Not such a good idea Scott, there are a few issues mainly safety related. I can only suggest to do a proper risk assessment before placing those bombs under your feet. I would see an aircraft builder for instance and have a tank built, aircraft aluminium because it would withstand the worst of abuse without leaking prematurely. Just my thoughts, in case you are coming up here we could go to Taree
For a quote. You could install an elec. Pump to transfer the fuel into the main tank. With my best wishes for a lovely (quiet haha) Christmas hartmut
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Mr Scott
Pitcher
Sent: Wednesday, 23 December 2009 6:26 PM
Subject: [Syncro_T3_Australia] Spare Wheel Well
I am trying to make use of my now useless spare wheel well and apart from some recovery gear and possibly some well packaged spares and thought why not a couple of 10L plastic jerry cans?
The spare wheel well is exposed to a fair amount of heat with the radiator fan above it but it is well ventilated. The plastic tanks seem to expand and contract well and it appears to be made from the same plastic our main fuel tanks are made of.
The standard syncro vehicle tank has heat shielding from the engine/ gearbox heat, however, my syncro has been converted at least 15 years ago to a suby power plant and the heat shielding was removed from the tank at the same time. This was never returned.
In previous 4wd expeditions - particularly in soft sand my 3rd stage fan has gone off due to hot running in very boggy sand and there has been no issue with the fuel tank.
Thus I assume if the lids are done up tight there should be no problem.
Anyone have any thoughts words of wisdom otherwise?
From: Hartmut KiehnSent: Wednesday, December 23, 2009 7:07 PMSubject: RE: [Syncro_T3_Australia] Spare Wheel Well
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of Mr Scott Pitcher
Subject: [Syncro_T3_Australi a] Spare Wheel Well
I think a solicitor, when proffering opinions, stamps "without prejudice" across the document so as to prevent use of such documents being used against himself in a court of law. This is probably something similar, hence "without prejudice"!
I've ruminated whether there is any tangible difference between placing a 20 litre steel jerry can of petrol in the spare wheel bay (hidden, shade protected, better for/aft weight balance, albeit radiant radiator heat) compared with a rear mounted jerry can of petrol (not hidden, vandal accessible, not so good for/aft weight balance, fully exposed to summer heat, rear impact risk).
So I'm still not convinced there is much difference between the two alternatives in terms of safety. I concede I'm not a fan of plastic jerry cans though, opt for a steel jerry can any day, ensure the internal air/expansion space is present and the clamp is pinned closed as well. I bought 2 ex swiss army steel jerry cans in very good nic ... happy with those.
Cheers. Not sure if this "without prejudice" opinion helps you Scott.
Date: Wed, 23 Dec 2009 19:07:32 +1100
Check out the latest features today Get more out of Hotmail
You can handle the emotional side of things--- I cut the hole. hartmut
Pitcher
Sent: Wednesday, 23 December 2009 8:00 PM
Subject: Re: [Syncro_T3_Australia] Spare Wheel Well
Thanks Hart.
I just get sick of seeing that fantastic empty space which has great ventilation.
Good idea for a custom tank although the dollars are a bit tight at this stage plus I have a custom stainless tank already made for under the central section of the syncro - just need to build up the courage to cut the hole in the side for the standard 2wd filler.
Hopefully I will catch you up the coast.
--- Original Message -----
----- Original Message -----From: Ken GarrattSent: Wednesday, December 23, 2009 8:02 PMSubject: RE: [Syncro_T3_Australia] Spare Wheel WellScott, Hartmut,
Subject: RE: [Syncro_T3_Australi a] Spare Wheel Well
Hi Ken,
Firstly, what a brilliant idea, let’s ALL of US contributing to this, our site, start each and every reply with “without prejudice”. This should stop all of this litigation crab which is plaguing some members.......
Secondly, Ken, you are absolutely right when you question the carriage of fuel in a rear mounted container, except we didn’t really talk about this, the question was about a couple of plastic cans
Carried in the wheel well and I didn’t like the idea too much. Nothing against a solid Jerry can if you can find a good one, except that it’s maybe cumbersome to fiddle out when already stressed to max
(poss. passed the last petrol station 20 clicks ago, the kidz are hungry, no Macca in sight etc) this is worst case scenario and this is what one takes into the equation when applying Risk Assessment.
Since Human Factors have become mandatory to pass as a pilot, the accident rate in the Recreational Pilot fraternity has shrunk by +- 80 %. Let us think about this when we mount fuel on front or rear bumpers. For me it’s no ruminating about, I would carry spare fuel where I would carry a Black Box , in the safest possible space available. But that’s me, I already had too many close calls, flying gliders since 1970. hartmut
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ken Garratt
Sent: Wednesday, 23 December 2009 8:02 PM
Scott, Hartmut,
rear impact risk).
Pitcher
I've already tried fitting a 20 litres Oz made jerry can underneath .... identical in size, and it fits under no probs, no mods. I glued flat rubber sheeting on the side that lays down to act as a steel/steel buffer. Anyone paranoid could also tie it down.
I get a warm floor ... always have, so there is heat there ... even more so when the fan kicks in. Maybe your bloke was snow skiing at the time ... haha
Date: Wed, 23 Dec 2009 22:14:02 +1100
----- Original Message -----From: Ken GarrattSent: Wednesday, December 23, 2009 8:02 PMSubject: RE: [Syncro_T3_Australi a] Spare Wheel WellScott, Hartmut,
Find out how Use Messenger in your Hotmail inbox
I've run out of other options for a supplementary fuel supply location ..... only leaves the spare wheel space or jerry cans out back. I wouldn't fancy carrying fuel out front.
My van came with a rear rack for 2 jerry cans, fitted back in about 1992. I assume it was used. I'm about the sixth owner. The syncro is still here in one piece. Maybe just plain old lucky eh. Touch wood.
Date: Wed, 23 Dec 2009 22:13:51 +1100
Hi Ken,
Firstly, what a brilliant idea, let’s ALL of US contributing to this, our site, start each and every reply with “without prejudice”. This should stop all of this litigation crab which is plaguing some members..... ..
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of Ken Garratt
----- Original Message -----From: BillSent: Friday, December 25, 2009 6:26 AMSubject: [Syncro_T3_Australia] Re: Spare Wheel Well
Hi Scott. Sounds like a good spot for a hot water tank. I just got back from Qld visiting my son. If the plomer run is on give me a ring, i'm in. ph 0265685025. Merry christmas all. Bill and Marg.
