Would anybody have some official VW Australia documentation stating roof load capacity and towing weight limits for a bus?
Just want to know what's legal for a Syncro.
I can’t recall having seen roof load figures but Page 141 of the Owners Manual gives the following figures for towing:
[mailto:Syncro_T3_Australia@yahoogroups.com]
Sent: 05 November 2014 03:20
Syncro carrying & towing capacity
Oh har har!! I had expanded the table on my screen and didn’t notice that the last column was off-screen!!
Sent: 05 November 2014 08:39
To:
_
No. I scanned my Owners Handbook when I first got my Syncro. I will send a copy to you.
Sent: 05 November 2014 17:38
Is there an on line version of the manual? I don't have one.
I have no doubt the Syncro can do more than my Bay window bus, and that has easily towed and carried on the roof more than most commercial vehicles will see in a life time. (went over weight bridge at the dump many years ago with a tandem axle trailer, total weight 4.7T). Driven sensibly you can achieve a lot.
My question however is more about what is legal, not what could be achieved. Have an accident outside of what is legal and your in deep p**.
Similar goes with modifications, you can do a lot and never be caught out, but have an accident and insurance/police will soon tell you what you should not have done and leave you with a hefty bill, or worse!
That would be great thanks!
Thanks a lot Peter, that's a great help. I don't see the attachment for some reason?
100kg on the roof is not a lot, my nearly ready to install full length roof rack already weights 40kg!
Interesting on the 2WD 4WD towing, so what happens if you have a decoupler?
My tow bar doesn't;t seem to have a tag on it (It is a common one I have seen on other T3's though). Not sure if that's an issue.
On the load capacity, this is quite limited for a caravelle, I think it's only ~5-600kg. Put in 7 people plus luggage and that's easily exceeded!
Thanks Peter, yes can read PDF's fine, I do not see an attachment to open, so assume it is how I am viewing/reading posts.
I am currently logging into Yahoo groups and reading posts from there.
I am new to Yahoo, and not sure I have set it up right, or am viewing it in the most efficient way. I can see attached images by going to the "photo's" tab (or in files/attachments tab), but do not see them in the post either.
Is there possibly a set up issue with how I view the posts? (please note I login mostly from my PC, occasionally from a tablet)
>Thanks again Peter, sorry for all the questions !
>I have looked through old posts, it seems I can open images and word documents fine, bit cannot open PDF files (tried a few posts with pdf's), and cant't open any
>I can however open PDF,s that are in the files section
>I am guessing it is something in yahoo when attaching pdf's to post.
>Anyway, is emailing the PDF to me an option?
>Thanks richars
>Posted by: cathrich1@yahoo.com.au
>Yahoo Groups Links
><*> To visit your group on the web, go to:
><*> Your email settings:
><*> To change settings online go to:
> (Yahoo! ID required)
><*> To change settings via email:
><*> To unsubscribe from this group, send an email to:
><*> Your use of Yahoo Groups is subject to:
> https://info.yahoo.com/legal/us/yahoo/utos/terms/
>Thanks richars
>Yahoo Groups Links
Much appreciated!! Thanks again for all the help.
Got the roof rack on over the week end, and given it a good work out. Made sure it was under the legal limit :)
Will have to post some pictures, it's just a locally made steel "tradesman" rack off a Hiace, with some mods is a good fit on the bus, and at 3.6m is longer than the roof. It will do for now, being steel is easy to modify and change around. Once I know what I need up there it will be a good template for a lighter aluminium one.
