Les,
Ive also been fiddling with this xls spread sheet from Dereck Drew but Ive only guesstimated my tire RPM i will need to talk to perilli. to be accurate.
Phil Lee
----- Original Message ----
Sent: Friday, April 18, 2008 11:28:58 AM
Subject: Re: Re: [Syncro_T3_Australia] Re: Speed/Gear Graphs
Phil,
The 6P and 6PA ratios are the same, according to that chart. It will be interesting to see in the longer term which boxes were fitted to the Australian delivery Syncros. Somewhere in my records I have the spec sheet for the first Syncros delivered to Australia. It was noticeable that the sheet specified 4.86 final drive. To my knowledge, Australia got the 5.43 only.
----- Original Message -----From: Phil LeeSent: Friday, April 18, 2008 11:50 AMSubject: Re: Re: [Syncro_T3_Australi a] Re: Speed/Gear Graphs
Les, just home had a look at my box its a 6P 03 090, I found a gearbox ratio chart from Brick yard don't knowhow accurate it is. but heres the link. http://www.brick- yard.co.uk/ VehicleSpecific/ T3/info/gbx. htmPhil Lee.![]()
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
