Sent: Wednesday, March 4, 2009 7:14:00 PM
Subject: Re: [Syncro_T3_Australia] Instrument cluster with tacho & digital clock. Oz alloy roo bar
Except the speedo, it's a straight swap. We already have the tacho wire.> Concerning the condition of the instrument cluster enclosure, I suspect
> this has a lot to do with whether or not the van is mostly garaged or
> left out on the street. If you say many enclosures are deteriorated,
> cracked etc., well by comparison, I know mine is in pristine condition
> despite Oz in the main being a very sunny part of this planet. So maybe
> this is only an issue on a case by case basis.
> If you can confirm this instrument cluster is a straight swap utilising
> our existing wiring loom and connectors and just the tacho has to be
> changed over plus add a tacho sensor cable (to somewhere), then it
> sounds like a goer, if Oz syncro list members are interested. Perhaps
> someone here would raise their hand and be the guinea pig to do a test
> run first ... iron out the bugs sort of thing, if any.
To convert from a clock to a tacho, you will need the printed circuit and the tacho.
Looking for the perfect gift? Give the gift of Flickr!
