Shift rod mounting boots
My rear shift rod mounting boot has given up the ghost.
As far as I can see in Bentley 34.2 the tensioning pin must be removed and the shift lever slides off the shift rod to fit the new boot. I cannot see how the tensioning pin can be removed.
Please advise if I am on the correct path or is there another way to fit the boot.
Philippe
Hi Philippe,
It is a mystery the first time.
Simply use a hammer and short metal pin or dowel slightly smaller in diameter than the spring pin you need to remove. Drive the spring pin UPWARDS and it gets shifted out of the way into the cast alloy selector lever above. Then recover it for use on re-assembly.
Date: Fri, 30 Nov 2012 08:32:31 +0000
Subject: [Syncro_T3_Australia] Shift rod mounting boots
Philippe
Spot on, Ken
At 11:30 PM 30/11/2012, you wrote:
Hi Philippe,
Philippe
Thx Ken
Life is so simple -
Philippe
On 30 November 2012 20:30, Ken Garratt <unclekenz@hotmail.com> wrote:
Hi Philippe,
Philippe
Philippe Tyack
Mobile:+61450059162
