Stranded in New England
Does the problem go away if you turn off the engine for a few minutes?
If it does then you probably have Vanagon syndrome.
> Francesca Coles <fcoles6@gmail.com> wrote:
> Hi, Ben. Thanks for that - very useful. That's some depth of experience
> you
> have there!
> Perhaps we may have been too quick to jump on the Vanagon syndrome
> bandwagon? It's just that the presentation seemed to be classic VS:
> running
> fine until had been driving for an hour or two at constant highway
> speed,
> then commenced intermittent bucking. I suppose that given Hartmut has
> been
> kind enough to lend us his harness we may as well give that a go first,
> and
> then proceed to your recommended troubleshooting if we get nowhere. Just
> so
> long as it's not VS plus some other issue! But, then again, that's par
> for
> the course with an old girl... My mechanic is also very experienced with
> T3s
> and could no doubt get to the bottom of the issue if I threw it at him,
> but
> better to try and save some cash by attempting some troubleshooting
> ourselves first.
> Francesca.
> On Sun, Jul 11, 2010 at 11:29 AM, BenT Syncro <syncro@gmail.com> wrote:
> > Francesca,
> > For what it's worth, most choking and bucking problems I've
> encountered had
> > to do with simple vacuum and exhaust leaks.
> > I have personally owned more than 30 T3's of which the majority had
> the MV
> > (2.1 litre Wasseboxer) engine. All ran fine w/o the harness filter
> > attachment. I'm sure this has been mentioned before. Finding the
> vacuum
> > leaks are relatively easy. I spray carburetor cleaner over all the
> hose
> > connections and especially around the large intake hoses going in and
> out of
> > the AFM housing. There is a noticeable change in idling
> characteristics once
> > the leak has been temporarily blocked by the spray of liquid. Do take
> some
> > precautions as most carb cleaners are flammable.
> > The most difficult to trace problem i encountered which presented
> itself as
> > "Vanagon syndrome" was exhaust related. I am not sure how this applies
> to
> > you. I found an exhaust leak upstream from the Oxygen sensor. I
> initially
> > thought the sensor was at fault. Changed the exhaust gasket eliminated
> > dilution of the exhaust sample passing over the sensor.
> > During that process, I obtained AFM's ECU's, patch harnesses... etc.
> In the
> > end, it was basic automotive troubleshooting. I casual query with my
> mate
> > who owns a shop which services an average of 5 T3's a day (5 days a
> week
> > time 52 weeks) revealed that the so called Vanagon syndrome has been
> > remedied with the harness patch once or twice per year at his shop.
> That
> > translates to 2/1300. Or less than 0.15% of the T3's serviced there. I
> can't
> > say the figures are exact as the remarks were annecdotal. There are
> days
> > when there two dozen T3's there but some have alternative powerplants.
> > Nevertheless, the suggestion is to look for basic problems before
> assuming
> > the problem is a bum AFM or the need for the harness patch or
> capacitors as
> > a signal filter.
> > Cheers,
> > BenT
> > Sent from my T3 w/ an AFM
> > On Jul 10, 2010, at 6:00 PM, Francesca Coles < <fcoles6@gmail.com>
> > Thanks for the thought, Greg. And thanks a whole lot, Hartmut.
> > It would be lovely if fitting the harness solves the bucking/choking
> > problem. I'd be happy enough to fork out good money for a new one if
> it
> > does. Of course the problem could be caused by something else not so
> > amenable to diagnosis or a cheap fix. Fingers crossed, however....
> There
> > have been a couple of times when the choking has been a little
> alarming, say
> > pulling out into traffic and she won't get up and go.
> > Francesca.
Well, it sometimes does go away but not always.
> you
> have there!
> running
> speed,
> been
> and
> so
> for
> T3s
> but
> ourselves first.
> Francesca.
> > Francesca,
> encountered had
> the MV
> vacuum
> hose
> out of
> some
> itself as
> to
> initially
> In the
> mate
> week
> That
> can't
> days
> assuming
> capacitors as
> > a signal filter.
> > Cheers,
> > BenT
> it
> There
> alarming, say
> > Francesca.
Hartmut and Phill,
As I said in my last post, I don't know if there are any internal differences between the "A" and "non A" versions. I guess the acid test would be to try both when the syndrome is happening and see if one can detect a difference. I've done that and found they both seem to have a similar positive affect.
There are plenty of references to an "A" version on Google, just as there also are "non A" references.
I sourced an "A" version here in Australia, clearly labelled as such.
I sourced a "non A" version from the US. clearly labelled as such.
The Samba pic I attached to my last post does show the "A" version, clearly labelled as such. See it here attached again.
So what say you Phill? Still no "A" version?
Date: Sun, 11 Jul 2010 08:59:28 +1000
Subject: RE: [Syncro_T3_Australia] Home at Last/AFM Issue
Ken,  g/m,  lovely day up here. Took my cable out to send it to Fran but it has the “A” missing, it’s only 025 906 302 . You think it matters?? H.
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of Ken Garratt
Sent: Sunday, 11 July 2010 12:53 AM
Subject: RE: [Syncro_T3_Australi a] Home at Last/AFM Issue
Peter,
My crystal ball anticipates the short answer to your question is no.
