----- Original Message -----From: plander@optusnet.com.auSent: Saturday, November 22, 2008 6:41 PMSubject: Re: [Syncro_T3_Australia] Double Cab Syncro
> Les Harris <leslieharris@ optushome. com.au> wrote:
> Phill,
> Ah, more history. Do you have any details of the upgrading?
8 Bilstein shock absorbers per car.
Extra body protection
Seikl springs
Extra fuel tanks.
Engines were standard MV
There were a few wbx engines upgraded to 2.5L in Sydney around 1990. The high compression caused dramas with our third world fuel of the time.
> Phill,
> It is interesting that the engine was left as standard MV. I have
> people contact me from time to time asking about engine upgrades. I
> have the same answer to all of them. Either leave it as standard or, if
> they really want more power, install a 2.5 Subaru but no larger. I
> point out that a lot of money can be spent on upgrades but the law of
> diminishing returns applies. Spend a lot of money, get a marginal
> increase in performance but usually at the expense of engine longevity.
> Now I can add the Safari vehicles as a good example of getting adequate
> performance out of the stock MV engine.
> > Phill,
> > Les
> Seikl springs
> Extra fuel tanks.
On Fri, Nov 21, 2008 at 11:57 PM, <plander@optusnet.com.au> wrote:
Remember Les that these cars were brought into Australia as normal ADR approved vehicles. The only engine approved was the standard MV. They have normal compliance plates like any other syncro.
Apparently, Calfornia has 3rd world fuel as well as a few of these larger displacement WBX's have grenaded themselves.I just tooled around in my very basic ABA 2.0 liter inline-4 today. It was more than adequate for daily driving. No headgasketisssues either. Since this was in a Doublecab, the engine is mounted at a 15° position just as it was in the donor Golf.As Les mentioned earlier, anything too drastic will require upgrades in other areas as well. Most notably, the Syncro transmissionis not likely up to anything over 200hp. Sure it can survive if you preload the drivetrain. But what's the fun in that?BenT
| syncroaustralia | Apr 28, 2008 | |||||||
| Aust-VW-power-Aug-Sept-1990.jpg VW Power Aug/ Sept. 1990 Australian Safari Syncro's | 298 KB | syncroaussie | Jan 1, 2007 | |||||
| Aust.Safari-1990-2.jpg VW Power Aug/ Sept. 1990 Australian Safari Syncro's | 331 KB | syncroaussie | Jan 1, 2007 | |||||
| Aust.Safari-1990.jpg VW Power Aug/ Sept. 1990 Australian Safari Syncro's | 295 KB | syncroaussie | Jan 1, 2007 |
28 Gwynne St
Richmond
Vic 3121
gary@twentytwentyone.net
www.twentytwentyone.net
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
Phill,It is interesting that the engine was left as standard MV. I have people contact me from time to time asking about engine upgrades. I have the same answer to all of them. Either leave it as standard or, if they really want more power, install a 2.5 Subaru but no larger. I point out that a lot of money can be spent on upgrades but the law of diminishing returns applies. Spend a lot of money, get a marginal increase in performance but usually at the expense of engine longevity. Now I can add the Safari vehicles as a good example of getting adequate performance out of the stock MV engine.Les----- Original Message -----From: plander@optusnet. com.auSent: Saturday, November 22, 2008 6:41 PMSubject: Re: [Syncro_T3_Australi a] Double Cab Syncro
> Phill,
Seikl springs
Extra fuel tanks.
> http://www.pps.net.au/4wdencounter/articles/vw.htmlThat article is an embarassment. You should have seen it before the corrections!
----- Original Message -----From: Gary CooksonSent: Sunday, November 23, 2008 7:45 AMSubject: Re: [Syncro_T3_Australia] Double Cab Syncro UpgradingHere's a link to what i assume is Mark's Syncro dual cab?There are also some articles in the links of the forum detailing the conversion.
