsert the tyre, juggle it around for best fit, push
the clamshell up and see if you can get the clamshell onto the catch. If
so, there is room to grab the steering rod on the side and juggle it
back and forth to check for clearance. If it's clear, screw the bolt
home in stages, check a few times to see if clearance is still ok. If
you find there is a small amount of drag on the steering rod you think
you can live with, just apply a smear of rubber grease to the steering
rod where the tyre sidewall is touching and check again. A case of suck
it and see. If you decide their is some tyre drag but not a lot, try
lowering the clamshell on the fixing bolt using a few steel packing
washers, maybe 5-10 mm total will do, this may be enough to get
clearance. In which case, you should also add equivalent packing to the
clamshells left and right bump upstands.
If all else fails, plan to buy a set of 15" BFG All Terrains or
equivalents.
To get an idea of the area I'm referring to that needs additional
grinding, go to the photos that Bill has posted today and look for the
photo called "spare wheel carrier modifications t3 004". On the inside
of the structural beam, you can see where the factory shaping has been
done to accommodate the tyre diameter. That shaping is what needs
grinding back further on both beams and also removing any daggy steel
bits intruding. Finally, check for and round off any sharp metal edges
and paint the exposed bare steel with protective paint. I use POR 15,
the best.
I stress, for the relatively small amount of additional grinding
involved, this in no way compromises the structural integrity of the
beams.
Hope this is of some assistance. Any queries, please fire away.
thanks for the comprehensive report.
2 items:
1) Do you have the clamshell or the heavy steel tube Syncro bash plate style carrier? (latter I assume)
2) Can you post some pics of what you have done / achieved?
Thanks for your efforts on this.
mark.
On Wed, Oct 29, 2008 at 10:21 PM, Ken <unclekenz@yahoo.com> wrote:
Gday syncronauts,
Re: .............
wrote:
> Gday Mark,
modify
UPDATE:
clamshell.
touring.
equivalents.
the best.
beams.
Mark Kofahl
Main: 1300 33 1000
Skype: markkofahl
www.siteflex.com.au
Mark, I feel both your queries are adequately covered in my update.
Answer to Q1 is paragraph 3, Q2 is in paragraph 13. Just follow the
instructions.
Short of others actually doing it, the only other suggestion I can think
of is a field day where anyone can check the fit of their deflated tyre
in my clamshell and also check for steering rod clearance. Probably be
simpler to just do it, suck it and see.
> Ken,
> 2 items:
style
> Regards
> mark.
> On Wed, Oct 29, 2008 at 10:21 PM, Ken unclekenz@... wrote:
> > Gday syncronauts,
> > Re: .............
> > """"""--- In
Syncro_T3_Australia@yahoogroups.com<Syncro_T3_Australia%40yahoogroups.co\
m>,
> > "Ken" unclekenz@
> > wrote:
> > > Gday Mark,
> > modify
angle
> > UPDATE:
down
spare
do
here
ring
> > clamshell.
100mm
> > touring.
and
the
tyre
isn't
with
your
This
R15.
would
208mm
of
eyeball
refit
until
want to
push
catch. If
If
think
steering
suck
the
> > equivalents.
the
inside
been
steel
edges
15,
> > the best.
> > beams.
> > Cheers.
> Mark Kofahl
> Main: 1300 33 1000
> Skype: markkofahl
> www.siteflex.com.au
privileged.
has
use,
received it
destroy all
presented
of
