Eddy,
It probably depends on where you are to do the fitting or if you use
the SmallCar systems you can probably do it yourself - they even now
have drastically shortened and proven sumps I believe - well at least
for the 2.2L and the 3.3L.
Note - Dont shorten the sump yourself as they are full of specially
designed baffles and have the oil capacity as required to keep the
engine happy. The aftermarket shortened sumps have equivalent volume
and have new specially designed baffles.
I believe that Custom VW in Queensland have a shortened sump
systemand they also do the conversion.
Andy has done this conversion in the last few years and he is in
South Oz if that helps.
If you want the same (or similar) economy you will need to replace
the gear ratios otherwise they all will use more fuel.
The trade off is excellent power and reliability - something the VW
motor could not provide in my opinion.
I have also heard the 2.2L is quite underpowered for the heavy syncro
so the 2.5, 3.0 or 3.3L engines are the ideal.
The 3.3L SVX motor is an amazing piece of machinery and you can get
every part required for the swap via Smallcar in the US including the
wiring harness (the hard part). This engine even has twin knock
sensors and will adjust itself to suit certain problems it may face.
I have calculated a cost of an SVX swap in mine and I am looking at
approximately $8K - $9K after I do the timing belts and other minor
essentials.
There are quite a few forums around for people doing this sort of
thing - just google and go.
Hope that helps.
--- In
Syncro_T3_Australia@yahoogroups.com, "bergodaz" <bergodaz@...>
wrote:
> after blowing another head gasket i'm seriously considering a subi
2.5
> engine swap.i've been looking at some of the u.s vendors of these
> conversions ,the main one being www.smallcar.com ,and i'm becoming
more
> and more convinced that these sorts of swaps not only possible but
also
> very practical.is there anyone that can offer any hints/ advice on
subi
> conversions.is there anyone who's undertaken this swap on their own
> van?
> any comments ,positive or negative re the swap, would be
helpful.thank
> you Eddie Bergodaz.