VW Power Aug/ Sept. 1990 Australian Safari Syncro's298 KB syncroaussie Jan 1, 2007 Aust.Safari-1990-2.jpg
VW Power Aug/ Sept. 1990 Australian Safari Syncro's331 KB syncroaussie Jan 1, 2007 Aust.Safari-1990.jpg
VW Power Aug/ Sept. 1990 Australian Safari Syncro's295 KB syncroaussie Jan 1, 2007
[2 0 / 2 1 Design]
28 Gwynne St
Richmond
Vic 3121
Tel 3 9429 1868
Fax 3 9421 1110
Mob 0417 352782
> Phill,
Seikl springs
Extra fuel tanks.
On Sat, Nov 22, 2008 at 2:25 PM, Les Harris <leslieharris@optushome.com.au> wrote:
Gary,The syncroaussie links are coming up as 404 Not Found.Does anyone have copies?LesLes,Did you mean the link that Phil sent? Works fine for me. I've cut& pasted the page into email. Now sure if this willgo through the forum but here it goes...BEN
OH VOTT A FEELING !
Would you drive your rare and collectible VW through axle deep mud, up crazy inclines at ridiculous angles and along boulder strewn, teeth rattling bush tracks ? Thought not, but then this ain't no ordinary Volkswagon collectors piece.
Story & Pix:- RICK McDOWELL
This article copyright to Rick McDowell, Australia.
Rick McDowell, PO Box 1537, Wangara, Western Australia 6947
Expressions of interest from Overseas publishers most welcome. Quality 35mm transparancies to support article available immediately.
All enquiries to:What you're looking at here is Australia's one and only VW syncro dual-cab Transporter with 16" wheels and double-diff-locks. A bit of a mouthful true, but it's important that we get the explanations correct right from the start. You see, Volkswagen's syncro 4WD system is nothing special Down Under and it 's fitted to quite a few vehicles, including transporters (see side story).
The usual wheel size with Transporters though is 14" and single-cab configuration with a single diff-lock down the back is more normal too. So, finding a dual-cab Transporter with two diff locks riding on 16" wheels is a rare find indeed. But whatever you do, don't go telling Hans that all he has is a tricked up Kombi. This machine sure ain't no custom butchers special and was manufactured under contract for Volkswagen by Austrian specialists, Steyer Daimler-Puch (see side story).
The vehicle came to Australia in the early 90s for the Wynns Around Australia Trial and won its class based on engine capacity (2.1 litre). The passage of time has seen the unique VW sold to various owners, although how Hans acquired it is an interesting story in itself. A ceramic tiler by trade, Hans has owned about six VWs over the years, all of them Combis, although there have been a couple of dual-cabs and one or two other projects. "I was in the process of re-building a dual-cab Toyota would you believe, but I was never really happy with it," recalled Hans. "Then my best mate John came back from Queensland with some pictures of this dual-cab, double-diff-lock syncro VW and I fell in love.
So, I rang up the missus and asked her if I could buy it and she said yes - I think because she was having such a good time in Bali when I rang ...." Volkswagen's ultimate 4WD machine was in reasonable condition when it arrived in Perth, yet a vehicle such as this still needs repaired and serviced like any other. Peter Arnoldi is the individual responsible or keeping Hans' VW in perfect working order and there's probably no-one better qualified to do the work in Perth.
A motor mechanic by trade specialising in VWs, Peter works out of the same shop on the same premises that his father Heinz founded back in the 1950s. To say that the guy is a Volkswagen connoisseur is an understatement and he's even done some of his own research on Hans' double-diff-lock syncro. "I was at Wolfsberg in Germany for a training course back in 1985 and they told me then that double-diff-locks were only fitted to military vehicles", explained Peter. "This particular one that Hans owns came into Australia along with a 16" wheeled Combi camper to do the Wynns Around Australia Trial back in 1992. I think the Combi was just a support vehicle for the trial, but it's now owned by a Baptist missionary up at Oenpelli in the Northern Territoy – I should know because his engine is sitting in my workshop !! I've got a feeling too, that Hans' dual-cab is the actual one they used on a poster where it was jumped off a sand dune on Fraser Island."
