I haven't actually eyeballed one of these bushes
for a very long time but, from memory, they are sintered bronze (which is very
porous) and are boiled in oil at the point of manufacture. As Phill points
out, all they need is the very occasional drop of oil. Since the starter
only runs for a few seconds per start and not many times per day, the original
oil usually sees out the life of the vehicle. It is prudent, however, to
add a bit of light oil whenever the bush is accessible, as when the starter is
out for service.
These bushes can wear out and the replacement
should be (again if I remember correctly) oil-filled sintered bronze. As
Phill says, new or reconditioned starters will come with a bush; it is
completely silly not to change the old one and grease should never be
used.
----- Original Message -----From: plander@optusnet.com.auSent: Sunday, January 04, 2009 7:37 AMSubject: Re: Re: [Syncro_T3_Australia]MY TRUCK WON'T START EITHERA problem with this bush is when people change the starter motor, they grease the shaft/bush. This is a bronze bush which needs to be oiled. Grease kills it real quick! A friend of mine was changing the bush yearly on his Kombi until told him not to grease. He never changed it again.
> Ken <unclekenz@yahoo. com> wrote:
> Ok Phil, looks like you've answered my question to Yurik. Then I guess
> the bronze bushing is listed elsewhere in ETKA, not as part of the
> starter motor exploded view. Probably wherever the bell housing is.
