> Eddie,
> Much the same.
> Theo
> At 10:47 AM 2/08/2013, you wrote:
> >What is your air fuel ratio gauge reading when on gas?
> >--- In
> ><mailto:Syncro_T3_Australia%40yahoogroups.com>Syncro_T3_Australia@yahoogroups.com,
> >Theo Weiss <teows@> wrote:
> > > Eddie,
> > > I have no issue with idles. After the van's been
> > > to the VW work shop the engine stalling has been fixed, see previous email.
> > > However the engine still runs very rich - you can
> > > smell it. Also the Innovate Motor sports gauge
> > > shows 9-11 Lambda in normal driving.
> > > The mechanic reckons the AFM is faulty. I have
> > > tried to repair the AFM shifting the circuit
> > > board so the wiper has a new track.
> > > All this as per Ken's suggestion, but it didn't
> > > make any difference. I really would like a good
> > > working AFM to try on my van to find
> > > out if the AFM is actually faulty, any takers?
> > > Cheers, Theo
> > > At 08:23 AM 1/08/2013, you wrote:
> > > >Try playing with the spring tension of the flap
> > > >in the afm. Over time it loosens up a bit. Does
> > > >it idle rough on gas too?. I know with my system
> > > >the afm has nothing to do with running on gas,
> > > >and idles very smooth whilst on gas. Eddie.
> > > >--- In
> > > > > Ken,
> > > > > Today I had a trial run my old AFM. The screws are certainly very
> > > > > tight. The first one came out ok, the second one the head broke off,
> > > > > the third one I stripped the head but I got it out. I was using a
> > > > > soldering iron which obviously has not enough heat. So I bought a
> > > > > fine gas torch
> > > > > and capacitor for the real job. I moved the circuit board a bit to
> > > > > find a clean track but the numbers did not change much.
> > > > > Does any one know what they should be? The Bentley only states " move
> > > > > air flow sensor - change in resistance".
> > > > > At the moment I can't go for a drive,the gas people are digging holes
> > > > > in the driveway. At least an easier job than the oil or water pump.
> > > > > Cheers, Theo
I did a few days ago. It makes no difference if I run it with Innovate MTX-L on LPG or petrol or the factory O2 sensor connected/disconnected.
May be there is something wrong with the Injectors or Pressure regulator?
At 12:53 PM 2/08/2013, you wrote:
Might have to recalibrate the gauge& then reset mixtures with a laptop, but swapping the afm is a good idea
> Eddie,
> Much the same.
> Theo
> >--- In
> >< mailto:Syncro_T3_Australia%40yahoogroups.com>Syncro_T3_Australia@yahoogroups.com ,
> > > Eddie,
> > > Cheers, Theo
> > > >--- In
> > > > > Ken,
> > > > > fine gas torch
> > > > > Cheers, Theo
Sent: Friday, 2 August 2013 11:54 AM
Subject: Re: [Syncro_T3_Australia] Re:Stalling Engine
Thank's for the offer, how about 9am would that be ok and your address please.Mine is also a 2.4.
At 08:13 AM 2/08/2013, you wrote:
Theo, You can grab mine on Saturday morning. We could even swap them and see if your fault changes to my bus. I will be kid wrangling between 11&1pm so those times are out. I have "fiddled" with mine to get the best air fuel ratio I can to suit the 2.4 capacity but there is no reason it won't work on yours. Just thought I should let you know it is not a standard unit. Greg E
Sent: Thursday, 1 August 2013 8:29 PM
Eddie,
I have no issue with idles. After the van's been to the VW work shop the engine stalling has been fixed, see previous email.
However the engine still runs very rich - you can smell it. Also the Innovate Motor sports gauge shows 9-11 Lambda in normal driving.
The mechanic reckons the AFM is faulty. I have tried to repair the AFM shifting the circuit board so the wiper has a new track.
All this as per Ken's suggestion, but it didn't make any difference. I really would like a good working AFM to try on my van to find
Cheers, Theo
Try playing with the spring tension of the flap in the afm. Over time it loosens up a bit. Does it idle rough on gas too?. I know with my system the afm has nothing to do with running on gas, and idles very smooth whilst on gas. Eddie.
--- In mailto:Syncro_T3_Australia%40yahoogroups.com, Theo Weiss <teows@...> wrote:
> Ken,
> fine gas torch
> Cheers, Theo
Suits me fine. Much better.
At 07:48 PM 2/08/2013, you wrote:
Could we make it 9.30am Theo? Address is 302 Mansfield st Thornbury. Greg E
Eddie,
Cheers, Theo
> Ken,
> fine gas torch
> Cheers, Theo
There must be a company that services the afm units and can recalibrate them any one got a phone number. Bob
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Theo Weiss
Eddie,
Cheers, Theo
> Ken,
> fine gas torch
> Cheers, Theo
Not that I know of.
Greg was kind enough to let me try his AFM but no difference - still running very rich.
I mean rich - about 22lit. per 100k!!! In my book, it is not the AFM it may not be 100% but no.
Since then I tried 2 secondhand temp2 sensor (one from Greg) -no difference. I will order some new ones.
I also checked the Injectors - they seem to work, I can hear them open & closing, resistance is ok.
Tomorrow, I will have another look at the Throttle switch, and after that I go window shopping, it starts with T.