Interestingly, the dual-cab featured here and the associated Combi utilise the same 2.1 litre liquid-cooled powerplant. It's the same engine as found in MV engine numbered Transporters from 1987 through to 1992. Peter admits that these motors do require good maintenance and he has already replaced the heads and head studs on Hans' engine due to corrosion. Although the original pistons, rods and crank are still on board, Peter has replaced the camshaft (stock specification) and various items in the valve train. A new clutch has also been added, while the gearbox was fully re-built by Regents in Osborne Park. Everything else in the engine and transmission departments has proved ultra reliable, including the stock exhaust system and Bosch 'Dijifant' EFI package.
As an enthusiastic member of the Wanneroo Wanderers 4WD club in Perth, Hans takes his rare VW on regular excursions and expeditions. Not surprisingly, the vehicle carries quite a few modifications, although there's a number of interesting features that are standard. There is, for example, provision for dual shocks on all four corners, yet Hans is happy enough with single shocks and has recently replaced the originals with Bilsteins. While we're discussing the underside of the vehicle, it's worth noting the huge skid plates which run all the way from front to back. There are no linkages or suspension components to snag on obstacles and if the rear wheels are driving, this Syncro could literally 'skate' forwards if the front wheels left the ground. Also of interest is a wiring loom under the back seat to accommodate three batteries in addition to that found under the front driver's seat. As a serious 4WDer, Hans has always used the extra battery capability for such things as air compressors and the 'obligatory' Engel fridge. In fact, Hans says that he owns about three Engels and which one he uses depends on the length of the trip !
There's plenty of space out the back and underneath the dual-cab, so much so in fact, that a 50 litre water tank is a standard feature too. On the inside and much of the dual-cab's interior has been customised, with the rear door trims and their additional pocket spaces a prime example. In-between the front seats resides a home-made centre console, again with storage space in mind, although it was originally designed to carry a small TV and a video recorder for the kids. Further in-flight entertainment is provided by a mild sound system.
When all is said and done however, the great thing is that this rare VW is regularly used in the sorts of conditions for which it was intended. The looks on the faces of other 4WD enthusiasts when they see what they falsely believe to be a Combi climbing a near vertical incline with six foot deep ruts and knee deep mud .........
Oh Vott a feeling indeed !! VOTT'S A SYNCRO MEIN HEIR ?
To understand how Volkswagen's syncro AWD system came into being requires some knowledge of the relationship between the various auto makers and specialists in Europe. Nonetheless, it was in the late 1970s that engineers from Volkswagen and it' s siblings Audi and Porsche, got together to see if they could invent the World's greatest All Wheel Drive system.
When the boffins had finished, they decided that Volkswagens fitted with the new system would be called 'Syncros', while Audi would use the 'Quattro' tag. Porsche used the system in their 959, but didn't really have a catch phrase. The number of Volkswagens fitted with the Syncro system over the years is vast and includes everything from the Passat, the Golf to all sorts of full or semi 4WD vans, Combis and transporters.
Transporters with the system are actually quite rare and as discussed in the main story, double-diff-lock, 16" wheel syncros are few and far between. Over the years there have actually been several versions of VW's Syncro system, the more latter - and as fitted to the dual-cab featured here - known as Vanagon.
Names aside, the system sees the rear wheels driven all the time, while the front wheels are normally free. When wheel spin occurs however, a viscous coupler transfers power to the normally free wheels for extra traction. The viscous coupler is a case full of parallel plates and a silicon gel. When the plates start to turn at high speed (wheel spin), the gel turns into a solid, locking the plates and transferring power through to the wheels that are normally free.
The system is quite efficient, but is really more practical for road cars as things can become complicated if a wheel leaves the ground. For serious 4WDing therefore, the addition of at least one diff' lock is preferred to back up the Syncro system, but of course, the dual-cab transporter featured here is equipped with two diff' locks. Make no mistake about it, this dual-cab, double-diff-lock syncro is virtually unstoppable !
Most of Volkswagen's syncro equipped vehicles were (and are) built by Austrian 4X4 specialists, Steyer Daimler-Puch. Steyer have been operating since the late 1950s and are well known for their small Haflinger vehicle. If you're still none the wiser, then consider that Steyer made the G-wagon for Mercedes Benz, the Fiat Panda's 4WD transmission, assemble the Jeep Grand Cherokee and are involved with Range Rover's Freelander. (c) Rick McDowell 1999
These pages were last updated on 16th July 1999.
Hits since 16th July 1999:
