Hi Phil,
Think this should get you in. They claim membership from 36 countries at last count. Perhaps its time to organise a Syncro Olympics. I fancy myself for the distance events. I think you would get the gold medal for the Concours de Elegance.
Hope it prove fruitful.
Melbourne
Sent: Friday, 10 August 2012 6:15 AM
Subject: Re: [Syncro_T3_Australia] Fw: [Syncro] Digest Number 5615 vibration problems.
Thank's Roger, what is the web address for these people?
> Roger Bell <bellrmit@yahoo.com.au> wrote:rel="nofollow" target="_blank" ymailto="mailto:Syncro@yahoogroups.com">Syncro@yahoogroups.com>
> Phil do you already access this site? Any of these experiences/solutions
> of any help for your imbalance problem. I can understand the frustration
> particularly at such a low mileage but am sure you will successfully
> persevere. Don't they say " If at first you don't succeed then perhaps
> sky diving is not for you"
> Good luck.
> Roger
> Melbourne
> ----- Forwarded Message -----
> From: "Syncro@yahoogroups.com" <
> To: Syncro@yahoogroups.com
> Sent: Thursday, 9 August 2012 9:45 PM
> Subject: [Syncro] Digest Number 5615
> Original group for VW's Vanagon Syncros!
> Original group for VW's Vanagon Syncros! Group
> 4 New Messages
> Digest #5615
> 1a
> Re: Vibration Issue Persists by "Richard A Jones" rjones1942
> 1b
> Re: Vibration Issue Persists by "Dan Goade" dgoade2
> 1c
> Re: Vibration Issue Persists by "batomika" batomika
> 1dPersists by "Robert Stevens" mtbiker62
> Re: Vibration Issue
> Messagesbolt in the transaxle or front
> 1a
> Wed Aug 8, 2012 9:39 am (PDT) . Posted by:
> > My Syncro still experiencing a vibration around 45 mph even though I
> have removed the propeller shaft.
> I had vibration problems once and removing the prop shaft didn't cure
> everything. We found an outer front CV that was very stiff. It wasn't
> apparent until the axle was removed. I think it was making the front
> diff strain in the mounts and putting vibes into the van, if that makes
> sense. Anyway, new axles made the ride smooth.
> Richard
> Reply to sender . Reply to group . Reply via Web Post . All
> Messages (8) . Top ^
> 1b
> Wed Aug 8, 2012 1:12 pm (PDT) . Posted by:
> "Dan Goade" dgoade2
> All:
> I feel the vibration in the seat and the steering wheel. The best ways
> I can describe the vibration is that it is like the "Magic Fingers" in
> cheap motel rooms, or an out of balance fan. It is not the radiator fan
> nor is it the heater fan.
> I have confirmed that all four axels are not rubbing on anything. I
> also verified that I did not leave a
> differential after I removed the driveshaft.new axles front and rear,
> Is there anyone in the Knoxville, Tennessee area that would like to go
> for a ride and help diagnose this vibration???
> Regards – Dan G
> 1987 Syncro Westy Butter Churn
> 1c
> Wed Aug 8, 2012 1:35 pm (PDT) . Posted by:
> "batomika" batomika
> Years ago I had this same problem with a '91 tintop where I did pretty
> much as you have done plus more, including all
> new VW propshaft (they were still available) as well as shimming thethe radiator
> front diff. to get the "proper" flange angle with no success. Dropping
> the propshaft did nothing in removing the "magic fingers" between 45 and
> 55. My VC was also aggressive and after replacing it and reassembling
> everything using what is now known as the "Van-Cafe" method of
> alignment, the problem went away. I could only assume that the VC was
> out of balance although I never tested to confirm this.
> --- In mailto:Syncro%40yahoogroups.com, "Dan Goade" <dgoade2@... >
> wrote:
> > All:
> ways I can describe the vibration is that it is like the "Magic Fingers"
> in cheap motel rooms, or an out of balance fan. It is not
> fan nor is it the heater fan.. Posted by:
> also verified that I did not leave a bolt in the transaxle or front
> > Regards – Dan G
> 1d
> Wed Aug 8, 2012 2:31 pm (PDT)
> "Robert Stevens" mtbiker62. All
> On Aug 8, 2012, at 2:12 PM, "Dan Goade" <mailto:dgoade2%40aol.com>
> wrote:
> I feel the vibration in the seat and the steering wheel. The best ways I
> I have confirmed that all four axels are not rubbing on anything. I also
> Dan,
> Has wheel/tire imbalance been eliminated, or bent wheel-rim?
> bob
> Messages (8) . Top ^visit:
> Visit Your Group
> View All Topics
> Create New Topic
> We are making changes based on your feedback, Thank you !
> Submit Feedback
> The Yahoo! Groups Product Blog
> Check it out!
> GROUP FOOTER MESSAGE
> Please note that the default "Reply" function will route your reply to
> the entire group. If you have a private message for a member you'll need
> to specifically address your message to them.
> If you would like to modify your subscription settings (including
> unsubscribing),
> http://groups.yahoo.com/group/Syncro------------------------------------
> Rude or offensive language is not allowed on the Syncro list. Please try
> your best to resolve differences privately and keep them off the list.
> CHANGE SETTINGS
> TERMS OF USE
> UNSUBSCRIBE
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
