rear wheel bearings
Hi,any one else replaced rear wheel bearings more than once during ownership of their vehicle?
I know of T3 Kombi to have 400+ and never even heard a murmur from the rear bearings.
I replaced the nsr today,I only did the both sides 2 or 3 years ago.I had a growl coming from that side,that changed pitch when braking,in and out of gear.
The inner felt a little gritty.Hard to test the outer.
Its got me thinking....
Faulty bearing?in-correct install?driving conditions?worn axle?worn bearing hub?in-correct off set????Surely there is other Kombi running around with different off-sets and their not changing rears bearings every couple of years.
Any one have any theories?
BTW the nut was tight.
BenC
Hi BenC,  changed mine at approx 300 . Now at 400 Th no complaints coming from the rear yet.
Could be a faulty one , after all humans are in charge of manufacturing. Sorry, no other explanation. Hart
Sent from my iPad
BenC
Hi Ben, mine's got 475 on it & never been changed. Littlle bit of play but not noisy. Have had big tyres on for most of its life & the last 150 k with et 25 wheels. I think German quality might not be what it used to be. Eddie.
> BenC
That’s presuming that the bearings are in fact German.
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of eddie
Sent: 15 April 2013 20:38
Subject: [Syncro_T3_Australia] Re: rear wheel bearings
Too much sand driving Ben
BenC
Skot,Sand driving,doubt it.There was no sand in the grease,grease looked brand new,still coloured.When I said gritty,I didnt mean sandy,just not as smooth as I thought it should be.
Corrugated roads is what I think wears them out if anything,it was after I drove the Port side of Plomer and Maria River Road last time that I rekon stuffed them,didnt do it last year but still did some shorter corrugated roads,but the noise only started a few weeks ago,long after I had returned.
I am going with faulty bearing or damaged whilst I installed it,fitting the outer is a little tricky although I think it was the inner that was noisy,who knows.
I am sick of working on this bloody thing on my day off,cant wait for a newer car!!
BenC
--- In Syncro_T3_Australia@yahoogroups.com, Mr Scott Pitcher <spbconsulting@...> wrote:
> > rear bearings.
> > and out of gear.
> > BenC
Ben,
Did you use the double lip seals or the single lip seals?
> BenC
251 419 831A
Should be the same left or right, power or manual, 4WD or 2WD
Try Just Kampers or Mick Motors.
To:
<Syncro_T3_Australia@yahoogroups.com>
Cc:
Sent:
Tue, 16 Apr 2013 16:43:12 +0930
Subject:
[Syncro_T3_Australia] Query re steering boot?
Could someone please enlighten me about the correct name for the rubber part in this attached photo?
Is it the steering rack boot/bellows or the tie rod boot/bellows?
Am I correct in assuming that left and right are the same.
Does it make any difference to the part if I have power steering.
One of mine is damaged and I would like to replace both
Thanks for your help
Peter Leolkes
Phil,not sure didnt take much notice of seals except they were in good nick.
BenC
--- In Syncro_T3_Australia@yahoogroups.com, "hdvwoc" <plander@...> wrote:
> Ben,
> > BenC
Phill, isn't that the fronts? I have used generic single lip seals on the front hubs. Never seen rear seals that differ from the oem design. Ben, there are a lot of crap bearings around. Your right in that German made usually is good. Some other countries that still make good bearings are Japan, Spain and eastern Europe. The spacer is critical. Did you have play after you torqued  the nut?
& nbsp;
Sent: Tuesday, 16 April 2013 7:11 PM
BenC
--- In mailto:Syncro_T3_Australia%40yahoogroups.com, "hdvwoc" <plander@...> wrote:
> Ben,
> --- In mailto:Syncro_T3_Australia%40yahoogroups.com, "Ben" <bencroft96@> wrote:
> > BenC
Hey Greg,thanks.Yeah they was and still is some play.
Phil, I think they were a fat lip seal.
BenC
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> From: Ben <bencroft96@...>
> Â
> BenC
> --- In mailto:Syncro_T3_Australia%40yahoogroups.com, "hdvwoc" <plander@> wrote:
> > Ben,
> > Phill
> > > BenC
BenC,
Have a look at my e-mail dated  9/01/2013 Rear wheel bearings
BenC
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> BenC
> > Ben,
> > Phill
> > > BenC
I wouldn't use them.
Aren't they for the South African 2WD?
BenC
Thanks for your prompt response.
Greatly appreciated.
Imparts at MILE END here in Adelaide can get them overnight for $24 for 2 which suits me.
All the best
On 16/04/2013, at 5:02 PM, plander@optusnet.com.au wrote:
251 419 831A
To:
Cc:
Sent:
Subject:
Peter Leolkes
Make sure they are suppling the genuine style with the large outer opening. If they  supply generic ones with a small hole you will have to remove the tie rod from the tie rod end and will need a w/alignment. Greg E
Sent: Wednesday, 17 April 2013 2:56 PM
Subject: Re: [-Disarmed-] Re: [Syncro_T3_Australia] Query re steering boot?
All the best
251 419 831A
To:
Cc:
Sent:
Subject:
Peter Leolkes
They are supplying ones with the part number 251 419 831A so I presume they will be genuine.
i'll know tomorrow
Peter L
All the best
251 419 831A
To:
Cc:
Sent:
Subject:
Peter Leolkes
Thanks Theo,I remember reading that back then and thinking,yeah I am in spec.
BenC
> BenC,
> Theo
> >BenC
> >--- In
> ><mailto:Syncro_T3_Australia%40yahoogroups.com>Syncro_T3_Australia@yahoogroups.com,
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > Â
> > > From: Ben <bencroft96@>
> > > To:
> > > Â
> > > BenC
> > > --- In
> > > > Ben,
> > > > Phill
> > > > --- In
> > > > > BenC
Phil,I thought they were from Antartica.
BenC
> Â
> BenC
