Seeking Help Advice
Read with interest Anthony's trials and tribulations with his Syncro and the pits inspection. I can empathise with him on this one and some $2,000 later. I also concur from experience with Ken's summation about the pitfalls (pun intended) of buying unregistered and from interstate ($4000 and counting).
I'm seeking help from members. I live in an isolated area far from specialists VW mechanics. My one and only local mechanic is belligerent, frustrated and out of his depth in working on my syncro but I need to cajole and keep him onside in order to get my car in a condition that allows me to drive it some 500klms to a decent mechanic and have the necessary work done. ("no wonder the krauts lost the war when they built shit like this") is what I have to put up with.
Car starting and running moderately OK but having overheating problems. Takes ages to warm UP to temperature, approx 20 klms @ 80kph through hilly country to centre the gauge, but then continues to move progessively to the right of the gauge until I have to pull over and allow to cool down. Approx 30- 40 klms. Also on the few very cold mornings this season the red temp warning light keeps blinking even though the temp needle hasn't even moved off the cold marker.
Can members suggest a logical, step by step, one procedure at a time approach for my mechanic to perform to identify and rectify the problem. Already replaced the water pump, which wasn't the problem in the first place.
Michael
Thermostat maybe?
Sent: Monday, April 12, 2010 10:28 PM
Subject: [Syncro_T3_Australia] Seeking Help Advice
Michael
My problems dont sound as bad as yours. What have you spent 4k on?
Mines going back over the pits as soon as i can get it back there.
Whereabouts do you live?
good luck in fixing the problem.
Sent: Mon, 12 April, 2010 8:28:39 PM
Michael
Re Michael's issues ..
for the slow-to-warm up ....usually you think of the thermostat for that symptom. They commonly open too early and run too cool.  Good new german one is indicated, seems to me.
for mysterious overheating or running too hot ...
the normal path through that is pressure test for leaks, make sure t-stat is good, and consider if the radiator is removing heat like it should.
Eventually they just don't to that too well, so if its' 15 years old say .....you suspect the radiator for running too hot, IF ...IF ..everything else is working like it should.
What to be suspicious of for mysterious or inconsistent overheating or running to hot ...if you ever get this one ...semi-common too actually in waterboxer vanagons. If it ever seems to 'unbleed itself' .....like it'll run fine, then act up, you bleed out air and it's ok until it acts up again ..
and particularly if you get 'hot engine, stone cold radiator , like the main pipes are blocked, and it's not that, and it's not the thermostat or waterpump" ...then you have exhaust gases getting into the coolant at the heads or headgaksets.  Quite a common waterboxer cooling system failure mode actually.
What I really like to see a waterboxer vanagon do for a cooling system test, is be able to sit there idling ...until the radiator fan comes on ....then it goes off after a while, then comes back on again in a few minutes ....then back off etc.
that cycle indicates a lot of good things in my mind ...that it's full of coolant ( not much air in it ) ......that coolant is circulating, that the radiator fan sender and circuit is working, and that the radiator removes heat properly.
 I see that with the temp gauge sitting right at about 55 % on the temp gauge ...
I'm happy. And good heater performance....that is 'a working' waterboxer cooling system.
a common mistake or non-understanding ...like changing that waterpump hoping that would fix something, if that's what happened.
.........when there is overheating that's not understood , while driving...
and people see that the rad fan doesn't come on at idle ................some people diagnose that as why it runs to hot at speed.
Once the van is up to say 5o or 60 kph speed, it doesn't care if the rad fan is even on the van. The rad fan is only for when it's not moving through the air.
the normal order to sort though is ..
all external and internal coolant leaks, look for those and fix those.
thermostat - that it runs in about the right temp range. Too cool is not good.  Must run fully up to temp.  T-stat should be wide open at about 180 to 190 F ...whatever that is in C.
then radiator....it has to be able to remove heat well enough. Eventually they don't.
then radiator fan, should cycle off and on sitting idling on a warm day.
if all that is right, and it still is inconsistent, or unbleeds itself, or can't sustain running consistently and all the above is correct, then you think about head gaskets.
the little green o-rings that sit at the top of the barrels...
that keep coolant way from the metal combustion sealing rings between barrel and head ..
those little green o-rings get hard, brittle, and cruddy, in just a few years even.    It's not that uncommon for exhaust to get past the metal rings and green o-rings into the coolant, a tiny bit at a time, and intermittently even.
 when that happens....exhaust in the cooling system at the engine ...
it displaces the coolant, the w. pump can't push anything gaseous .....then you get  hot engine, cold radiator, no circulation. Like the main pipes where clogged, buy they are not.
  one semi-definitive test is to sniff the air space above the coolant in the pressure bottle for high HC with a smog sniffer probe. There's also a 'block tester' tool  that uses a fluid that changes color if there is exhaust in the coolant- as a test for this syndrome.
