I have just looked at a Trakka Multivan (1989) and the sliding windows are Kingsleys.
And yes the rubbers are sucked in on the corners.
----- Original Message -----From: plander@optusnet.com.auSent: Saturday, August 16, 2008 1:26 PMSubject: [Syncro_T3_Australia] Trakka WindowsLes,
On 8/15/08, Les Harris <leslieharris@optushome.com.au> wrote:Phill,The problem certainly seems endemic to this brand. I occasionally see a Caravelle not far from where I live. If I can catch up with the owner, I can very quickly measure the corner radius (I have made some card templates) and compare it with mine.It is possible to make up a mould to correct the corner radius. It will take some time and effort but should correct it. There aren't many alternatives. One is to fill behind the seal to take up the slack but that could be a bit hit and miss. The last alternative is to try to find some second-hand genuine windows. I believe that they are quite pricey. Or perhaps fit fixed glass until I can work something out.Les----- Original Message -----From: plander@optusnet.com.auSent: Saturday, August 16, 2008 1:26 PMSubject: [Syncro_T3_Australia] Trakka Windows
Les,
> Phill,
> Les,
> are Kingsleys.
----- Original Message -----From: BenT SyncroSent: Saturday, August 16, 2008 3:12 PMSubject: Re: [Syncro_T3_Australia] Trakka Windows
Les,I can make a template and mail it to you. It would me much cheaper than shipping a real (original) window -- which are cheap here.BenT
On 8/15/08, Les Harris <leslieharris@ optushome. com.au> wrote:Phill,The problem certainly seems endemic to this brand. I occasionally see a Caravelle not far from where I live. If I can catch up with the owner, I can very quickly measure the corner radius (I have made some card templates) and compare it with mine.It is possible to make up a mould to correct the corner radius. It will take some time and effort but should correct it. There aren't many alternatives. One is to fill behind the seal to take up the slack but that could be a bit hit and miss. The last alternative is to try to find some second-hand genuine windows. I believe that they are quite pricey. Or perhaps fit fixed glass until I can work something out.Les----- Original Message -----From: plander@optusnet. com.auSent: Saturday, August 16, 2008 1:26 PMSubject: [Syncro_T3_Australi a] Trakka Windows
Les,
----- Original Message -----From: plander@optusnet.com.auSent: Saturday, August 16, 2008 3:17 PMSubject: Re: Re: [Syncro_T3_Australia] Trakka WindowsLes,
The easiest way would be to measure a fixed glass as it is more 2 dimensional if you know what I mean. I have one somewhere, but I cannot find it.
> Phill,
> Les,
> are Kingsleys.
On 8/15/08, Les Harris <leslieharris@optushome.com.au> wrote:Ben,That's kind of you. The key dimension is the corner radius of the vertical flange that goes into the seal.Next best is the radius of the rib on the outside of the frame as it is installed in the vehicle. The two radii would be concentric, so the radius of the rib can be extrapolated to the radius of the vertical flange if the overall depth/length is know.However, I don't know for sure if the overall depth/length of this aftermarket window is the same as the original VW slider. If anyone has a loose fixed glass and could give me the overall depth/length, I would know where I was starting from. Needless to say, such a loose fixed glass would also give me the all important corner radius!LesLes,Alas, fixed glass windows are rare her except for the ones that got from D to E pillar. We got those in two flavors. One is just plain glass the shape of the opening. The other is slightly shorter with a plastic flow through vent in the rear. If you can't get the dimensions locally, let me know and I'll bring out the trusty tracing pencil. If you just want the corners, it will be a very small piece of paper.Cheers,Ben
----- Original Message -----From: BenT SyncroSent: Saturday, August 16, 2008 5:35 PMSubject: Re: [Syncro_T3_Australia] Trakka Windows
On 8/15/08, Les Harris <leslieharris@ optushome. com.au> wrote:Ben,That's kind of you. The key dimension is the corner radius of the vertical flange that goes into the seal.Next best is the radius of the rib on the outside of the frame as it is installed in the vehicle. The two radii would be concentric, so the radius of the rib can be extrapolated to the radius of the vertical flange if the overall depth/length is know.However, I don't know for sure if the overall depth/length of this aftermarket window is the same as the original VW slider. If anyone has a loose fixed glass and could give me the overall depth/length, I would know where I was starting from. Needless to say, such a loose fixed glass would also give me the all important corner radius!LesLes,Alas, fixed glass windows are rare her except for the ones that got from D to E pillar. We got those in two flavors. One is just plain glass the shape of the opening. The other is slightly shorter with a plastic flow through vent in the rear. If you can't get the dimensions locally, let me know and I'll bring out the trusty tracing pencil. If you just want the corners, it will be a very small piece of paper.Cheers,Ben
Dear Les,
I had to replace the sliding window in the sliding door of my (non Trakka) camper after someone decided to gain entry with a brick. That was while I was in W.A. When I returned I sought to replace the temporary perspex that got me home and couldn't find a wrecker or automotive glass supplier that could help other than by getting in a genuine VW one at from memory about $200. I baulked at the price and whether mine was a VW sliding window.I then tried an ordinary general household glass supply shop near me and he came out with a radius gauge worked out the corner arcs and ordered in an appropriate sheet of toughened glass to the measurements as he could not cut it.Again from memory it cost me $60.
