Syncro info
When I wanted to do a basic 4wd course they wouldn't accept a Syncro with a VC. They were OK when I explained VC had been removed and solid shaft installed.
Paul.
Sent from my Samsung GALAXY S5 on the Telstra Mobile Network
Date: 23/05/2018 6:19 PM (GMT+10:00)
Subject: Re: [Syncro_T3_Australia] Syncro info
I like your write up Peter, and is a good way to look at it. From experience in my van, there is not switch from coupled to uncoupled, but a progressive change. So the 6% or 10% would not really matter.
Just on Ken's comments, I think it's a matter of preference what you want out of your Syncro. If you want all out serious off road capability I do not think there is any doubt a solid shaft will out perform a VC. Even an aggressive VC is not a solid connection, and in critical situations the difference in speed front to rear could mean the difference between stuck or not.
If however you are after a good all round performer and don't want to constantly monitor road surface, if you need to be coupled or not you can't beat a working VC. It will get you a lot further than a 2WD and it will be a lot safer on wet roads or hard dirt roads than with a solid shaft (as in you would need to decouple front to rear in these conditions)
The tests are well documented for the VC, but I would think some variation either way in performance will still give you a capable off road van.
I think the terms used commonly today are AWD and 4WD. I would consider a (factory) Syncro to be AWD. However the slip required front to rear is less, and amount of torque the VC will transmit is more than today's road going biased AWD cars.
So the poor Syncro is left in no mans land. Better than today's AWD, but not the same as a 4WD with a locking centre diff.
That's hilarious!
I did my first 4WD course back in the 90s when the motoring journalist, Chris Mullet was running his 4WD school.
Chris was a little worried at first because front engine 4WD Mazda & Toyota Vans on his course,
had a tendency to want to roll over their front engines on very steep descents.
He was very pleased when he saw the SYNCRO in action.
The SYNCRO is so well balanced,  the flat 4 contributing to a lower the centre of gravity.
I’ve also lone some  work with Vic Widman the owner of Great Western Tours.
Vic has a training ground down near Batemans Bay on the south Coast.
If Vic was to tell me anything, it would be to pull on the VC now,
and perhaps one or both diff locks as well.
Vic is so highly recognised, he does courses for Defence and the Police.
If you’d like to consider a course of that order, you’ll get him on:
 02 9913 1395    or    www.4wd.net.au
On the subject of solid shafts, unless you live and drive only on “rough and broken ground”,
(Andrew Barton "Banjo” Paterson - the man from Snowy River),
look forward to frequent work on your CVs and the transmission.
As an aside, it’s not 4WD.
My mechanic has bought new CVs for the BERGMEISTER, my B32 imitation (Porsche/T3).
They are best German.
He tells me there is a lot frequent replacement rubbish available.
On 23 May 2018, at 6:44 PM, paulnevinfloors paulnevinfloors@yahoo.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Paul.
Have to say with my time in Syncros and other 4WD vehicles I still haven't been in anything that is much better. Except for front overhang.
Pull on the difflock(s) and you're good. Never have I felt the % difference required to engage the VC an issue.
Compared to the binding in the axles I had with other 4WD's I would take the VC any day. And follow any other comparable 4WD on the planet.
And then have AWD on the bitumen.
That's why I like this crazy old block of flats that I drive around.
Hi Peter,
Re: On the subject of solid shafts, unless you live and drive only on “rough and broken ground”,
Ummmmmm ... correct me if I'm misunderstanding, but you seem to be inferring we shouldn't be driving them on hard surfaces?
Your mechanic you mention, he works on European cars I believe. Does he speak fluent German?
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of Peter SCHWEINSBERG peter@peterandval.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>
Sent: Thursday, 24 May 2018 12:20 PM
Paul.
I would assume Peter means the load on the transmission system will be higher with a solid shaft compared to a VC.
You could only drive with a solid shaft on the road if you decoupled front/rear (essentially what a good VC will do automatically)
Doesn't look at the syncro specifically, but interesting none the less.
https://www.youtube.com/watch?v=TotrUUuYOM4
https://www.youtube.com/watch?v=jm-_Ncjunuc
This one is an add for Subaru, so is far from telling the truth, but interesting to watch.
https://www.youtube.com/watch?v=2OzK-oRPCbs
An interesting point often over looked, if you have a 4WD system with all wheels locked, the amount of torque you can put to the ground is still affected by suspension travel (assuming you are on a slippery surface)
Hi Ken,
I’m fundamentally saying that our SYNCRO transmissions have a history of needing to be serviced.
I’m gathering that there is a growing shortage of parts.
So in the case of solid drive to the front, that is no viscous coupling.
If that is what I had that then,  I would not be driving it in hard surfaces.
Look at my numbers and see the variation between each of the four wheels on a full lock circle turn.
All I see is axle windup, a loaded transmission,  and tyres skipping on tight turns.
What I am saying, I’d have no concern on sand and loose surfaces.
My SYNCRO only gets it’s VC on when 2WD shows signs of slip,
then progressively the VC is switched on, next the rear diff lock, last of all the front.
Perhaps if I faced a swamp, thick loose sand they would all come on before entering.
Extremely wet “soapy” clay, would get the VC and the rear lock before the front lock.
