Syncro Brakes
Dear All,
I was recently talking to a VW mechanic who has fitted 4 wheel disc brakes from the T4 VW to his two wheel drive T3 transporter.
He is very pleased with what it has done for him.
Does anyone have experiencing this modification on a Syncro.
I'm particularly interested in what the mod will do for hand brake descents down steep rough hills.
Stock drums are only just adequate for the job and need to be kept well adjusted.
I've got the small car 4 wheel disc kit and i have found that they are no where as good as stock drums ( from a hand brake point view ) because the pad contact area and force applied are both greater with the drum set up.
Sent from my iPhone
On 16/09/2013, at 6:42 PM, "Peter Schweinsberg" <peter@peterandval.com> wrote:
Dear All,
Hamish / Peter,  I fitted Audi A4 brakes all round ca 10 yrs ago. While I am happy with the foot brake, the hand brake is
nowhere acceptable and I wonder how on Earth it passes the test every year.
I read somewhere that the VW Roxon (converted by SEIKEL) is refitting the rear with drums because of holding on steep terrain.  Hartmut
Sent from my iPhone
Dear All,
I just live with the fact my Syncro might become my second boat one day at boat ramp.!
Sent from my iPhone
Sent from my iPhone
Dear All,
Hey Guys , Just thought I would add that my NM Pajero has a rear discs with a small drum brake machined into the hubs ? of the discs used only for the hand brake. Not sure why they went this way but my guess is its hard to apply enough pressure to a disc pad over a long standing period reliably. Could be worth exploring if there is other drum disc combo that could fit the old Syncro.
Another hand brake type is a drum on the tail shaft usually found on trucks etc ?
Regards Pete
Sent from my iPhone
Dear All,
Thanks Hartmut, and thanks for raising this one Pete,
It is possible, Oettinger make them.
I have Oettinger disks all round on my 2WD Porsche powered Caravell.
They have a small drum on the rear brakes for a hand brake.
It is not very effective.
Oettinger had them listed for our Syncros when I did the "Bergmeister".
I presume they are still available.
Problems I had with Oettinger were:
1. Stock wheels would not fit so I had a set of Simmons wheels made up.
2. The studs are easy to knock into the hub when putting a wheel on,
you have to be really careful.
For these reasons i did not explore using them for the Syncro.
--Original Message Text---
Date: Tue, 17 Sep 2013 14:53:00 +1000
Regards Pete
Sent from my iPhone
Dear All,
I have never understood the need to replace the rear drums with discs. I find when reconditioned properly they work great. The only thing I wish VW had done was vent the front discs.
Sent: Monday, 16 September 2013 10:40 PM
Subject: Re: [Syncro_T3_Australia] Syncro Brakes
Sent from my iPhone
Dear All,
I found the drums can get sand in them and or rust up internally if beach driving alot and or mud bashing.
The stopping power of the bigger vented front brakes coupled with a larger BMW booster is much better.
I fitted the bigger front disc for improved front braking and rear reliability (from sand n mud issues).
It also made sense to improve the rear braking efficiency at the same time.
Sure my hand brake has never been as good but I've never let it bother me.
I prefer safer braking especially with big OD tyres now.
Sent from my iPhone
Sent from my iPhone
Dear All,
I have Oettinger discs on my doca , I agree with the stud problem in that the knurling on the stud is too small for it to lock into the disc properly I had new studs made by a shop in Sydney with a larger diameter this overcome the problem with the stud turning when undoing the wheel nut.
The offset on the wheels is different with the oettinger brakes fitted different wheels where fitted by the previous owner, the spare is the standard steel rim but a spacer plate has been fitted for the different offset.
The hand brake works perfectly
I understand that pads are no longer available for the units but one can have the original units fitted with new pads
Bob
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Peter Schweinsberg
Sent: Tuesday, 17 September 2013 5:12 PM
Regards Pete
Sent from my iPhone
Dear All,
Stick with stock drums on the back, Audi discs up front.
Best combination and big improvement on stock.
--- In Syncro_T3_Australia@yahoogroups.com, <syncro_t3_australia@yahoogroups.com> wrote:
Dear All,
Thanks Bob,
I'm interested in knowing the contact details for the engineering shop that made the new studs.
Date: Wed, 18 Sep 2013 11:07:42 +1000
v\:* {behavior:url(#default#VML);}o\:* {behavior:url(#default#VML);}w\:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}
Bob
Regards Pete
Sent from my iPhone
Dear All,
