Hi Greg,
Ok thankyou for that clarification.
So concerning the donut, what is its function please? It must have one, despite GoWesty saying it's not needed ... they leave it out in their own replacement propshaft.
Best guesses are:
Is a buffer, absorbing impacts in the drivetrain or ....
Allows and accommodates to a degree, out of spec changes in relative setup angles between components, they being the setup angles of the transaxle, propshaft and front differential.
or? ...
Don't recall this being discussed here before. TIA.
Sent: Monday, 28 May 2018 5:32 PM
Subject: Re: [Syncro_T3_Australia] Re: Syncro / VC / noise and vibes
It doesn’t work that way. Many modern wheel balancers spin very slowly. It’s all about the quality of the sensors. If there is play in the unis have them replaced by the professionals and then they will balance it. You can also replace the bush and o ring
under the donut. Greg
On 28 May 2018, at 4:28 pm, Peter Bellamy wanderingstar911@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Alternativehttp://www.gowesty.com/product/transaxle-drivetrain/23382/syncro-drive-shaft-new-?v=
On Mon, 28 May 2018, 3:47 pm Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia], <Syncro_T3_Australia@yahoogroups.com> wrote:
Also,I read somewhere that local refurbishers/balancers of the likes of tailshafts/propshafts do not have test equipment that maximum rotate any where near as far as our propshafts do. Limited to say 1000rpm. If valid, then your vibration coming in in excess of 100kph may not show up. I stand corrected if incorrect.Cheers.Ken
Sent from Samsung tablet
From: "Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Date: 28/05/2018 3:17 PM (GMT+10:00)
Hi Gaetan,
Sure, if you so choose. Might get lucky.
There's been previous discussion here about replacing joints with a particular model designed more for agricultural use. Maybe not quite up to scratch but lacking an alternative. Not been there so can't help further, someone else may have more specific info.
Sent: Monday, 28 May 1:35 PM
Subject: [Syncro_T3_Australia] Re: Syncro / VC / noise and vibes
I'm awaiting to hear from FDE - hopefully they will be able to help and that will solve my problem!
When you say having the uni's checked, do you mean the U-joints either end of the tail shaft?
And thanks to all who posted in this topic - all great advice and much appreciated!
