Bill, Ken, Roger, Hamish and All,
Mine is not a Vanagon Syndrome only #2 of Peter Kestels explanation apply
to my problem but no smoke.
Thanks Ken for that very informative report, I'm going to need it.
In my case a few not related symptoms buildt up around the same time
according to the VW mechanic.
Spark plug connectors faulty resistance, the AM wiper movement has a few
erratic spots.
Running on LPG I use special plugs which could not handle the over rich
mixture, back to standard plugs for now.
So a few things out of wack caused me all that headache. The AFM isn't
that old - bought in 01/2010. (58,000km)
I will try to repair the AFM as per Peter K's remedies. I will keep you
posted as I go.
Thanks again for all your suggestions.
At 10:15 AM 30/07/2013, you wrote:
Theo. I had the same problem as you and Ken. Intermittent stalling. After
working my way through all the common offenders it turned out to
