This post just to introduce myself. I have just joined your group, my name is Ian. I don't have a Syncro but have harboured a long term desire to do so. Now that I am semi-retired I would like to make it happen. I can see already that the group & it's history will be a most necessary resource. I currently have a T3 1990 Van(lined by a previous owner) with a rear bench seat conversion (so folds down to bed) also a LWB Delica. A Syncro would potentially replace both. I just missed a Telstra van on CarPoint which (still listed) is pretty much where I would like to start. i.e. restore van then fit-out step by step. Anyway that's my story (of a small part of it) and so on with the dream!
You have made the right choice, I used to have a Mits L300 4wd van a long while back because I couldn't afford a syncro - they were still fetching $30-$40K when I was looking first time. Before that I had a 2wd 73 kombi tin top and my dad had already bought a syncro.
I wanted a syncro really bad as the Mitso was a piece of crap.
Anyway, it seems like a natural progression of yours (as was mine) into a VW kombi syncro.
The ex-telstra van I saw on car point looked like areal mess that had never been looked after - which is a real concern for a high mileage vehicle. If they are serviced they run well for many kms.
Dont rush in and try out at least 2 vans before buying. Also look at what van suits your needs.
Hope the right vehicle finds you.
On 27/01/2013 5:06 PM, boxerm8 wrote:
Hi everyone,
another ex-Telstra van has appeared on Carsales:
http://www.carsales.com.au/private/details/volkswagen-transporter-1990-14200203?base=1216&vertical=Car&cr=4&eapi=2&__N=1246%201252%201247%201282%204294962746%201216&num=15&silo=Stock&Range=Year%3a1980%2c1992&sort=default
Looks a bit better than the last one.
Paul.
--- In Syncro_T3_Australia@yahoogroups.com, Mr Scott Pitcher wrote:
> Ian,
> a VW kombi syncro.
> Skot
> > Hi everyone,
http://www.gumtree.com.au/s-ad/birchgrove/campervan/vw-type3-syncro-4wd-campervan/1013590085
--- In Syncro_T3_Australia@yahoogroups.com, "paulhtravel" wrote:
> Hi Ian,
> Paul.
> > Ian,
> > a VW kombi syncro.
> > Cheers,
> > Skot
> > > Hi everyone,
I would at least go and have a look/ test drive the Sydney one - seeing you are in Sydney - maybe not to buy but at least get a benchmark of the $$ for what you get. Both have gas conversions so see where they have installed the tank and how much space this takes up.
Many Telstra workers did not treat their vans very well - so look closely for damage to panels.
I wouldnt expect miracles from the A/C in these things either - the Prestige system is not very reliable from what I have seen and the mounting brackets can cause a lot of damage to the engine case.
On 3/02/2013 2:13 PM, paulhtravel wrote:
and another...the ex Telstra vans are coming thick and fast at the moment:
> Hi Ian,
> Paul.
> > Ian,
> > a VW kombi syncro.
> > Cheers,
> > Skot
> > > Hi everyone,
Date: Sun, 3 Feb 2013 14:28:01 +1100
Subject: Re: [Syncro_T3_Australia] Re: Self introduction
> Hi Ian,
> Paul.
> > Ian,
> > a VW kombi syncro.
> > Cheers,
> > Skot
> > > Hi everyone,
On 03/02/2013, at 2:40 PM, Ken Garratt wrote:Hi Scott,It has been reported here dissatisfaction with the Prestige AC mounting bracket. Agreed there are some versions of it that are more crude than others. Agreed they are more heavy than veedubs own alloy bracket. There are those who have suffered from damage to the engine case bosses that the AC brackets are mounted to.For some reason, I know not why, my Prestige bracket is just fine, albeit heavy, and I have no sign at all of an impending failure of the the engine case boss fastenings. Its only been mounted there for say 20 years. Not long enough? Just lucky? No idea.Cheers.Ken
Paul,
> Hi Ian,
> Paul.
> > Ian,
> > a VW kombi syncro.
> > Cheers,
> > Skot
> > > Hi everyone,
Mr Scott Pitcher <spbconsulting@bigpond.com> wrote:
>Paul,
>Skot
>> <mailto:Syncro_T3_Australia%40yahoogroups.com>, "paulhtravel" wrote:
>> > Hi Ian,
>> > Paul.
>> <mailto:Syncro_T3_Australia%40yahoogroups.com>, Mr Scott Pitcher wrote:
>> > > Ian,
>> a 2wd
>> into
>> > > a VW kombi syncro.
>> > > Cheers,
>> > > Skot
>> > > > Hi everyone,
>> group, my
>> a most
>> previous
>> also a
>> missed a
>> the dream!
Joel,
No content and no trimming of previous posts. Please try again.
Behalf Of Joel Bahu
Sent: 04 February 2013 12:02
To:
Sent from my Verizon Wireless Sony Ericsson Xperia™ PLAY.
Mr Scott Pitcher spbconsulting@bigpond.com>
wrote:
>Paul,moment:
>Skot
>>href="http://www.gumtree.com.au/s-ad/birchgrove/campervan/vw-type3-syncro-4wd-campervan/1013590085">http://www.gumtree.com.au/s-ad/birchgrove/campervan/vw-type3-syncro-4wd-campervan/1013590085
>>href="http://www.carsales.com.au/private/details/volkswagen-transporter-1990-14200203?base=1216&vertical=Car&cr=4&eapi=2&__N=1246%201252%201247%201282%204294962746%201216&num=15&silo=Stock&Range=Year%3a1980%2c1992&sort=default">http://www.carsales.com.au/private/details/volkswagen-transporter-1990-14200203?base=1216&vertical=Car&cr=4&eapi=2&__N=1246%201252%201247%201282%204294962746%201216&num=15&silo=Stock&Range=Year%3a1980%2c1992&sort=default
>> > Hi Ian,
>> >4wd van a
>> > Paul.
>> > > Ian,
>> > > long while back because I couldn't afford a syncro - theywere still
>> > > fetching $30-$40K when I was looking first time. Before thatI had
>> a 2wdcrap.
>> > >mine)
>> intothat had
>> > > a VW kombi syncro.
>> > > never been looked after - which is a real concern for a highmileage
>> > > vehicle. If they are serviced they run well for many kms.look at
>> > > what van suits your needs.your
>> > > Cheers,
>> > > Skot
>> > > > Hi everyone,
>> group, mylong term
>> > > > desire to do so. Now that I am semi-retired I wouldlike to make it
>> > > > happen. I can see already that the group & it'shistory will be
>> a mostVan(lined by a
>> previousto bed)
>> also ajust
>> missed amuch where I
>> > > > would like to start. i.e. restore van then fit-out stepby step.
>> > > > Anyway that's my story (of a small part of it) and soon with
>> the dream!