I take it you have read and digested the VAG internal bulletin concerning the AFM harness add-on fix (see attachment). This bulletin first saw the light of day here on this forum not that long ago thanks to Yurik in Perth. From memory, he sourced it from a contact who was once a VAG employee.
Bare in mind that in Australia, this matter was never the subject of an official vehicle recall between VAG and the Dept. of Transport & Regional Services. It was merely an internal initiative by VAG at the time to address a perceived electrical/signal problem stemming from the AFM. Meaning that VAG, if approached now, could easily tell you to simply go jump (politely?).
The facts of the matter as stated in this bulletin are consistant with my prior understanding concerning the free distribution/ fitting by VAG at the time to T3/MV vehicles that presented for routine service at VAG service centres. Meaning that all other eligible vehicles serviced elsewhere or owner serviced would have missed out and certainly there would never have been an official VAG communication via letter to all known T3 owners at the time to draw this matter to individuals attention.
I would suggest that, if you so choose to, you be guided by the content of that bulletin and so form a strategy accordingly to best effect in an approach to "try on" a VW service centre of your choice. I would think by now it would be very unlikely VAG personnel would have any knowledge or record of this bulletin, so this could be an interesting challenge. Still, it is possible the local service centre, guided by instructions from head office, just may come through for you. Do you have anything to lose? Are you up to the challenge? Do you need a life coach to assist you in this matter? haha
Also bare in mind it was not that long ago it was reported here of a member who chose to purchase one of these new from VAG for the princely sum of something like $350 from memory ... I'll stand corrected on the exact amount.
As I said previously, these can be had secondhand occasionally on eBay or The Samba from say $50 upwards plus shipping. What is unclear though is that the Australian distributed harness fix is part no. 025 906 302A whereas some examples sourced seconhand from US are missing the A on the end. Does this suggest an internal difference between them?
Should anyone purchase a secondhand one, often the thin rubber protective boot is already torn. It doesn't seem to affect functionality but I suppose water and debris could end up inside. Either figure out a way to patch it or in my case, I formed a complete flexible seal over the torn rubber boot using a rubberised 2 pack epoxy.
For those who missed the relevant detailed article ...
Goto: http://www.teluspla net.net/public/ gary2a/rack/ afmharness/ afmharness. htm
Also see attached a pic of the AFM harness add-on fix part with a ruler. Gives an idea of its length.
Did I miss something?
PS: Peter, on the ignition switch issue, I've not had reason yet to replace one so I for one am interested to learn of any difficulties in such a procedure, should the need ever arise in the future. So after you've mastered the changeover technique, I and perhaps others here would appreciate some feedback on the methodology .. TIA.
Date: Sat, 10 Jul 2010 22:07:57 +1000
Subject: [Syncro_T3_Australi a] Home at Last/AFM Issue
Hi Ken. Back in Port M at last. Syncro all washed and looking schmick. Have a new ignition switch to install and the way the sparky wired up my temp switch and button I can leave it there tucked up under the dash for safety. Will be checking headlight globes on Monday. I have the old bull bar off and will drop out to see Hart and put the new one on next week.
RE the AFM. I do not have the harness fix. Does this mean that the local VW dealer here has to install one free of charge?
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5266 (20100709) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset. com
Looking for a hot date? View photos of singles in your area!
Thank you Larry. One of the other guys sent this through. After due reading of all the posts I have concluded I do not have this problem so will just let the issue rest for the present.
Regards, Peter
Peter,
As Phill replied, "if it ain't broke, don't fix it."
Well for several years since buying the syncro, mine wasn't broke either. But then, all of a sudden, unexpectedly, it broke.
So I fixed it as per the known solutions. Hasn't missed a beat since.
Begs the question then. Had I done earlier when it wasn't broken, the maintenance work I did to "unbroke" it, might I have avoided all the drama and inconvenience and expense, especially if I was out in the middle of the Tanami desert?
I say without any hesitation .... yes.
Date: Sun, 11 Jul 2010 20:23:44 +1000
Regards, Peter
What do you think an "A" suffix on the part number means?
It doesn't mean that the part is different, it could just be a different supplier. People on this forum are reading too much into small things.
Just remember that Vanagon Syndrome will not cause a breakdown.
> Hartmut and Phill,
> From: hartis@live.com.au
> it has the ���A��� missing, it���s only 025 906 302 . You think it matters??
> H.
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ken Garratt
> Peter,
> my prior understanding concerning the free distribution/fitting by VAG
> attention.
> exact amount.
> Goto:
> http://www.telusplanet.net/public/gary2a/rack/afmharness/afmharness.htm
> From: peter@coeconsult.com.au
> Subject: [Syncro_T3_Australia] Home at Last/AFM Issue
> Peter
> http://www.eset.com
> View photos of singles in your area! Looking for a hot date?
> http://clk.atdmt.com/NMN/go/150855801/direct/01/
I asked my friend Rennie Wibble who is a longtime partsmanager for one of the largest VW dealerships in Southern California regarding this business about the 'A' suffix on the P/N for the Vanagon Syndrome patch harness. Here's his response:
Sometimes it's just a vendor change. Usually it's because they updated it. But just because they updated it doesn't mean for sure that it is a better part.
Rennie
He just sent me this message this evening. I responded asking if he can get a definitive answer as to whether the suffix signified a vendor change or if if there was indeed a change made to the part itself.
I suspect his answer will come tomorrow if not later. It's still Sunday here.
