----- Original Message -----From: plander@optusnet.com.auSent: Friday, September 17, 2010 12:32 PMSubject: Re: Re: RE: [Syncro_T3_Australia] Deep Cycle Batteries That fit under the Passenger SeatThey are similar to mobile phone batteries. You would have to find the details and what packs that they come in. You may need 4 of them or you may need 20 of them, I don't know the specifications. You would have to by them from a wreck as new ones would be worth more than your syncro.
> Do they fit under the seat Phill?
> Sent: Friday, September 17, 2010 11:36 AM
> Subject: Re: RE: [Syncro_T3_Australia] Deep Cycle Batteries That fit
> The only battery to suit your needs would not contain lead/acid and
> could cost many thousands of $.
> I have heard of success with Toyota Prius batteries if you wish to
> search a few wreckers.
> > Ken Garratt <unclekenz@hotmail.com> wrote:
> > Scott,
> > Concerning the topic of "camping battery", there are so many
> variables
> > that need to be taken into account so as to arrive at what may still
> > prove to only be a compromise. I fear that based upon the limited
> info
> > you have provided so far re your own family/van circumstances,
> > especially with a self imposed time limit ... I suspect you will be
> > heading for a fall .... ain't gunna work m8y. Especially if you hope
> to
> > do more than ONE day camping AWAY from ac and/or solar power and/or
> long
> > drives to recharge but you dearly still want to avoid egg on face
> when
> > the princesses and your better half in unison complain about the
> warm
> > fridge and the rotting provisions. This happened to some on the
> Batemans
> > Bay Tour 2007, despite having a larger camping battery and driving
> every
> > day, just for starters.
> > If I were you, I'd be deferring the decision about the
> fridge/camping
> > battery combo until such time as you carry out a detailed research
> on
> > this complex topic. I know hindsight is just sooooooooo great, but
> > really, the pre-allocation of space for an adequate sized/type
> camping
> > battery plus choices of supplementary battery charging systems for
> your
> > camping needs, particularly if you need adequate multi day running
> of a
> > fridge, all this should have been sorted/earmarked years ago near
> > start of your conversion.
> > So at this stage, in my view, under the circumstances as you have
> > described, hold off on committing to what you seem to be heading
> toward
> > and instead till you sort this properly, limit to one day picnics
> and
> > frozen bricks in an esky. M8y, this temp solution should work just
> fine.
> > As a pretty rough rule of thumb, whatever YOU are thinking at the
> moment
> > re camping battery size, probably triple or quadruple it and add 160
> > watt minimum solar!
> > Good luck. Cheers.
> > Date: Fri, 17 Sep 2010 10:12:54 +1000
> > Subject: Re: Re: Re: [Syncro_T3_Australia] Deep Cycle Batteries That
> fit
> > There is no joy there without major modifications.
> > I haven't seen a deep cycle that will fit. 280L x 175W x 175H
> > I use a Federal 691MF but I don't have a fridge to deep cycle it.
> > A 44ah may only work your fridge for a few hours.
> > > Thanks Phill.
> > > My Subaru 6cyl has various bits in these holes and hence it wont
> work.
> > > My under seat area is also full. Under the front passenger seat is
> my
> > > only option.
> > > Cheers,
> > > Skot
> > > Sent: Friday, September 17, 2010 8:10 AM
> > > Subject: Re: Re: [Syncro_T3_Australia] Deep Cycle Batteries That
> fit
> > > Scott,
> > > That (44ah) sounds like a very small battery to run a fridge for
> long.
> > > Optima are the better of the spiral agm batteries.
> > > Give these guys a call. They deliver and prices are usually good.
> > > www.batteriesdirect.com.au/
> > > Have you thought of batteries under the back seat? Or beside the
> > > engine where the diesel battery is located?
> > > > Thanks Roger.
> > > > I need to sort this in 2 weeks. I looked at the site provided by
> > > Scott
> > > > from Turbovans and found an Odyssey 44A/h battery fits with code
> > > number
> > > > PC1200 and some other numbers that were hard to read from the
> photo
> > > > 0766.2025 0906.
> > > > I am going to try for this.
> > > > I copied a photo of the multiple small battery setup he also
> used in
> > > > another van in series which is also a good idea but difficult
> for me
> > > to
> > > > sort in the remaining time I have available.
> > > > I will try and source an Odyssey from battery world.
> > > > I checked the Varta battery he originally suggested and its way
> too
> > > high
> > > > - by about 15mm.
> > > > Thanks for all the help though.
> > > > Cheers,
> > > > Skot
> > > > From: Roger Bell
> > > > Sent: Friday, September 17, 2010 12:41 AM
> > > > Subject: Re: [Syncro_T3_Australia] Deep Cycle Batteries That fit
> > > under
> > > > the Passenger Seat
> > > > Dear Skot,
> > > > The original owner of my vehicle solved the problem by deepening
> > > > the battery box to 220mm under the front passenger seat. I
> replaced
> > > the
> > > > previous deep cyle battery last year when it was over 8 years
> old
> > > with a
> > > > Delkon deep cycle forklift truck battery.It says it is a 20hr
> > > battery
> > > > (at what discharge rate?) and its minimum capacity is 145(don't
> know
> > > > what units) and it is a MF Calcium battery.From memory it was
> about
> > > > $140. The lid of the battery box has also been slightly
> hightened
> > > with
> > > > spacers on the hinges.