It takes a while for a newbie to wrap their mind around a syncro, working on it.  At first it's difficult for sure.
Sent: Monday, April 12, 2010 6:08 AM
Subject: Re: [Syncro_T3_Australia] Seeking Help Advice
Subject: [Syncro_T3_Australi a] Seeking Help Advice
Michael
That's a pretty comprehensive and helpful answer. Good luck, Michael! Sorry to hear the saga continues, and I hope you get that Syncro running properly soon without too much further expense. Quite an initiation you've had.
Francesca.
On Tue, Apr 13, 2010 at 7:35 AM, Scott Daniel - Turbovans <ScottDaniel@turbovans.com> wrote:
Michael
CALLING PETER KESTLE
Peter is based in your general area and might have knowledge of a mechanic who is not out of his depth.  I think that Peter works away from home a lot but believe that he checks on the group from time to time.
Michael, have you got a copy of Bentleys AND the Owners Handbook?  If not, let me know and I will get a CD in the post immediately. A copy of the parts list, known as ETKA, is also very useful because it illustrates all components and the order in which they are assembled.  Having this information gives you a head start when people refer to components that might be causing a problem..
Not coming up to heat is usually a thermostat jammed open; overheating can be a thermostat not opening.  I will look at the cooling system diagram later today and see if I can work out what might be happening.
You didn’t mention the radiator fan, which should come on when the needle gets into the right hand side of centre.  Is it coming on?
From: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Michael Rayner
Sent: 12 April 2010 22:29
Michael
Hi Scott
Thank you for an extremely thorough and extensive reply for advise to my problem re overheating of my Syncro. You have armed me with a modicum of confidence when I go in to do battle with my mechanic. I will follow your advise and start off with pressurising the system for internal and external leaks, then t-stat, then radiator.Lets hope that by then we have fixed the problem.
Do you think that the flashing temp warning light that comes on and blinks only first thing on a cold morning might indicate thermostat problems. It does this for the 2 klms I drive to my studio. When I return 2 hours later all is OK, no blinking light.
Interestingly, with more trips, the engine seems to be traveling a little further each time before getting too hot (3/4 over on the temp gauge). Could this have something to do with the engine being dormant for a few years. It only traveled something like 20 klms for 3 years after engine rebuild.The previous owner claimed he drove it down the street and back once a week to keep the engine lubricated.
When the mechanic  pulled the water pump off after much shouting and cursing he said the engine was stuffed because he thought there was corrosion in the block where the water pump is attached. Interestingly he replaced the pump even though the original was OK and put the engine back with a RWC
For interest sake how long does it take for your vanagon to attain the correct temperature running in hilly country at 80 klm p/h?
Once again thank you very much for taking the time to lend me some advice and your considered attention.
Michael
Sent: Tue, 13 April, 2010 7:35:30 AM
I'm happy. And good heater performance. ...that is 'a working' waterboxer cooling system.
and people see that the rad fan doesn't come on at idle ............ ....some people diagnose that as why it runs to hot at speed.
then radiator.... it has to be able to remove heat well enough. Eventually they don't.
Subject: Re: [Syncro_T3_Australi a] Seeking Help Advice
Michael
Anthony.
What I was agreement with Ken in regard to the pitfalls of buying interstate are the following
1. Transportation in bringing the vehicle back to your base. Cairns>Melbourne        $835.00
        Melb>Mallacoota petrol $$140.00
2. Temporary Registration to drive unregistered vehicle.  $50.00
3.  Road Worthy Certificate  $2400.00
4. Registration, Third Party Fees and new plates   $840.00
        TOTAL                         $4265.00.
When we see the original price of the vehicle  we tend not to see the hidden costs involved in getting it on the road. And more so the case if you foolishly buy on ebay, (ie moi,) and take the sellers word at face value. Buy locally  and pay the little extra or at least catch a plane and visually eyeball your intended purchase.