I’ve been on extremely wet “soapy” clay, where even with all three,
the SYNCRO was vectoring along the way at 20 to 30 degrees to the direction of travel.
My mechanic.
I don’t know whether Michael speaks German or not,
But he is a specialist Porsche mechanic whose Porsche Cup customers demand the best.
He treats me and the Bergmeister the same way.
On 24 May 2018, at 11:35 PM, Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Peter,
Paul.
If however you are after a good all round performer and don't want to constantly monitor road surface, if you need to be coupled or not you can't beat a working VC.. It will get you a lot further than a 2WD and it will be a lot safer on wet roads or hard dirt roads than with a solid shaft (as in you would need to decouple front to rear in these conditions)
Could not agree more.
And the programmable stuff that manufacturers are throwing at us,
like the Ford Everest I was allocated for the tag along in the wilds of New Zealand’s South Island is a good example.
On 24 May 2018, at 9:58 PM, m.mullet@yahoo.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Peter,
Thank you. Reckon we're on the same page, as below.
Sent: Friday, 25 May 2018 1:00 PM
Hi Ken,
I’m fundamentally saying that our SYNCRO transmissions have a history of needing to be serviced. Agreed, it's just another wear item that requires maintenance to avoid massive repair costs if else neglected.
I’m gathering that there is a growing shortage of parts. Agreed, it helps a lot though where a local mechanic has long established direct supply source links to Europe, for syncro drivetrain components.
So in the case of solid drive to the front, that is no viscous coupling. Absolutely, it's not. Solid shaft has such reassuring capabilities plus full-on function. Benefits/concerns/obligations/recurring costs differ to a VC.
If that is what I had that then,  I would not be driving it in hard surfaces. Me neither, except straight ahead.
Look at my numbers and see the variation between each of the four wheels on a full lock circle turn. Agreed. Best to avoid doing full lock turns with either VC OR solid shaft. I learnt that from my mechanic. He said to do 3 point turns instead. Also avoids unnecessary extra stress on front CVs. It's all about drivetrain preservation.
All I see is axle windup, a loaded transmission, and tyres skipping on tight turns. Agreed. Best to avoid being stranded or flat bedded home, due to an otherwise avoidable and inconvenient failure.
What I am saying, I’d have no concern on sand and loose surfaces. Agreed. Me neither for solid shaft.
My SYNCRO only gets it’s VC on when 2WD shows signs of slip, Agreed, also on when anticipating likely slip.
then progressively the VC (solid shaft) is switched on, next the rear diff lock (ok), last of all the front. (n/a)
Perhaps if I faced a swamp, thick loose sand they would all come on before entering. Agreed, given difflocks take time to engage, it's prudent to couple all before the event, not in it.
Extremely wet “soapy” clay, would get the VC and the rear lock before the front lock. Asking for trouble here!
I’ve been on extremely wet “soapy” clay, where even with all three, the SYNCRO was vectoring along the way at 20 to 30 degrees to the direction of travel. Agreed. In my case, truly an unnerving experience when all solid shaft engaged 4 wheels unexpectedly lost traction up a grass slope, vectoring helplessly back down the slope. Useful lesson learnt.
My mechanic. My Austrian mechanic worked/trained/qualified/for VAG Europe specialising in syncro drivetrain. I believe he is THE ONLY specialist VAG trained/qualified syncro drivetrain service/repair/rebuilder in Australia. Also has direct syncro drivetrain supply sources from Europe. The complete package really for all of us syncronutters downunder!
I don’t know whether Michael speaks German or not, Mine does, it sure does help with customers and suppliers.
But he is a specialist Porsche mechanic whose Porsche Cup customers demand the best. Same here on syncro.
He treats me and the Bergmeister the same way. Mine likewise and a nice bloke to boot!
Hi Peter,
Paul.
I like your write up Peter, and is a good way to look at it. From experience in my van, there is not switch from coupled to uncoupled, but a progressive change. So the 6% or 10% would not really matter..
The only thing you have not done is shared your mechanic’s name, address and contact details.
On 25 May 2018, at 4:43 PM, Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Peter,
Hi Ken,
All I see is axle windup, a loaded transmission, and tyres skipping on tight turns. Agreed.. Best to avoid being stranded or flat bedded home, due to an otherwise avoidable and inconvenient failure.
Hi Peter,
Paul.
Peter,
Urrrmmmmmmmmmmm ... really? But I have. So have others here. In fact more often in recent times. He's definitely not a secret.
With respect, what you ask about has been posted here on this forum on a pretty regular basis, usually at times when the question of syncro transaxle servicing/repairs plus shipping is raised. In fact I remain bemused as to why it's necessary to repeat the same contact details so often. Don't people use a pen and paper anymore?Perhaps we need a sticky message posted someplace, given its importance to members.
I forgot to restate before, this T3 syncro drivetrain specialist prefers to drive his syncro almost always in 2WD. For 4WDing, he engages a solid shaft. What would he know? Perhaps he's misguided.
But sure, he loves to chat on the phone of an evening to anyone about syncro drivetrain issues.
Sent: Friday, 25 May 2018 5:10 PM
Hi Peter,
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of Peter SCHWEINSBERG peter@peterandval.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups..com>
Hi Ken,
Hi Peter,
Paul.
From: "cathrich1@yahoo..com.au [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
