On Thu, Jan 21, 2016 at 1:07 PM, Peter Leolkes pleolkes@bigbutton.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Hello fellow Syncro lovers
My Van has now been off the road for a record three weeks.
After replacing several components my hopes were high as the van went without a hitch for a couple of days and then the same problem returned.
In my quest to solve this intermittent engine cut out/no spark problem, now I am trying to get hold of the relay that is in the black box above the coil. Not the fuel pump one, the other one for the ECU etc. Relay Part Number 321.919.505A.
From somewhere in Australia. I can get it from VAN Cafe but the cost of freight ($36 US) is more than the cost of the relay.
Also I am looking to get hold of a working ECU. Has anyone got one that I could borrow/hire to see if that is my problem?
Alternatively, I have been looking at purchasing one. As per attached. Does anyone know of any Australian based suppliers of rebuilt s/h ones?
I noticed that there is a significant variation between costs of ECUs from Go Westy, Van Cafe and some others.
What might be the reason for that?
I would be grateful for any assistance.
Thank You
Peter Leolkes
'89 Syncro.
Adelaide
0457 822 453
--CheersPaul DumaisAerospace Engineer
From: "Paul Dumais paul.d.dumais@gmail.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Date: 21/01/2016 2:08 PM (GMT+10:00)
Subject: Re: [Syncro_T3_Australia] Relay and ECU
Thank You
Peter Leolkes
'89 Syncro.
Adelaide
0457 822 453
On 21/01/2016, at 4:22 PM, unclekenz unclekenz@hotmail.com [Syncro_T3_Australia] wrote:Hi Peter,ECU ... probably best if you stick with the later "D" version as used in OZ.Join OZ kombi clubs and ask .... some members dismantle T3s from time to time.Borrow from someone or else buy a local VW magazine from a newsagent, check the advertising for service/parts sources.Tried local wreckers and independent vw service businesses?http://www.thesamba.com/vw/classifieds/search.php?submit=yes&type=text§ion%5B%5D=57&keywords=ecuhttp://www.van-cafe.com/hom e/van/page_1126_750/cooling-fan-relay-88-thru-91-ecu-relay.htmlFor shipping small items (up to 4lbs total weight) from Van Cafe, first email them an enquiry re shipping quote via USPS First Class Mail service instead. Should be cheaper.Good luck. Cheers.Ken
I saw some ECU's at Stokers last month.On Thu, Jan 21, 2016 at 1:07 PM, Peter Leolkes pleolkes@bigbutton.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Hello fellow Syncro lovers
Thank You
Peter Leolkes
'89 Syncro.
Adelaide
0457 822 453
Peter,
I have found it next to impossible to pin anyone down on the question of what is done to constitute a ‘rebuilt’ ECU. When I first got my Syncro, there was a question about the function of the ECU. It was sent to a place in Melbourne that specializes in ECUs and charged plenty just to look at an ECU. Mine came back accompanied by a “test report” that said absolutely nothing. It did not say if any fault had been found and, if so, what had been done about it. All it had was a series of boxes with ticks in them. Nonetheless, the bill was eye-watering!
So far, I haven’t found any answers that are anything more than sales gobbledegook.
A question to members.
Both Van Cafe and Go Westy claim that their ECUs are REBUILT.
Yet Go Westy's price is US$780 (incl. US$400 core charge) and Van Cafe's price is US$350 (incl. US$125 core charge).
Why the large discrepancy? Any ideas?
Thanks again for taking the time Ken.
Peter Leolkes
'89 Syncro
ADELAIDE
From: "Peter Leolkes pleolkes@bigbutton.com.au [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Date: 24/01/2016 12:34 PM (GMT+10:00)
Thank you for these suggestions Ken. Greatly appreciated.
Thank You
Peter Leolkes
'89 Syncro.
Adelaide
0457 822 453
Peter,
Peter Leolkes
'89 Syncro
ADELAIDE
Peter,I have found it next to impossible to pin anyone down on the question of what is done to constitute a ‘rebuilt’ ECU. When I first got my Syncro, there was a question about the function of the ECU. It was sent to a place in Melbourne that specializes in ECUs and charged plenty just to look at an ECU. Mine came back accompanied by a “test report” that said absolutely nothing. It did not say if any fault had been found and, if so, what had been done about it. All it had was a series of boxes with ticks in them. Nonetheless, the bill was eye-watering!So far, I haven’t found any answers that are anything more than sales gobbledegook.LesA question to members.Both Van Cafe and Go Westy claim that their ECUs are REBUILT.Yet Go Westy's price is US$780 (incl. US$400 core charge) and Van Cafe's price is US$350 (incl. US$125 core charge).Why the large discrepancy? Any ideas?Thanks again for taking the time Ken.RegardsPeter Leolkes'89 SyncroADELAIDE
Jon Bartlett
0424006192
On 24 January 2016 at 4:39:07 pm, Peter Leolkes pleolkes@bigbutton.com.au [Syncro_T3_Australia] (syncro_t3_australia@yahoogroups.com) wrote:
You are probably aware of GoWesty definition of 'rebuilt' as expressed on their web site."Our rebuilt ECU's are not just wiped down, tested, and labeled. We have found from experience what commonly goes bad in these suckers, and they are fixed to better than new. ALL old, brittle original solder on EVERY internal component is removed and re-soldered. Common failure electronic components, whether they test good or bad, are replaced. Then the unit is tested on a test bench. We are so confident in this product, and feel it provides enough added reliability that every Vanagon we sell includes one of these suckers."Which I guess can be described as sales gobbledegook.I have asked Van Cafe to let me know what they do to the ECUs to rebuild them and am awaiting an answer.I keep reading that at times the soldering in the ECU fails and although invisible to the naked eye causes the ECU to intermittently malfunction.I am assuming that to rebuild would include re soldering all joints inside the ECU. I haven't looked inside one so have no clue what it looks like.RegardsPeter Leolkes
On 24/01/2016, at 1:43 PM, 'Leslie Harris' leslieharris@optusnet.com.au [Syncro_T3_Australia] wrote:
Peter,
Peter Leolkes
'89 Syncro
ADELAIDE
Peter,
I did read that earlier but it is a bit on the vague side. They make much of the fact that they re-solder everything but that just isn’t a major issue with today’s electronics. It was an issue before the days of pin point soldering and it was usually caused by the thermal expansion differential between dissimilar metals.
They don’t say what they are testing against and there is no mention of a warranty, so there is not a lot of information to work on.
Syncro_T3_Australia@yahoogroups.com ]
Sent: 24 January 2016 16:38
Relay and ECU
Thank You
Peter Leolkes
'89 Syncro.
Adelaide
0457 822 453
