Any feed back would be muchly appreciated
You can run with an empty cat – one that has had the guts knocked out of it – and with the O2 sensor still in place and connected to the ECU.
Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Hartmut Kiehn
Sent: 10 April 2011 14:24
To: Hartmut Kiehn
Syncro catalytic converter / sensor required!
Hi
Without oxy sensor connected you would expect to run rich, better than running
lean, but it would still be running. If you take the cat out, the
fitting of the sensor should be welded back in again, into the bend
before the cat, and the sensor re-inserted. It will run perfectly ok
without cat. Consumption is normal too 12.4/100km on long trip, going 'fast'.
(for DC that is, migth be more for heavy camper).
Some people might say that you would enjoy a little more power (less back
pressure) personally I can't feel much of a difference.
ciao Hartmut
Date: Sun, 10 Apr 2011 02:09:07 +0000
Subject: [Syncro_T3_Australia] Syncro catalytic converter / sensor required!
Hi i have recently found
out through trial and error that syncros do not perform well with out cat
convertor in place!!! fuel issues running rich? computer error? im really not
to sure can anyone add to this question?, as for the subject matter as a result
i now require a catalytic converter + sensor does anyone in the group have one
they would consider selling ? or any tips where i could find one in Aus ?
> Hi Cheers,
> Without oxy sensor connected you would expect to run rich, better than running lean, but it would still be running. If you take the cat out, the fitting of the sensor should be welded back in again, into the bend before the cat, and the sensor re-inserted. It will run perfectly ok without cat. Consumption is normal too 12.4/100km on long trip, going 'fast'. (for DC that is, migth be more for heavy camper).
> Some people might say that you would enjoy a little more power (less back pressure) personally I can't feel much of a difference.
> ciao Hartmut
> From: richardnicholls74@...
> Hi i have recently found out through trial and error that syncros do not perform well with out cat convertor in place!!! fuel issues running rich? computer error? im really not to sure can anyone add to this question?, as for the subject matter as a result i now require a catalytic converter + sensor does anyone in the group have one they would consider selling ? or any tips where i could find one in Aus ?
> You can run with an empty cat - one that has had the guts knocked out of it
> - and with the O2 sensor still in place and connected to the ECU.
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Hartmut Kiehn
> To: Hartmut Kiehn
> Subject: RE: [Syncro_T3_Australia] Syncro catalytic converter / sensor
> required!
> Hi Cheers,
> ciao Hartmut
Richard,
There is a world of difference between an ECU engine and a non-ECU engine.
In the olden days (the days of 8” drum brakes and vacuum wipers!!!), there were a host of standard mods that would increase power – usually at the cost of extra fuel consumption and decreased engine life. The list included larger exhaust pipes, larger carburetors for quick mods, head porting and larger valves for more complicated work.
This generally does not apply to ECU controlled engines for very complicated reasons. In fact, the first line of mods for ECU engines is usually modified ECU module that has been re-mapped. This can give increased engine performance by adjusting fuel delivery, ignition firing point and similar.
Knocking the guts out of the Syncro CAT won’t get you any better performance because the ECU is set to optimize a standard engine.
Given that you have a coolant weep, you have more important things to deal with at the moment.
Syncro_T3_Australia@yahoogroups.com ] On Behalf Of richardnicholls74
Sent: 10 April 2011 18:59
Hey thanks for the info les as this is the what i have done in the
attempt to gain some more HP!! in retrospect i should have left it well alone
as that was the way the 2.1 was designed to run now that i have changed things
,yes defiantly running richer!!i can smell it!! even when still with the ecu
hooked up.
>it
> - and with the O2 sensor still in place and connected to the ECU._,___
