Do you know the 'before' measurements also?
BenC
--- In Syncro_T3_Australia@yahoogroups.com, "wendy and brian" <wendyandbrian7@...> wrote:
> Hi ben
> The falcon springs come i 1cm length increments( don't know the max length
> you can get them, and also spring dia increments. My local car accessory
> shop sourced them, but they were off the shelf items. The wind is app 2mm
> larger dia in the wind but they still sit in the shock holder ( new standard
> boags) ok. Oh i had to grind one end to have a flat profile.
> The ride of the van before these changes( with a camper fitout and much more
> weight 70lit more fuel and70lit of water etc) the suspension arms were
> already over the center line of their travel, ie when hitting a bump they
> were already mostly through the better half of their travel.but now the arm
> is in a position where it still has the best part of its travel at the
> beginning of the bump. Side advantage is far more ground clearance, but
> still it is nut stressing the uni's.
> The Nissan rears now make the van sit flat from the side view, and are much
> more compliant over bumps, once again the swing arm is in a better attitude
> to hit a bump. Because i got these from a wrecker and i know they are heavy
> duty but i don't exactly know how hd they are.
> From memory front springs $80 ea and rears $20ea and a happier ride and
> stance have made a syncro owner happy.
> Oh and one more thing you need toknow about the rears is that the diminished
> spring wind dia is not as much as the syncro spring but it is ok in my
> estimation. They have been on for a few thousand k now with no probs. They
> passed a rego hoist inspection.
> Hope to be at valla, so you can look, if you have no rush
> brian
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ben
> Sent: Tuesday, 17 January 2012 9:12 PM
> Subject: [Syncro_T3_Australia] Re: Springs
> Brian,I am also interested in the Falcon spring option.
> Were these springs made by a spring manufacturer to those specs?
> How have you found them?Do you also run OME shocks?
> Has it raised the front at all?how much?
> BenC
> <mailto:Syncro_T3_Australia%40yahoogroups.com> , "wendy and brian"
> <wendyandbrian7@> wrote:
> > Hi
> > I have just finished putting xd falcon springs on the front ( 1mm larger
> in the spring dia, and 1cm longer than falcon standard. And on the rear i
> have put Nissan gq patrol front springs on the rear( these were after market
> hd spring sourced from wrecker.
> > All up a very cheap way of re springing a heavier than standard camper
> syncro.
> > brian
> <mailto:Syncro_T3_Australia%40yahoogroups.com> ] On Behalf Of Graham Adams
> > Sent: Tuesday, 17 January 2012 11:55 AM
> > To: syncro_t3_australia@yahoogroups.com
> <mailto:syncro_t3_australia%40yahoogroups.com>
> > Subject: RE: [Syncro_T3_Australia] Re: Springs
> > Hi David
> > Note with interest your trip starting late April.
> > My wife and I are planning a similar Syncro trip but from Sydney starting
> mid June or July.
> > Itinerary being Alice, Tanami, Kununurra,Mitchel falls,Broome,Perth, home.
> > Opposite way to you so hopefully our paths will cross around Halls creek.
> > Like you, early preparation. OME shockers on order but what springs are
> you using?
> > Suplex springs from J Kampers are the easiest to access (made in germany).
> Any other suggestions?
> > Shwenka from USA is an option or H.R from Go Westy. Can any one help on
> this one?
> > Tried googling Volksland as recently mentioned as a possible source, no
> luck, address anybody?
> > Cheers Graham
> > Sent from Samsung tablet
> > David Beckley <david.beckley@ <mailto:david.beckley%40cdcwa.com.au> >
> wrote:
> > >Hi Guys,
> > >I am getting a few people saying that they are interested in a WA Syncro
> > >group and I will put together a list of names and contact details and
> post
> > >it in a few days time.
> > >I live in Mosman Park and get my vehicle serviced at Mosman Park
> Autocare,
> > >which is back under the management of Patrick Hugi who is a really good
> > >factory trained VW mechanic and Syncro owner.
> > >I just thought that I would see how many people I could find in WA that
> use
> > >their Syncros for camping trips. I am now retired so have lots of time
> for
> > >trips with my wife Louise. We have had the Syncro since new and I am
> still
> > >running the original 14 inch rims although I may have to change to 15
> inch
> > >as it is getting harder to get tyres for 14 inch rims. We have been round
> > >Aus once and are leaving in late April for a four month trip to the
> > >Kimberley region. The van has a pop top and a full camper conversion,
> hence
> > >the rego name.
> > >There are some good trips east of Esperance that we would like to do
> later
> > >this year or possibly in April/May next year. There is also the Holland
> > >track that might be good fun. For local camping we often go to Hoffman
> Mill
> > >near Harvey. This is a nice place in the forest and only 21/2 hours from
> > >Perth but not challenging for off-road activities although there are
> plenty
> > >of tracks around there.
> > >My phone number is 9383 4303 and if you are in the area please give me a
> > >call and drop in for a chat; I live at 38A Manning Street, Mosman Park.
> > >Cheers,
> > >Dave
> > > _____
> <mailto:Syncro_T3_Australia%40yahoogroups.com> ] On Behalf Of Philippe Tyack
> > >Sent: Monday, 16 January 2012 8:09 PM
> > >Subject: Re: [Syncro_T3_Australia] Re: Springs
> > >Hi Dave ,
> > >I would be interested in a Wa Syncro group
> > >Regards
> > >Philippe - Scarbourgh
> > >Mobile : 0450059162
> > >On 16 January 2012 19:18, Greg <greg_navarro95@
> <mailto:greg_navarro95%40yahoo.com> > wrote:
> > >Hi Dave
> > >I live in Bunbury if your heading down this way drop in to say hello.
> > >I would be interested in meeting with other WA syncro owners.
> > >Greg
> > ><mailto:Syncro_T3_Australia%40yahoogroups.com> , "David Beckley"
> > ><david.beckley@> wrote:
> > >> Hi Greg,
> > >> Thanks for the info; your report on the front springs is encouraging. I
> am
> > >> going on a four month trip to the Kimberley region returning via the
> > >Tanami
> > >> desert road to Alice Springs and then Alice to Laverton and back to
> Perth.
> > >> We leave in late April and I want to fit some new springs before we go.
> > >> I am keen to meet other Syncro owners in WA and perhaps do a Syncro
> group
> > >> trip some time in the future. I have joined the VW Club of WA but they
> do
> > >> not have many Syncro owners as members. Any WA Syncro owners interested
> in
> > >> forming a local group for trips in WA?
> > >> Dave Beckley
> > >> Mosman Park
> > >> VW Syncro rego - VW HILTON
> > >Philippe Tyack
> > >Mobile:+61450059162
> > > _____
> > >size=1 width="100%" noshade color="#a0a0a0" align=center>
> > >No virus found in this message.
> > >Checked by AVG - www.avg.com
> > >Version: 2012.0.1901 / Virus Database: 2109/4745 - Release Date: 01/15/12
