I have a need to remove the dash in my T3 to get to all the wiring behind. I wondered if anyone had any detailed instructions, or experience in doing this they would be willing to share?
Thanks in advance,
Thanks in advance,
On Tue, Aug 28, 2018 at 12:31 PM, lepews@me.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Hi all,
Thanks in advance,
--Head OfficeUnit 2, 1472 Boundary Road Wacol,Qld, 4300 AustraliaPh: +61 7 3879 3005US Office3388a Commercial AveNorthbrook IL, 60062USAOffice: +1 224 501 9001
Not difficult, but time-consuming - put aside at least a day for the project, or possibly two if you need to repair bodgy wiring. Photograph each step, place parts in labelled bags, and order any parts that you think you might need in advance.
It's a good opportunity to add any extra accessories like additional power outlets, a headlight wiring upgrade, and additional gauges. A voltmeter is a good idea if you are considering camping 'off the grid'.
Also a good opportunity to replace or recondition the clutch and brake master cylinders, and consider fitting the bigger BMW brake booster.
The instrument cluster is fragile and often breaks at the screw attachment points. I believe gowesty makes a repair kit but it is simple to fabricate your own repair.
They also make a nifty overheating alarm, which is cheap insurance for a thirty-year old classic with 18 coolant hoses and numerous plastic components in the cooling system.
Don't forget to check and clean every electrical connection you can get at, including the many earth connections - they are the source of many electrical issues. Check each wire connection individually as they sometimes partially fracture where the wire is crimped to the connector.
Tag and label any non-factory wires. It will save time and money if you ever have to call in an auto-leccy.
enjoy!
On 30 Aug 2018, at 6:44 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Great write up Roger.
Also, this video from Go Westy gives a step by step instruction of the process.
https://www.youtube.com/watch?v=FLIsH2yqhoo&feature=youtu.be
Worth a watch as they have good tips.
ScottNot difficult, but time-consuming - put aside at least a day for the project, or possibly two if you need to repair bodgy wiring. Photograph each step, place parts in labelled bags, and order any parts that you think you might need in advance.It's a good opportunity to add any extra accessories like additional power outlets, a headlight wiring upgrade, and additional gauges. A voltmeter is a good idea if you are considering camping 'off the grid'.Also a good opportunity to replace or recondition the clutch and brake master cylinders, and consider fitting the bigger BMW brake booster.The instrument cluster is fragile and often breaks at the screw attachment points. I believe gowesty makes a repair kit but it is simple to fabricate your own repair.They also make a nifty overheating alarm, which is cheap insurance for a thirty-year old classic with 18 coolant hoses and numerous plastic components in the cooling system.Don't forget to check and clean every electrical connection you can get at, including the many earth connections - they are the source of many electrical issues. Check each wire connection individually as they sometimes partially fracture where the wire is crimped to the connector.Tag and label any non-factory wires. It will save time and money if you ever have to call in an auto-leccy.enjoy!--
Thanks Scott.
Much easier when you see the video.
Also, this video from Go Westy gives a step by step instruction o f the process.
The instrument cluster is fragile and often breaks at the screw attachment points. I believe gowe sty makes a repair kit but it is simple to fabricate your own repair.
enjoy!
Arne that's brilliant thank you!
Now to be a real PITA, is there a trick to removing the difflock console? I remove the 2 screws and 90 degrees brackets underneath, but it's not budging? I only have 1 difflock knob fitted, for the rear axle.Thanks in advance,Gaetan
On 31 Aug 2018, at 18:04, Arne kleinersyncro@yahoo.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
No worries Gaetan!For the Difflock console, it‘s just the screws you did remove already. Did you unscrew the knob too?Cheers Arne
Am 31.08.2018 um 19:38 schrieb lepews@me.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>:Arne that's brilliant thank you!
Duh! That would explain it.. does the knob itself just unscrew anticlockwise or does it have a retaining screw?
Sent from my iNuke
No worries Gaetan!
For the Difflock console, it‘s just the screws you did remove already.. Did you unscrew the knob too?
Cheers Arne
The diff lock knob just unscrews anti clockwise.
Easy as.
On 31/08/2018 8:08 PM, Gaetan Schurrer lepews@me.com [Syncro_T3_Australia] wrote:
Sent from my iNuke
No worries Gaetan!