From: Syncro_T3_Australia@yahoogroups.com [ mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Theo Weiss
- Theo, You can grab mine on Saturday morning. We could even swap them and see if your fault changes to my bus. I will be kid wrangling between 11&1pm so those times are out. I have "fiddled" with mine to get the best air fuel ratio I can to suit the 2.4 capacity but there is no reason it won't work on yours. Just thought I should let you know it is not a standard unit. Greg E
- To: Syncro_T3_Australia@yahoogroups.com
- Sent: Thursday, 1 August 2013 8:29 PM
- Subject: Re: [Syncro_T3_Australia] Re:Stalling Engine
- Eddie,
- I have no issue with idles. After the van's been to the VW work shop the engine stalling has been fixed, see previous email.
- However the engine still runs very rich - you can smell it. Also the Innovate Motor sports gauge shows 9-11 Lambda in normal driving.
- The mechanic reckons the AFM is faulty. I have tried to repair the AFM shifting the circuit board so the wiper has a new track.
- All this as per Ken's suggestion, but it didn't make any difference. I really would like a good working AFM to try on my van to find
- out if the AFM is actually faulty, any takers?
- Cheers, Theo
- At 08:23 AM 1/08/2013, you wrote:
- Try playing with the spring tension of the flap in the afm. Over time it loosens up a bit. Does it idle rough on gas too?. I know with my system the afm has nothing to do with running on gas, and idles very smooth whilst on gas. Eddie.
- --- In mailto:Syncro_T3_Australia%40yahoogroups.com, Theo Weiss <teows@...> wrote:
- > Ken,
- > Today I had a trial run my old AFM. The screws are certainly very
- > tight. The first one came out ok, the second one the head broke off,
- > the third one I stripped the head but I got it out. I was using a
- > soldering iron which obviously has not enough heat. So I bought a
- > fine gas torch
- > and capacitor for the real job. I moved the circuit board a bit to
- > find a clean track but the numbers did not change much.
- > Does any one know what they should be? The Bentley only states " move
- > air flow sensor - change in resistance".
- > At the moment I can't go for a drive,the gas people are digging holes
- > in the driveway. At least an easier job than the oil or water pump.
- > Cheers, Theo
Have you checked the electronic motor management chip? Bob
Sent: Monday, 5 August 2013 10:21 PM
Subject: RE: [Syncro_T3_Australia] Re:Stalling Engine
Bob and All,
Not that I know of.
Eddie,
Cheers, Theo
> Ken,
> fine gas torch
> Cheers, Theo
Do you mean the ECU ? I had a look at the circuit board with a magnifying glass but could not see any obvious damage.
It could be a faulty ECU.
Theo,
Two possibilities.
1. Have you checked free exhaust flow through the CAT and muffler? High back pressure can cause excessive consumption.
2. Recently, I was reading some notes from Ben Tan regarding ECU’s and he had previously found the following:
“In my previous life working for AT&T, we discovered the more
'advanced' the equipment, the more they suffered from electronic gremlins. Upon
closer examination of the circuit boards under a microscope, there obvious
micro-cracks which would intermittently open to create a faulty condition then
subsequently close to hide it again. Said gremlins are ever present especially
in automotive components.
A Vanagon List member went to the trouble of inspecting "defective"
ECU's and ICU's from T3's. Lo and behold, micro-cracks were present in the
solder. He re-melted the solder and thereby "rebuilt" the ECU's”.
Sent: 06 August 2013 11:39
To:
Re:Stalling Engine
Bob,
Do you mean the ECU? I had a look at the circuit board with a magnifying
1. I have a free flowing muffler and CAT. ;-)
2. I will have an other look.
At 11:53 AM 6/08/2013, you wrote:
Theo,
Two possibilities.
2. Recently, I was reading some notes from Ben Tan regarding ECUs and he had previously found the following:
In my previous life working for AT&T, we discovered the more 'advanced' the equipment, the more they suffered from electronic gremlins. Upon closer examination of the circuit boards under a microscope, there obvious micro-cracks which would intermittently open to create a faulty condition then subsequently close to hide it again. Said gremlins are ever present especially in automotive components.
A Vanagon List member went to the trouble of inspecting "defective" ECU's and ICU's from T3's. Lo and behold, micro-cracks were present in the solder. He re-melted the solder and thereby "rebuilt" the ECU's.
Bob,
Do you mean the ECU? I had a look at the circuit board with a magnifying glass but could not see any obvious damage.
Sent from my WalkingStick!
On 05/08/2013, at 10:21 PM, "Theo Weiss" <teows@melbpc.org.au> wrote:
Bob and All,
Not that I know of.
- Eddie,
- Cheers, Theo
- > Ken,
- > fine gas torch
- > Cheers, Theo
Tricycle?
Behalf Of Hartmut Kiehn
Sent: 06 August 2013 15:18
To:
Re:Stalling Engine
Theo ! Starting with T ? What could that be??? T2 maybe ? No whizzz fizz electronics!
What about a Terrafugia it's a flying car you could hopp to Coffs in no time.
There's of course another one with T but even looking at it could be interpreted as an offense .....
Please give us a hint !!!
Hartmut
Theo;
Yes it sends all the signals to the motor components i.e. air flow meter, timing, fuel mix, idle revs ,injector operating time are you in Sydney if so you may find a member who has a spare or is prepared to swap to see what happens, I do have one as my docca has a performance chip fitted to it, but I will need to find it if you want to go down this path.
Bob
Sent: Tuesday, 6 August 2013 11:39 AM
Bob,
