Send me a private email to:
spbconsulting@bigpond.com
With your bank details.
Hi Scott
I used E-Go when I sent them previously to Roger, pickup from my door to Berkeley Vale Depot is $40 to keep round numbers plus maybe $10-20 for insurance if you want it, can't tell from their website unless I book it.
The package size is 10cm x 10cm x 140cm and weighs 10.5 KG, in case you want to check with E-go or other couriers.
and a shaft is $490
Cheers, Uwe
On 31/05/2018 2:17 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] wrote:
Hi Uwe,
How much for a courier to NSW Central Coast?
Have you tried Ego Couriers?
I could pick it up from the Central Coast depot in Berkeley Vale.
Please advise.
On 29/05/2018 4:52 PM, 911Jack 911jack@gmail.com [Syncro_T3_Australia] wrote:
Peter, Mark, Scott ,...
I'm in Melbourne, the shafts are $490 plus courier (I sent 2 to Roger for about $70 with insurance Melb-Goulburn).
I have 3 ready and get can more made within a week or so. They are simple solid shafts with just serviceable uni's at either end, they are common 153X made by many including Dana Spicer.
Been meaning to put up a website up for them and other bits, need to pull my finger out.
Cheers Uwe
On 29/05/2018 1:37 PM, Peter Bellamy wanderingstar911@gmail.com [Syncro_T3_Australia] wrote:
UweHi thereI'd be interested mate.How much?Where are you?ThanksPeter Bellamy
On Tue, 29 May 2018, 1:33 pm 911Jack 911jack@gmail.com [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
I have had some shafts made up just like the gowesty ones, solid shafts with grease nipples and common replaceable uni joints, if anyone is interested I still have a few. I've had mine in place for a year and done quite a few thousand K's with no issues or any vibrations.
Roger Bailey also has one in use. (Hi Roger)
I had the same issues with the original, changed to the agro uni joints, had it balanced, still had vibrations. Had the solid shafts made and haven't looked back.
Cheers, Uwe
On 28/05/2018 4:28 PM, Peter Bellamy wanderingstar911@gmail.com [Syncro_T3_Australia] wrote:
Alternativehttp://www.gowesty.com/product/transaxle-drivetrain/23382/syncro-drive-shaft-new-?v=
On Mon, 28 May 2018, 3:47 pm Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Also,I read somewhere that local refurbishers/balancers of the likes of tailshafts/propshafts do not have test equipment that maximum rotate any where near as far as our propshafts do. Limited to say 1000rpm. If valid, then your vibration coming in in excess of 100kph may not show up. I stand corrected if incorrect.Cheers.Ken
Sent from Samsung tablet
-------- Original message --------
From: "Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Date: 28/05/2018 3:17 PM (GMT+10:00)
To: syncro_t3_australia@yahoogroups.com
Subject: Re: [Syncro_T3_Australia] Re: Syncro / VC / noise and vibes
Hi Gaetan,
Sure, if you so choose. Might get lucky.
There's been previous discussion here about replacing joints with a particular model designed more for agricultural use. Maybe not quite up to scratch but lacking an alternative. Not been there so can't help further, someone else may have more specific info.
Ken
Sent: Monday, 28 May 1:35 PM
Subject: [Syncro_T3_Australia] Re: Syncro / VC / noise and vibes
I'm awaiting to hear from FDE - hopefully they will be able to help and that will solve my problem!
When you say having the uni's checked, do you mean the U-joints either end of the tail shaft?
And thanks to all who posted in this topic - all great advice and much appreciated!
Best regards, Scott Pitcher SPB Consulting
