Gday Ralph,
Ok good stuff .... does look to be quite doable then eh.
Just a couple of points then please.
To further clarify the power supply for the digital clock then. Is there
or is there not a 1 or 2 wire power lead coming from the blue printed
circuit and the lead has a plug on its end to connect onto the clock? If
so, does this form an integral part of the cluster wiring so it should
be there in place anyway? Or if not, it must then be part of the
vanagons wiring harness, in which case I need to have supplied that same
end of lead plug to connect the clock. Sorry, still confused on that
bit.
As far as the OXO advisory light goes, I believe we don't have the
necessary device that the OXO light is connected to ... its on US
vanagons but not Oz syncros. It's to do with periodic warning for oxy
sensor replacement. Our Oz syncros are far more sophisticated than that.
We wait till they start gasping and belching etc., then we replace the
oxy sensor.
There still is a demand for US mph speedos on ebay, so when you remove
it, flog it off on ebay back to the states.
Cheers and thanks Ralph. Too bad it's a bit too hard ferrying our
syncros across the ditch to visit you guys eh.
--- In
Syncro_T3_Australia@yahoogroups.com, "Ralph Roden" <rrmoss@...>
wrote:
> Ken,
> Yes the LHD "Fasten Belt & Brake" was swapped over for the RHD "Park
> Brake & Brake" module, I changed the blanking plate for the spare
> defogger switch (future spot lights?)
> The digital clock is wired in to the printed blue circuit where it
gets
> it's power from the red wire.
> The RHD Oz Syncro plug fits straight into the LHD socket of the
cluster.
> The plastic cover sheeting did not come with the cluster I used the
old
> one.
> Tacho worked straight off (I did follow the green coloured tacho wire
> from the dash to the coil to make sure)
> I've always had Tacho's on my vehicles and couldn't drive without
> knowing the engine revs, especially with such a quiet motor.
> The only thing I haven't got working is the OXO indicator which could
be
> the sensor or a bulb?
> I didn't have to do any extra wiring as suggested by the Oldvolkshome
> article.
> I still need to change the Speedo over.
> The following is correct for both of my clusters.
> Hoping this helps.
> Regards,
> Ralph
> -----Original Message-----
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ken
> Sent: Sunday, 3 May 2009 9:21 p.m.
> Subject: [Syncro_T3_Australia] Re: Vanagon instrument cluster ..
fitting
> issues
> Gday Ralph,
> Thanks for responding ... much appreciated. Yes I already had that
> oldvolkshome article and hoped our Oz clusters, being newer, wouldn't
> need such gymnastics. Just a few follow q's if you don't mind please.
> On the LHS, is it the case you simply parted out the Seat Belt/Brake
> Warning Light module from the Vanagon cluster and installed in its
place
> your own existing Parking Brake/Brake Warning Light module. No other
> mods required for this?
> On the RHS, there is an extra switch in the Vanagon cluster ... Rear
> Window Defogger switch. Did you find an alternate use for that switch?
> The Vanagon digital clock needs to be connected to its own power
supply
> plug connector and 2 wire feed. Is it correct this particular 2
> connector plug and wiring isn't in our Oz syncros, meaning you had to
> procure this plug connector and then wire in a power feed? Is it a
> common plug type available here?
> The translucent plastic sheet protective cover that lays on top of the
> cluster ... did it come with your vanagon cluster or was it missing?
> The tacho worked straight off? .... no extra wiring needed?
> Do you find having the tacho worth all the trouble and expense ...
> buying OS and shipping costs?
> Any other issues I haven't included? Thanks a lot Ralph.
> --- In Syncro_T3_Australia
> <mailto:Syncro_T3_Australia%40yahoogroups.com> @yahoogroups.com,
"Ralph
> Roden" rrmoss@
> wrote:
> > Hello Ken,
> > I brought a cluster from TheSamba.com
> > http://www.thesamba
> <http://www.thesamba.com/vw/classifieds/detail.php?id=623053>
> > complete with the circuit ribbon and plug advertised for an 86 to 91
> > vehicle.
> > I downloaded the following
> > http://www.oldvolks
> <http://www.oldvolkshome.com/late_van_cluster_install.pdf>
> home.com/late_van_cluster_install.pdf expecting to
> do
> > some rewiring, but when I checked all the wire colours which all
> matched
> > and after plugging in, everything also worked except the MPH Speedo
> > which read fast i.e.; off the clock at 80kph
> > regards,
> > Ralph Roden
> > NZ Syncro
> <mailto:Syncro_T3_Australia%40yahoogroups.com> @yahoogroups.com] On
> Behalf Of Ken
> > Sent: Saturday, 2 May 2009 8:56 p.m.
> @yahoogroups.com
> > Subject: [Syncro_T3_Australia] re: Vanagon instrument cluster ..
> fitting
> > issues
> > Gday ALL,
> > Just doing some homework so I can make an informed decision whether
or
> > not to decide on this project.
> > Is there anyone here in Oz who has physically done this changeover,
> can
> > remember how things went and are prepared to answer a few
installation
> > queries I have please. Thanks.
> > Cheers.
> > No virus found in this incoming message.
> > Checked by AVG - www.avg.com
> > Version: 8.5.287 / Virus Database: 270.12.2/2074 - Release Date:
> > 05/01/09 17:52:00
> Version: 8.5.320 / Virus Database: 270.12.2/2074 - Release Date:
> 05/02/09 14:23:00