> > > > The extra depth widens the range of battery choice and also
> > > > probably the capacity. .However if you go for this solution the
> > > extended
> > > > box blocks withdrawal of the top wishbone bolt which is
> necessary to
> > > > replace this suspension bush. Either first replace the bush as a
> > > > precaution or as in my case cut a round hole in the extended
> battery
> > > box
> > > > which allows subsequent withdrawal of the bolt and then
> > > appropriately
> > > > plug it.The battery box also has a metal plate clamping the
> battery
> > > > tightly in position but possibly this is an original fitting. I
> > > > understand it is important not to have a battery bouncing around
> in
> > > its
> > > > box if you want an extended life from it.You'd be welcome to
> have a
> > > look
> > > > but aren't you in NSW? Could send some photos if the idea
> appeals.
> > > > Good luck
> > > > Roger
> > > > --- On Thu, 16/9/10, Mr Scott Pitcher
> > > > From: Mr Scott Pitcher <spbconsulting@bigpond.com>
> > > > Subject: [Syncro_T3_Australia] Deep Cycle Batteries That fit
> > > > Received: Thursday, 16 September, 2010, 12:58 PM
> > > > Hi All,
> > > > Now I am finally connecting up a second hand fridge I have had
> > > > for the last 6 years (unused) I need to organise a deep cycle
> > > battery as
> > > > starting batteries don't like the constant draw from the fridge
> > > > compressor.
> > > > However, finding batteries that fit is a struggle.
> > > > My local Battery World has a VARTA (German made) battery that
> > > > is an 80Amp that is of the following dimensions:
> > > > 278mm Long x 175mm wide x 190mm high.
> > > > My existing battery is 280mm long x 180mm wide x 180mm high.
> > > > Hence it fits except the height may be an issue with the extra
> > > > 10mm.
> > > > Has anyone fitted one of these or any other type of deep cycle
> > > > battery.
> > > > Any help appreciated.
> > > > Thanks,
> > > > Skot
According to some American site the new ones are nearly $3K
but apparently there are only two - both different sizes? I find that hard to
believe.
I will check it out further.
Syncro enthusiast Paul Guzyk, recently from California now in Colorado, modifies Prius cars to run 100% on batteries. Pmail me if you want his contact info. Hate to post it on a public forum without his permission.
If you want some interesting solutions, you might want to google the contact info for Jan Tribulowski who is now in the business of building hybrids for BMW. He is a Syncro enthusiast as well and will likely be helpful. He is in Germany now after a two year stint here in California playing with twin-turbo petrol powertrains. I only have his personal email which may not be how he wants receive such inquiries.
On Sep 16, 2010, at 9:05 PM, "Mr Scott Pitcher" <spbconsulting@bigpond.com> wrote:
According to some American site the new ones are nearly $3K but apparently there are only two - both different sizes? I find that hard to believe.I will check it out further.Thanks,Skot----- Original Message -----From: plander@optusnet.com.auSent: Friday, September 17, 2010 12:32 PMSubject: Re: Re: RE: [Syncro_T3_Australia] Deep Cycle Batteries That fit under the Passenger SeatThey are similar to mobile phone batteries. You would have to find the details and what packs that they come in. You may need 4 of them or you may need 20 of them, I don't know the specifications. You would have to by them from a wreck as new ones would be worth more than your syncro.
Ben T and all,
I have managed to find a Varta battery that is a "Euro Special
Fit" designed specifically for "Recreational Power". This one is rated @ 80A and
according to the dimensions it will fit without the battery flap
on.
My Traxide smart charger system is now fitted and the battery
is on order.
Hopefully it will all work out fine.
We use powered sites when we go away so the battery will only
have the driving burden. Should cope fine.
----- Original Message -----From: BenT SyncroSent: Friday, September 17, 2010 3:41 PMSubject: Re: [Syncro_T3_Australia] Deep Cycle Batteries That fit under the Passenger Seat
Syncro enthusiast Paul Guzyk, recently from California now in Colorado, modifies Prius cars to run 100% on batteries. Pmail me if you want his contact info. Hate to post it on a public forum without his permission.If you want some interesting solutions, you might want to google the contact info for Jan Tribulowski who is now in the business of building hybrids for BMW. He is a Syncro enthusiast as well and will likely be helpful. He is in Germany now after a two year stint here in California playing with twin-turbo petrol powertrains. I only have his personal email which may not be how he wants receive such inquiries.Cheers,BenTAccording to some American site the new ones are nearly $3K but apparently there are only two - both different sizes? I find that hard to believe.I will check it out further.Thanks,Skot----- Original Message -----From: plander@optusnet.com.auSent: Friday, September 17, 2010 12:32 PMSubject: Re: Re: RE: [Syncro_T3_Australia] Deep Cycle Batteries That fit under the Passenger SeatThey are similar to mobile phone batteries. You would have to find the details and what packs that they come in. You may need 4 of them or you may need 20 of them, I don't know the specifications. You would have to by them from a wreck as new ones would be worth more than your syncro.
