Running over-rich, blowing black smoke
Thought I would share the learning curve ... gave the van it's annual refurbishment before the rego check a few months ago, and fitted new temperature sensor and O2 sensor.
Has covered several thousand km since then with no issues.
Day trip down to the coast last week, ran perfectly until cruising along the Princes Highway at 100 km, started to run a bit rough, lost some power, noticed in the rear-view mirror that black smoke was billowing out the exhaust.
Pulled over, engine idling roughly, switched off, restarted half a minute later - running perfectly.
Rejoined the highway, after a couple of minutes the symptoms returned.
Pulled over, lifted the engine lid, everything looked ok, suspected the Throttle Position Switch, disconnected the plug, started up, ran perfectly, congratulated myself, only for it to happen again a few minutes later.
Re-connected TPS, removed Fuel Pressure Regulator, and replaced it with the spare.
Ran well for a couple of minutes.
Finally bit the bullet and removed the nearly-new O2 sensor and replaced it with the old one.
Cured.
Now running better than ever.
Hi Roger,
Reminds me the symptoms you describe are much the same as experienced by Hartmut heading back to Port after the VW Macksville weekend in August. It was quite a struggle but he did at least finally manage to make it home. Happened all of a sudden for no plausible reason. Not sure if the actual culprit was identified, though a lot of remediation work was done to cover all possibilities, to finally sort it.
Begs the question, was there dissimilarities between the old and new O2 sensors?
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of gullyraker53@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>
Sent: Thursday, 13 December 2018 10:59 PM
Subject: [Syncro_T3_Australia] Running over-rich, blowing black smoke
Cured.
My 2wd auto that I just bought has a similar issue but is running nicely with the O2 sensor unplugged.
Wife drove behind me to the panel shop with it and said it was running very rich (smelly).
Where to get a good O2 sensor????
< span>Re-connected TPS, removed Fuel Pressure Regulator, and replaced it with the spare.
Cured.
Thanks Ken for remembering except that it wasn't Macksville but Old Bar 2 seasons back. This makes it even more  interesting as those dreaded symptoms never re occured.
After the initial fix late at night by Arne the Tristar performed faultlessly and to be honest never again missing a single beat.
What's even more interesting is the consumption as it is down to
12.6 l/100km and that is town traffic. I had the throttle box rebuilt by Nils, that might contribute to tbe consumption also.
Now, almost forgetting to mention what we did that night in the dark, Arne cleaned EVERY one ground connect / earth connecton there is.
Sent from my Samsung Mobile on the Telstra Mobile Network
From: "Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Date: 14/12/18 12:55 am (GMT+10:00)
Subject: Re: [Syncro_T3_Australia] Running over-rich, blowing black smoke
Hi Roger,
Cured.
Yes, gremlins in old EFI systems can be a challenge. My auto died suddenly a couple of years ago. Re started fine, drove 500m, bucked a couple of times and died again and never re-started. Towed it home and left it parked as I didn't really need it running. Tried a few times over the following few weeks and would not start. It sat for a month or two before I started measuring every part of the EFI system for issues, never found any. Re-connected everything up and has been running fine ever since! I can only assume a bit of corrosion on one of he terminals somewhere.  (it's not a regularly driven car, just around the block every now and then to keep it running)
From: "Ken Garratt unclekenz@... [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Hi Roger,
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of gullyraker53@... [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>
Cured.
Regarding your question about the O2 sensor Ken, it wasn't the original. I replace them every year or two, along with the temp sensor.
last time I looked, the genuine sensors were NLA, and most vendors sell crappy generic 2-wire sensors or a sensor with the wrong electrical connector that needs to be spliced to the existing connector.
There has been a lot of discussion on his issue over the years. After a fair bit of research I paid big money to import the 'right' part, but it wasn't. Will have to check the p/n and let you know what it was, so no=one else gets caught.
Will do a bit more research and get back to you with the result.
Meantime, has anyone out there found a source for an O2 sensor that works?
Hi Roger,
I believe I know a quality model, is 3 wire of correct length & correct connectors. Definitely not from Brazil, China etc.
But I'll do some more comparative research too in the meanwhile.
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of Roger Bayley gullyraker53@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>
Sent: Saturday, 15 December 2018 10:09 PM
Subject: [Syncro_T3_Australia] Re: Running over-rich, blowing black smoke
Thanks Ken.
The Bosch Book says that Oxygen sensors (or Lambda sensors) are used to measure the mixture of fuel and oxygen fed to the engine to achieve the correct ratio of 14.7:1 at operating temperature, and a little richer when starting from cold. They communicate this information to the ECU which, after taking engine temperature, throttle position and other variables into account, decides how long to open the fuel injector nozzles;
Oxygen Sensors are used to detect the amount of excess oxygen in the exhaust gas after combustion to indicate the relative richness or leanness of mixture composition.
The oxygen sensor contains two porous platinum electrodes with a ceramic electrolyte between them. It compares exhaust gas oxygen levels to atmospheric oxygen and produces a voltage in relation to this.
The voltage produced by the oxygen sensor will be typically as small as 100 mV [lean] up to a maximum of 900 mV [rich]. An active oxygen sensor would cycle between these two points as the engine management system drives the mixture rich and lean to achieve an average sensor voltage of ~465mV. This would represent the mixture ratio of 14.7:1.
This type of operation is normal for a “narrow band” style of sensor; these are used for the majority of standard vehicle applications.
The O2 sender that I removed from my car back in 2002 is a genuine VW unit P/N 025 906 265 B, date-stamped 04/1991, made by Bosch, and it appears that the Bosch P/N is 0 258 003 031. It has 3 wires 60cm long - two white wires to a dual plug, and one black wire to a single plug.
It appears that Bosch no longer manufactures the part. Googling the number merely returns a heap of generic sensors that are made to suit multiple vehicles, usually without the correct wiring connections. Feedback from other sites is that they don't work very well.
Many purveyors of cheap and nasty equiptment have tried to foist 2-wire senders on to the market, or 3-wire senders with incorrect connectors, or no connectors at all, which have to be spliced to the factory wiring.
A well-known local purveyor is advertising what looks (in the photo) like a generic 2-wire unit with 3-wire connectors at a ridiculously high price, so beware. It is advertised under the Bosch part number - check if it is genuine before you buy it.
The correct Bosch unit can be found under the VW P/N or the Bosch P/N 13931. Bosch also makes a generic part 1393 which will work at a pinch, but without the correct wiring.
The Bosch 025 906 265 B units are available at VanCafe and GoWesty, and the latter has a good technical rave on the subject. The ones I have used work well and have the correct connections, but the wires are twice as long as the original. This is not a problem.
The same sensors were used on some other VW models, Audi, Saab, Volvo and Ferrari in the '80's and '90's.
I will call Tooley's on Monday to see if they carry the Bosch units. Everyone needs to carry a spare under the seat, along with a 22mm spanner (there may not be enough room to use a shifter).
The faulty item that caused the problem on my van was a German-made Lowe 0 258 003 957. It looked the goods, but in practise it created a stumble when taking off from cold, but appeared to work well when warm, until the over-fuelling problem occurred after it had been fitted for several thousand k's.
The original item that replaced it is running reasonably well.
Bentley tells us how to check them with a multi-meter. That's the next job ....
Are their any electronic gurus out there who can make a 465 mV gizmo to plug in to the connecting wires to fool the ECU?
On this topic, I found the following O2 sensor from JK.
https://www.justkampers.com.au/025-906-265-b-lambda-sensor-t25-2100cc-1985-to-1992.html
Its a special order so it may take a few weeks to get it but it looks like the original.
On 16/12/2018 2:11 pm, Roger Bayley gullyraker53@gmail.com [Syncro_T3_Australia] wrote:
Thanks Ken.
Hi Roger,
My concern now with Bosch products is country of manufacture. Have they done the same as Meyle for example and also farmed off manufacture to the PRC. Many people I believe are now loathe to buy Meyle "inferior" parts.
Unlike your and my original oxygen sensors, clearly stamped "Bosch" and "Germany", the current crop of Bosch products have no markings at all as to the current country of manufacture, hence my hesitation now with Bosch products. As well, I  see retailers of Bosch oxygen sensors for example, no longer state in their advertising ... "Made in Germany".
Interesting then that when Rudi replaced my oxygen sensor years ago, he installed an NGK ... the same brand as the well acclaimed manufacturer of quality spark plugs made in Japan, certainly I for one prefer and use them.
I've had no problems since with my NGK oxygen sensor ... definitely not made in PRC.
Sent: Sunday, 16 December 2018 2:11 PM
Thanks Ken.
Thanks for your replies, Ken and Scott.
Ken, I would love to know the part number for your NGK unit, but I hesitate to ask you to crawl under the car with a wire brush and mirror to have a look. Will search the net instead. Does the engine runs sweetly? Much soot around the tailpipe?
Comments about Bosch are widespread. Many people complain that their coils ain't what they used to be.
Scott, from the photograph, that JK unit looks like a two-wire unit masquerading as a 3-wire. Might be similar quality to the High-Tension ignition leads that they sell ... friend of mine bought some, and then spent the next few weeks and handfuls of cash trying to sort out the misfire. Put the old leads back in - voila!
A new problem has emerged over the last couple of years - its now a lot harder to identify the difference between good quality and rubbish parts.
Roger.
Thanks for the tips Roger.
I though the photo showed 3 wires - two in the main block and one for the fibre optic connection (as I call it).
But is that what you get?
I have seen people advertise certain things with a photo and what you get is something totally different.
Who knows unless you try it out.
I'm sure they would refund if you weren't happy.
On 17/12/2018 12:59 pm, Roger Bayley gullyraker53@gmail.com [Syncro_T3_Australia] wrote:
Roger.
I bought an O2 sensor from Tooley's about 2 years ago and it was the correct Bosch Germany with correct wiring. Unfortunately I sold it with the Doka.
Another one on the same topic, not sure what else to check. Have not looked at the O2 sensor yet.
Hi Richard.
Have you tried the CO2 bypass screw adjustment?
The AFM’s come off the bench with plenty of variance from one copy to another, and the CO screw is just a final trim for the basic adjustment, depending on actual idle vacuum, etc. Also, the range of actual adjustment there is pretty small. So don’t be afraid of screwing around with it to get the mixture you need. The AFM is a stunningly crude device, in no way the delicate precision instrument most people seem to think it is.
That said, the range of the CO screw is 13 turns outward from bottomed out. If you want to start off at the midpoint of the adjustment range, run it to the bottom (gently), and back it out 7 turns. Keep count of the number of turns you move from there, so you can get back to center, or if you lose track just run it back down and count outward again. You can work in full turns for counting purposes; you’ll see little change in CO by partial turns anyway.
Hi Richard. Just a thought. Have you tried swapping the ECU? Hope you find the cause of this annoying issue. Peter
Thanks guy’s.
Peter, have not swapped the ECU, but was thinking I have been checking things individually, not at the ECU plug. So if there is a wiring issue I am missing that. I think that is my next step. But yes swapping ECU is a simple test.
Scott, understand on the AFM, but as it’s a sudden change , am thinking it’s not an adjustment, and as I’ve swapped out to an AFM I have run before, it’s not there. I do have one of the VW “vangon syndrome” fix cables, and have not tried taking that out.
The AFM’s are a funny device, across the few I have all have different outputs. Given I have tested them all on my old motor and they all ran fine, and all felt the same to drive and had the same economy over a couple of tanks. That said, the spring rate, and starting ohm’s are different on all. I’m guessing as you said they are crude, and the bypass screw makes up for these differences.
I have driven with the AFM and O2 sensor disconnected before just to see what happens, I think that (and checking some ground cables) will be the next step.
Also want to check the fuel pressure as the regulator is an old one.
Also this motor has been way down on fuel economy since I installed it (almost 2 years now), and after a few (half hearted) attempts to fix it didn’t resolve it, makes me think something was on the way out, and washing down the engine bay was the final straw for something.
Might be taking some time off work to try and find the issue!!
Been slowly double checking everything, and re-checking back at the ECU to confirm the wiring harness also.
AFM, Temp sender (1 and 2) check out, fuel pressure is in spec, Injectors have a nice spray pattern, and don’t leak (plus hold pressure in the fuel rail when off) I did not measure the flow rate, so might still do that.
The VW cable (for the AFM “vanagon syndrome”) affects the reading, so unsure if that is OK, so might give the van a run with that removed.
Pulled the plugs, very black as expected. Gave the ma good clean/checked gap, and confirmed a good strong spark at each.
Will keep checking a fe things over before firing it up again. Nothing stands out as wrong yet.
Big question though is how do you check an O2 sender? The book talks about checking with a Co2 sensor, which I do not have. The O2 sender was covered in a thick layer of soot , and unsure of its age. Would be nice to have a way to test it.
A few more things to check over before I give it a run again. If it’s still no good, will just start replacing bits and see what happens.
I had the same problem when the 02 sensor died on me once. Sudden loss of power, clouds of black smoke, rough running. Swapped it out beside the road and it ran fine again.
Check the wiring and connections first.
Thanks Roger, that is great to know. Just wish I had a way to check the O2 sender.
I’ll definitely check the wiring back to the ECU as well.
Interesting that the engine runs rough at idle as well, as it should disregard the O2 sensor at idle (with the throttle pos. switch).
Fun week end ahead testing for me!
