----- Original Message -----Sent: Friday, May 16, 2008 8:36 PMSubject: [Syncro_T3_Australia] New poll for Syncro_T3_Australia
Enter your vote today! A new poll has been created for the
Syncro_T3_Australia group:
"2009 Fully Sync Tour" - SAT 10th to Friday 16th January 2009.
Batemans Bay - Shallow Crossing - South East NSW.
For planning purposes, Who is attending ?
o Yes
o NO
To vote, please visit the following web page:
http://groups. yahoo.com/ group/Syncro_ T3_Australia/ surveys?id= 2043931
Note: Please do not reply to this message. Poll votes are
not collected via email. To vote, you must go to the Yahoo! Groups
web site listed above.
Thanks!
> Ben <bencroft96@yahoo.com> wrote:
> Les and Group,
> As there has been a lack of posts on this forum lately,it has been
> making me wonder about the groups usage of their vehicles, so I decided
> to create a poll to create some interest.
> If you get some time,please fill it out.Your name is not recorded.
> Les,if you go into the poll section,you can see that I am the creator of
> the poll.
> Thankyou
> BenC
> --- In Syncro_T3_Australia@yahoogroups.com, "Les Harris"
> <leslieharris@...> wrote:
> > Posting polls is fine.
> > Not putting a name to it is not!
> > Who posted this?
> > Les
> > _____
> > From: Syncro_T3_Australia@yahoogroups.com
> > [mailto:Syncro_T3_Australia@yahoogroups.com]
> > Sent: 11 August 2011 22:36
> > To: Syncro_T3_Australia@yahoogroups.com
> > How do you use your Syncro?
BenC
> BenC is now becoming a computer nerd.
> > Ben <bencroft96@...> wrote:
> > Les and Group,
> > the poll.
> > Thankyou
> > BenC
> > > Who posted this?
> > > Les
> > > _____
Ok change of subject
If you have power windows and are thinking of fitting the weather shields from Mr Kuch from st Clair I have encountered this problem ;
1. When the weather shield is fitted it narrows the window channel clearance to the glass causing more friction as the glass goes up and down;
2. The window rise and lower assembly has two 90 degree wire guides one at the top and one at the bottom the top one is fitted with a metal rivet, the lower with a plastic unit, with the increased tension on the drive the lower rivet fails with this happens the wire rope looses it tension and then the wire proceeds to unravel in the gearbox drum drive unit and makes a mess to untangle, one has to access the drum unit, reinstall the cable and put back, so the purpose of this note is if you are in this situation replace the plastic pin with a metal pop rivet or screw and nut before you fit the weather shield, it will save you a lot of anguish as I encountered as I had both sides fail..
Bob
I ran into a similar problem with mine and decided to trim the inner edge off the upper section of the bailey channel to give sufficient clearance. I needed this the most on the passenger side where the channel was still fairly tight . My drivers side glass used to rattle even when fully closed as the channel was squashed so badly so the shields basically fixed that issue immediately.
My plastic rollers that guide the stainless wire on the passenger side used to fail regularly until I took them to my Dads hydraulic engineering shop and he made up some new brass ones on the lathe. They have been brilliant ever since and much stronger than the plastic rubbish they replaced.
I also glued my weathersheilds to the rubber channel to ensure they stay out of the way of the glass.
Works well.
I would suggest getting a new Stanley knife and trim the inner rubber to allow clearance just where the weather shield is.
Worked for mine.
On 22/01/2012 9:26 PM, Robert Dale wrote:Ok change of subject
Bob
Fair comment, one question was the upper and lower guide a 90 degree unit , it would be interesting if you could post a diagram of what you did, another thing I found that when the passenger side unit glass moved up down the deflector moved from its mounted position, the deflectors are a great unit far better than the standard full deflector.
Bob
Sent: Sunday, 22 January 2012 10:06 PM
Subject: [Syncro_T3_Australia] New Weathersheilds
Bob,
Works well.
Worked for mine.
Bob
I installed the weathershields on a hot day and followed the you tube instructions on the "Campervan Culture" installation video. The top of the shield is a tight fit at first however being maliable it moulds in to the window frame well. I left the window wound up on the first day and the hot weather helped to mould it into the perfect fit with no cutting or gluing required. A little more pressure on the window winder and I can see that may be a potential mechanical problem for the motor on electric windows. The window rattle I had with window half down previously is almost non existent now. They look and work very well. Ill try to attach a pic.
Cheers Dave
/Users/renateleibmann/Desktop/IMG_3134.JPG
--- In Syncro_T3_Australia@yahoogroups.com, "Robert Dale" <rcdale@...> wrote:
> Skot
> Regards
> Bob
> Bob,
> issue immediately.
> Works well.
> Worked for mine.
> Skot
> Regards
> Bob
Thanks!
Enter your vote today! A new poll has been created for the Syncro_T3_Australia group:Can you see the attached photos to this post on 01/12/2015? 25667 Small Car Sump - Suby ej25 engine I attached and downloaded 2 photos to the post but for me they are nowhere to be found. PKCreated by: kestelp
Thanks!
Saw the sump photo this morning nice not sure if I looked at them in my email though
but it appears the photos are not going to the photos folder on the forum as they used to. ?
Loud and Clear.
Syncro_T3_Australia@yahoogroups.com ]
Sent: 01 December 2015 14:00
Created by: kestelp
1. Yes
2. No
Thanks!
There are no attachments visible in the E-mail,
and
I do not know where to look on the web site.
--Original Message Text---
From: 'Leslie Harris' leslieharris@optusnet.com.au [Syncro_T3_Australia]
Date: Wed, 2 Dec 2015 09:40:59 +1100
v\:* {behavior:url(#default#VML);}o\:* {behavior:url(#default#VML);}w\:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}st1\:*{behavior:url(#default#ieooui) }
Loud and Clear.
Created by: kestelp
1. Yes
2. No
+ Add Options
Thanks!
