Thanks for the detail ... interesting. Yes I often see the genuine
article 2nd hand on ebay, always wondered the sense of buying one
especially when not knowing how much life might or might not be left in
them, by all reports they can fail suddenly, hence the interest in a new
one instead, like this one I uncovered on ebay.
I'm not sure but I had the idea the genuine article is something like
$250, maybe someone knows for sure. If so, makes this one look quite
reasonable if it were to do the job satisfactorily ... a mute point.
Essentially it would work then, your main concern is the difference in
flow rates between the genuine one and this? Meaning do you know the
correct flow rate for the genuine article and compare that with this
pump?
--- In Syncro_T3_Australia @yahoogroups. com, plander@... wrote:
> It has a higher litres per minute flow rate.
> These pumps are not like electric fuel pumps for carburettors. They do
not cut in and out due to pressure, they just run continuously and the
pressure regulator sends the excess back to the tank. The digifant
system was designed for a certain flow rate and if the fow rate is too
much, can the return system handle it on overun when the injectors are
shut off?
> I could understand using an alternative pump if the genuine article
was no longer available, but why when they are not hard to get? These
exact pumps have been on Kombis since arount 1974 so they should be
available for a while.
> > Ken unclekenz@.. . wrote:
> > erm ...... please, would you care to elucidate your point? TIA.
> > --- In Syncro_T3_Australia @yahoogroups. com, plander@ wrote:
> > > . The 070 pump will flow a
> > > > little bit more fuel than your stock VW pump, however the fuel
> > pressure
> > > > regulator will keep a constant system pressure (regardless off
pump
> > flow
> > > > capability) and will simply return excess fuel back to the tank.
> > Your
> > > > engine will run exactly the same with the same
performance/ economy.
> > > Sounds like it is the wrong pump to me.
