DOKA , a mayor challenge at my vintage but we have to keep on doing what we love...
Date:08/09/2016 12:48 AM (GMT+10:00)
Cc:
Subject: Re: [Syncro_T3_Australia] Fuel tank removal [9 Attachments]
Well there you go!! It all looks OK in there despite I do the odd creek crossing/mud wading. Does the grommet incorporate a drain tube of some sort? I will make my own unless they are available new?
Progress is still slow but getting there. Just a few pics. Cleaned up and covered the original earth leads, and will double up on each (two leads on the GB, one to each head).Also doubling up on the cable from the alternator to the starter.
Going to trial some rubber panels and see if they help keep dirt/mud/sand out
A couple of the nut serts at the back holding the muffler cover had come loose, so have replaced them,
Was interesting to see the kinks in the fuel filler, also getting a new hose.
Photo of the failed grommet in the tank breather/roll over valve. Seemed odd all the other rubber and hoses are in good condition. Even the failed grommet is fine externally, only the inside fell to pieces.
Currently working on fitting the rear heater and decoupler
---In Syncro_T3_Australia@yahoogroups.com, <gregespo73@...> wrote :
Sent from Greg's iPhone
On 7 Sep 2016, at 12:21 AM, cathrich1@... [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Was looking at the engine today, I notice the bell housing has a breather at the top, but it is also open at the bottom. Is that correct, or should the syncro be sealed at the bottom?