I was curious in your last posting that you put your car in "syncro mode"? Do you mean you put it in the "G" gear on a wet forcourt pavement. The beauty of the syncro system is that it doe's it automatically for you, you don't have to do a thing. Curious.
Michael
Sent: Mon, 12 April, 2010 11:08:26 PM
Michael
Hi Les.
Thanks for the advice. I'm going to follow Scott 'Turbovan's" course of procedures from his terrific response. I would appreciate that CD Les. Send it PO Box 144 Mallacoota 3892. Where does Peter Kestle live?. For interest sake, where is the thermostat located and what would b the best way of buying one if it comes to T-stat problem.
Michael
Sent: Tue, 13 April, 2010 8:42:00 AM
Subject: [Syncro_T3_Australia] Calling Peter Kestle
From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of Michael Rayner
Michael
Hi Michael, nice to read your words.
"Doing Battle" with your mechanics ...lol  !
I would hope that would be 'conferring with' , rather than anything contentious or anything like that.
( whole other topic ...but for sure ...'most' I could almost say ...
many, professional auto technicians are ..............oh, 'arrogant' let's say.  I've observed a tendency to jump to a diagnosis, insist on that repair, then back peddle and say 'you need that anyway, and now you need more' when things don't pan out like they thought they would with the first quick diagnosis.  Sorry to say, but 'most' car repair I see is not 100 % dead on the money.........the wrong thing done, something done incorrectly, etc. )
It's a perfectly normal indication for the red LED to flash in the temp gauge when you start the engine. It's a test feature for that warming light. It's  in the Owners Manual if you have that.  ( that light can have it's own weird symptoms at times though ...but what you describe is normal and good ) .  Not related to the thermostat in any way. not at initial start up.
  Should not do it for 2kms though !
My thoughts on that are either it is a little low on coolant at the pressure bottle  ( that light warns both of low coolant level in the pressure bottle, and of getting too hot ...if gauge gets up to say 75 % ....light should be flashing.  I don't really like that .....it can go off for either of two reasons ...and sometimes it's a matter of the level sensor itself in the pressure bottle, or the gauge and control unit for it circuit.  I've never had to really get into that part of it very much ......you can have gauge and warning light weirdness in the dash/electrical systems though. I've just never had to mess around with that part much at all.
Not being used very much is really rough on things.
Every time I take heads off a waterboxer engine...........and as far as I'm concerned *all* used waterboxer engines need new headgaskets ..
( unless it's pretty fresh of course ) I always find the small green o-rings at the top of the barrels hard, shrunk, cruddy etc.
< o-rings brought down a space shuttle .....o-rings are far from a perfect sealing system in my mind ) .
  Those o-rings are always worn out, lost their resilience etc.  They keep coolant away from the metal sealing rings.
It would make some sense maybe, that the warmer the metal parts get, and the longer it runs, the better it seals...
so don't take short trips !  lol.
the impeller face for the water pump is part of the engine block. Usually they are not corroded there. But if that surface is really bad, and is actually a Real Problem ....the engine block itself would have to be replaced.   But there is reasonable tolerance I think...
'some' corrosion there is ok as far as water pump performance is concerned, I think.
 Since corrosion was reported though ...
I can't tell you how many crusty, horribly corroded, pitted etc. waterboxer heads and head gaskets I've seen.
Hundreds of them.  Just white power where aluminum was.  Outer black rubber gaskets, pinched and split, or just 'disintegrating , like turning soft.
IF there is bad corrosion in the engine .....here's something to really watch out for.
When you go to unscrew the head nuts ......it's kinda scary how they feel. It's like the stud twists under the nut for the first half turn or so ...
then finally the nut breaks loose from the stud and unscrews.
  The stud is about 9 inches long under the nut .....where it screws into the case way down in there...
if the stud breaks off down there, you're in big trouble.
  Very difficult to deal with. The 'real repair' would be bare engine cases in a machine shop to repair the broken off stud area.
It would be possible to do it in situ to save your life maybe ...but not something that is easily done.
So be real careful if removing heads on a very corroded engine.
The barrels get stuck in the heads sometimes too ...there are tits or bumps on the sides of the barrels to pry against ....to separate head and barrels .....sometimes they're kinda stuck there.  You don't want to pull the cylinder barrels off the pistons.
