Hey Everyone,
I'm realizing followings recent adventures with coolant and cv joints
(not game to tackle fronts yet!) that the syncro isn't as easy to work
on as my other cars!
I'm trying to change my gearbox oil for general maintenaince and
hoping the gear shifting might become smoother. Following a recent
failed attempt a friend has made me a custom tool - a bunch of 17mm
nuts welded together for the drain / fill plugs.
And despite the recent discussions on this group I still have some
basic questions I was hoping to clarify.
1. Do you need to use a piece of garden hose and funnel to fill up the
gearbox?
2. Apparently only 4L can be emptied. If I just remove the drain
plug will that 4L come out or exactly what else do I need to do to get
max oil out of the gearbox?
3. Don't fill up all the way - only to 1cm below the fill plug? So
do I just keep putting a bit of oil in then sticking my pinky in the
fill plug to see where the oil level is? how precise does this need
to be?
Cool, thanks guys. Sam.
gearbox?
to be?
