Apologies in advance to those who find my actions somewhat sacsyncrolegious.
With the intention of converting my first Telecom Syncro 'Synthia'to a subi drivetrain, i sold her 2.1 wbx motor to my mate and mechanic Brian to replace he's blown motor in his 2wd T3 transporter.
Unfortunately he has not been able to get it going.
He has done every check in the manual, swapped computers, dizzys, coils, relays, checked fuses etc.
There is no spark and no power at the hall sensor.
The manual points to the computer.
However we used his computer at one stage to get my van going originally.
He has tried another computer known to be good to no avail and is going try my computer in the morning.
Has anyone got any ideas as to the possible problem here?
Other than syncro motors should be only be used in syncros!
Brian has noticed some things that i didn't know:
Apparently the motors sit 40mm higher in a 2wd.
the exhaust and the tinware are different.
The thermostat housing is also different as are some of the hoses.
The sale of this motor has gone towards the purchase of my second Syncro 'Sylia' also a ex telcom van.
It's quite an upgrade as this van has windows installed all around including a sun roof and headliner.
It has a rocker rear seat/bed and is engineered and registered as a five seater.
Most importantly though it has a fourth gear, which I never had on 'Synthia. I bought the aftermarket 3rd/4th hub slider from Alan at Stokers but have never managed to get the time to head up to Bribie Island to get Rudi to to the rebuild.
For both syncros I am seriously considering a full subi drivetrain conversion using the subaru gears reversed ring and pinion and flipping a subi rear diff.
I am about to start investigating the geometry to make sure everything will fit easily.
Apparently the subi box exits at the top rather than the bottom like the syncro box so there may be a clearance issue.
Also there is a floor stiffener that may interfere with the box.
At the moment there are no reversed 5.43 ring and pinions offered, so a flipped subi diff is the only option if you wish to run the subi box and motor.
Todd at Subi reversed gears has put a flipped subi diff in his manx.
The coverplate can be rotated 180 deg to put the breather at the top.
So as long as everything can fit I would have to come up with a diff mount, a drive shaft and a gear linkage set up.
Everything else is available from Todd and small cars.
I figure this full drivetrain conversion is a lot of work, but someone has to do it and being an engineer and competent 3d modeler I think it may as well be me.
If it can be made to happen it means that the sycro's can continue to run and have modern updates to their drivetrain for as long as subi keep their flat four configuration.
I would love any advice or info anyone has regarding this conversion?
Paul Dumais