At that point, many technicians would just insist it's new rebuilt engine time. ....if you are getting really severe corrosion and difficulty getting things apart cleanly.
I spent two hours just on one cylinder head nut once, maybe 3 hours ....felt like it didn't want to unscrew, but rather break off the stud down in the engine block.
I heated that nut, I used penetrating oil on it for days, ...did everything. Finally I drilled a hole down through the top of it, got penetrating oil into the threads that way, then finally got it off without damaging the stud. I might have been over-cautious on that one nut ...
but you really don't want any studs breaking off.
if your mechanics are arrogant or brutish .....and in a hurry or careless....well....I'm sure you follow.
don't know what an RWC is. 'real wheel carrier ?
a vanagon should get fully up to operating temp in about 15 minutes at the most.
Its' common for them to take a lot longer ....due to thermostat likely. It's common for the t-stat to fail in the direction of it not running warmly enough.  I see that all the time in vanagons.  A really nicely working on will go from say..........it's room temperature outside, to mid-range on the temp gauge in 15 minutes, even a little less. Like 10 km.....yeah, should be fully up to temp well before 10km @  80 kph.
The whole time it's not really up to proper running temp, more wear occurs. Short trips are really rough on cars.
Short downhill trips are really bad. I have seen a blown head gasket on a Suzuki Samurai ( small Japanese made jeep ) in only 35,000 km...
like 2 or 3 years.  Belonged to an old guy, he drove downhill to a coffee shop, stayed there all day, drove 8 blocks home. That's almost the only driving that car did - ate out the head gasket in fairly short order.
I hope it works out well on your van's cooling system issues !
And really .....we love them, and we manage to deal with the headgaskets on waterboxer VW engines...
but it really is a very joke head gasket design.
There's no other engine at all in the whole world with this silly converted-from-air-cooled 'two step' head gasket system.
All 'normal' cars have a flat bottomed head. Combustion sealing and coolant sealing are done between solid  flat surfaces.
Waterboxer is nothing like that.
Combustion sealing is by metal rings at the top of the barrel .....and that worked well enough in air-cooled boxer VW engines.
And if combustion leaked out there, so what ....little popping sound and some pressure escapes rather than driving the piston downward .
in a waterboxer, if that happens, it displaces the coolant and you get hot engine, cold radiator.
There is nothing about squeezing that metal ring between the aluminum head and top of the cast iron cylinder barrel that should especially seal, and the nuts are only torqued to 37 ft lbs.,  very little actually.
so that's the combustion sealing ....that sorta works.
now ..the coolant sealing .......
that is where it is really mickey mouse. In a regualr engine the head is held down with thousands of lbs of force .......between two flat surfaces with a 'real' head gasket - often layers of compressable material.
  In the waterboxer...
the only coolant sealing is by having the head fit down over the barrels 'just the right amount'....
just the right amout to compress the outer rubber gaskets 'just right'. Too much and they split and pince. Not enough ...and they can leak.
It can't work long term really.
The first time I ever dealt with this .... a new head leaked after about a year - I checked with everyone in the world ...finally a VW dealer technician told me ...........you put the bare head on without the rubber outer gaskets, measure that gap, and if it's too small or to big, you try another head ( ! ) .....Standardized automotive parts were invented in about 1918..........
there is no such thing as 'one head will work better, dimensionally speaking, than another"  in the automtive world normally ....
but it's that way in Waterboxer engines. It is possible to make dimensional corrections by mahcine work, but it's not easy or commonly done.
anyway ...hope you get it fixed !!
and we don't even know that you have head gasket issues yet of course .....but it's quite common.  Perhaps you're just fine in that area.
For a coolant mixture, I run a high quality conventional anti-frz ......
mixed 50/50 with tap water ....and I have never lived where the water was extra hard .....
and then I add macinist's oil...cutting oil, a water soluble oil ........a few cupfulls , Makes a fine rust inhibutor and water pump lubricant. Been doing that 20 + years to thousands of cars.  You can't take too good care of a waterboxer cooling system. It's the most delicate and attetnion-worthy  system in the whole van.
Sent: Tuesday, April 13, 2010 6:16 PM
Hi Scott
Michael
From: Scott Daniel - Turbovans <ScottDaniel@ turbovans. com>
Michael
> can
How about the thermostat is stuck open a litte?
Slow warm up.
Not open enough to cool properely.
