Need advice - my Syncro sliding door pops open (door closes but pops loose whilst driving - does not slid open.Have tried adjusting the locking pin ,but to no avail.
Thx
Philippe
The next most likely cause is that the rear latch is not closing properly. If the pawl does not grip fully, the rear pops open, followed by the front.
Behalf Of Gullyraker@aol.com
Sent: 16 September 2012 23:56
To:
Sliding door
Check
the easy stuff first Phillipe.
Bolts and screws often work loose on the sliding door.
Roger Beetle.
> properly.
> front.
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of
> Gullyraker@aol.com
> Subject: Re: [Syncro_T3_Australia] Sliding door
> Check the easy stuff first Phillipe.
> Roger Beetle.
> Les Harris <mailto:leslieharris%40optusnet.com.au> wrote:rel=nofollow target=_blank ymailto="mailto:Gullyraker%40aol.com">mailto:Gullyraker%40aol.com
> properly.
> front.
> From: mailto:Syncro_T3_Australia%40yahoogroups.com
> [mailto:mailto:Syncro_T3_Australia%40yahoogroups.com] On Behalf Of
> To: mailto:Syncro_T3_Australia%40yahoogroups.com
> Roger Beetle.
On 17 September 2012 12:14, Bill <marg_bill@westnet.com.au> wrote:
Hi Philippe. I had the same problem april 2009 with my telstra van. Proved to be the rear latch as Les suggested. I posted my solution on april 24 2009 post no 5162. It still working well today. The problem was wear on the two stage securing hook as well as the shaft the hook rotates on. The fix was to file the round spots on the hooks and give the shaft a good wack with a punch to take the slop out. you will need to remove the lock to do this.Check the post it may help. Bill
Philippe Tyack
Mobile:+61450059162
--- In Syncro_T3_Australia@yahoogroups.com, Philippe Tyack <philtyack@...> wrote:
> Hi Bill ,
> Thx for the info , all is working well again
> Cheers
> Philippe
> Philippe Tyack
> Mobile:+61450059162