Cheers Arne
Hi Roger and ALL,
re: "The earths (brown wires) all congregate on a round junction screwed to the firewall close to the passenger's door, behind the glovebox."
and
re: "Don't forget to unscrew the union from the firewall to clean the screw and screw-hole."
In my view a word of caution is prudent here, concerning removal/maintenance of the round junction (cluster) fastened to the sidewall to the left of the fuse box.
Some time ago I remember Graham Adams telling me the trouble he had with removing the screw that holds the cluster in place. It was really tough, like as if it shouldn't be removed, and in hindsight, wished he hadn't done so.
Afterwards, I also was keen to check/clean all earth connections in that area, and likewise, I found the screw to be impossible to remove, so I chose to leave it alone, instead just checked/lubricated all connectors attached to the cluster.
Now in the past there has been some talk about earthing clusters such as this one that upon assembly in the factory, they go through a special process that in effect provides a special bond to the body that ensures a permanent bond for maximum electrical continuity ... provided the cluster/body connection is not compromised .. ie ... separated for reasons of inspection and cleaning.
So unless someone has something to say with veracity to the contrary, I in the meanwhile would suggest caution about removing the cluster. If anyone is still concerned about it, at least first check continuity through the cluster/body joint with a multimeter, before deciding or not to separate it.
LePewSonics
Gaëtan Schurrer
PO Box 285 Claremont WA 6910 Australia
+61 426 813 466
skype: lepews
On 31 Aug 2018, at 8:14 pm, Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Hi Roger and ALL,re: "The earths (brown wires) all congregate on a round junction screwed to the firewall close to the passenger's door, behind the glovebox."andre: "Don't forget to unscrew the union from the firewall to clean the screw and screw-hole."In my view a word of caution is prudent here, concerning removal/maintenance of the round junction (cluster) fastened to the sidewall to the left of the fuse box.Some time ago I remember Graham Adams telling me the trouble he had with removing the screw that holds the cluster in place. It was really tough, like as if it shouldn't be removed, and in hindsight, wished he hadn't done so.Afterwards, I also was keen to check/clean all earth connections in that area, and likewise, I found the screw to be impossible to remove, so I chose to leave it alone, instead just checked/lubricated all connectors attached to the cluster.Now in the past there has been some talk about earthing clusters such as this one that upon assembly in the factory, they go through a special process that in effect provides a special bond to the body that ensures a permanent bond for maximum electrical continuity ... provided the cluster/body connection is not compromised .. ie ... separated for reasons of inspection and cleaning.So unless someone has something to say with veracity to the contrary, I in the meanwhile would suggest caution about removing the cluster. If anyone is still concerned about it, at least first check continuity through the cluster/body joint with a multimeter, before deciding or not to separate it.Cheers.Ken
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of Roger Bayley gullyraker53@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>
Sent: Friday, 31 August 2018 9:20 PM
Subject: [Syncro_T3_Australia] Re: removing the dashYep, you have to remove the diff-lock panel first, before removing the plastic console by spreading the tabs outward. It took me a while to work it out myself, but simple when you know how.You don't have to remove the dashboard first..If you are only worried about fixing the earths and wiring up a new power outlet, you don't need to remove the dashboard at all. The earths (brown wires) all congregate on a round junction screwed to the firewall close to the passenger's door, behind the glovebox. Just remove the glovebox lid by bending the flexy plastic prongs on each sid so it drops down, and clean all the earth connections. Don't forget to unscrew the union from the firewall to clean the screw and screw-hole.Removing the glovebox will also give you access to the fusebox and relays.You can access most of the wiring this way, but that damn aerial lead for the stereo is still a bugger to get at unless you remove the instrument console.I fitted a couple of power outlets at each end of the top of the dashboard, which can easily be reached from underneath without removing any hardware. These work well because the cigarette-lighter plugs are held in by gravity - they don't rattle out - so your GPS doesn't stop working on corrugated roads. Solves the problem of dangling wires.Another option is to fit one of the multiple consoles that are available at S*****Cheap, which can accept any combination of power plugs and gauges.The only reason I had to remove my dashboard was to fit the air-con, which was hardly worth the effort anyway.Cheers.