If I look at my frame there are no markings as I think the brand sticker disappeared with the original glass. My deluxe van has the original fixed VW window set in rubber on the driver's
side whereas I think this is where you have your sliding window in a frame. Interestingly my frame in the sliding door also exhibits some "sucking in" but no leaking/rust problems. On my frame the outer part of the frame would have to follow the door window profile more closely to avoid the sucking in rather than the window glass pushing it out. All the above is a long way of saying that you may be able to get a local glass supplier (or mine in Nicholson St Nth Carlton) with an appropriate gauge to measure what you want and fix you up at reasonable cost.
Good luck and contact me if I can help further.
--- On Sat, 16/8/08, Les Harris <leslieharris@optushome.com.au> wrote: From: Les Harris <leslieharris@optushome.com.au> |
--- On Sun, 8/17/08, Roger Bell <bellrmit@yahoo.com.au> wrote:
> From: Roger Bell <bellrmit@yahoo.com.au>
> Date: Sunday, August 17, 2008, 9:57 AM
> Dear Les,
> cost me $60.
> on the driver's
> Cheers
> Roger
> Received: Saturday, 16 August, 2008, 3:58 PM
> Ben,
> Thanks for that. I will keep you posted and call upon
> your offer if I can't get the information locally.
> From: BenT Syncro
> Subject: Re: [Syncro_T3_Australi a] Trakka Windows
> com.au> wrote:
> Ben,
> Les,
> paper.
> Ben
> Win a MacBook Air or iPod touch with Yahoo!7.
> http://au.docs.yahoo.com/homepageset
----- Original Message -----From: Roger BellSent: Sunday, August 17, 2008 11:57 PMSubject: Re: [Syncro_T3_Australia] Trakka Windows
Dear Les,I had to replace the sliding window in the sliding door of my (non Trakka) camper after someone decided to gain entry with a brick. That was while I was in W.A. When I returned I sought to replace the temporary perspex that got me home and couldn't find a wrecker or automotive glass supplier that could help other than by getting in a genuine VW one at from memory about $200. I baulked at the price and whether mine was a VW sliding window.I then tried an ordinary general household glass supply shop near me and he came out with a radius gauge worked out the corner arcs and ordered in an appropriate sheet of toughened glass to the measurements as he could not cut it.Again from memory it cost me $60.If I look at my frame there are no markings as I think the brand sticker disappeared with the original glass. My deluxe van has the original fixed VW window set in rubber on the driver's
side whereas I think this is where you have your sliding window in a frame. Interestingly my frame in the sliding door also exhibits some "sucking in" but no leaking/rust problems. On my frame the outer part of the frame would have to follow the door window profile more closely to avoid the sucking in rather than the window glass pushing it out.All the above is a long way of saying that you may be able to get a local glass supplier (or mine in Nicholson St Nth Carlton) with an appropriate gauge to measure what you want and fix you up at reasonable cost.Good luck and contact me if I can help further.CheersRoger
Win a MacBook Air or iPod touch with Yahoo!7- Find out more.
----- Original Message -----From: n hSent: Monday, August 18, 2008 11:57 AMSubject: Re: [Syncro_T3_Australia] Trakka WindowsLes I have a '89 caravelle gl syncro with what i think are original sliding side windows and can happily trace/measure up or offer you/someone else to do same if useful around Sydney's eastern suburbs. If former you'll have to give me precise instructions. I'm not quite sure how to access under the seal to get you the precision you need.
Nigel.![]()
----- Original Message -----From: nickbellauSent: Monday, August 18, 2008 12:52 PMSubject: [Syncro_T3_Australia] Re: Trakka WindowsLes,
I have just added some photos of the side window I had put in about 12 years ago. The local manufacturer (Adelaide) got around the different radius problem by pop riveting an additional piece of aluminium to the new aluminium window frame. One of the rivets is visible while the other two are hidden under the seal. It looks a little rough in the photo, but this is the first time I have noticed it in 12 years. From a distance (main window shot) you cant see it at all. I only noticed it as I wondered why my windows had not suffered from the same fate as yours. They have not leaked or sunken at all.
>>> "Les Harris" <leslieharris@optushome.com.au> 18/08/08 1:04 PM >>>Nick,
Les,
