Hi there experts. I have rust in the seams on the left rear side. On investigation after recent rain (alt last) I found water lying in that compartment behind the left rear tail light unit. Quite a bit there and it's that bottom edge where the rust is appearing on the outside. Also a bit higher up in the vertical seam. I am wondering where the moisture is getting in. No point getting the seams fixed and an expensive repaint unless I can find where the water gets in. BTW, Ken had an idea to hide a spare key in this spot in one of those magnetic cases as you can get at it with a phillips head screwdriver in case you lose your keys. The key inside had nearly completely rusted away. Shows I have a problem.
Has anyone else had this issue? See photos.
Peter from Port
